Results 1 to 32 of 32
    Reputation: CrozCountry's Avatar
    Mar 2011
    Why does my friends bike (Reign SX) rides so much nicer than mine (Blur LT2)?
    My friend's bike tracks so much better and confidence inspiring. It goes when you point it. It feels like its on rails, while my bikes "jumps around" (his description, for luck of better terms). Need more effort to keep a line.
    My bike:
    Santa Cruz BLT2, Fox Talas 32 150mm 1 1/8 steerer, Float RP23 shock, 90mm stem, 685mm handlebars
    His bike:
    Giant Reign SX, Fox Van 36 160mm coil fork with tapered steerer, FOX DHX RC2 coil shock, shorter stem and wider bars (not sure how much)
    Wheels and tires about the same. My bike is 5 pound lighter and little bit shorter wheelbase.
    He thinks it's the stiffer fork, 36 stanchions and beefy steerer.
    Is it the coil suspension?
    Wider handlebar with shorter stem?
    Geometry?
    Beefy fork?
    Talas not plush?
    All the above?
    There must be something that is more contributing than the rest.
    Reputation: fireball_jones's Avatar
    The Reign X is 7'' of coil suspension, you could run it as a downhill bike if you wanted to. It's not too surprising it's more confident than a Blur.
    Reputation: wilsonblur's Avatar
    Quote Originally Posted by CrozCountry View Post
    My bike:
    His bike:
    Geometry?
    Beefy fork?
    Talas not plush?
    All the above?
    It depends on what you mean by nicer? They are in two totally different categories of bikes. The Reign is an AM/Freeride bike. The BLT is a long legged trail bike. Its sort of like comparing a Toyota Rav 4 to a Jeep Wrangler. They sorta do the same thing but really excel in different areas. Sounds like you want an AM 6+ inch travel bike.
    Narrow is the path to life, few are those who find it.
    Reputation: TwoHeadsBrewing's Avatar
    The Reign with a F36 160 coil fork has slacker angles AND the more plush feel of coil. If you're after more of an AM feel to your bike, here's what you can do:
    700mm+ bars & 65mm stem: brings the bars back so it's easier to ride further back on the bike.
    Run 30%+ sag on your shock and fork: in fact, run the shock as low as you can without bottoming out or feeling like the rear end wallows around. Adjust rebound speed up to compensate for the additional sag. More sag means you're riding in mid-travel more of the time which helps keep the tires on the ground and you in control.
    Run a 160mm travel coil fork: this will give you not only a bit more travel, but will slack out the geometry of the bike to be more similar to the Reign.
    "Got everything you need?"
    Reputation: Lost Biker's Avatar
    I agree with other posts. You are comparing to different category of bikes.
    the biggest things you are likely noticing are:
    air rear shock vs. coil
    xc fork vs. basically a DH fork
    narrow bars/long stem vs. wide bars/short stem
    Flying in High in the Sky
    Fox 36 20mm tru axle > Fox 32.
    Reputation: gticlay's Avatar
    You need a Nomad set up similarly to really compare with the bike he's riding. The Blur is more like a long travel race bike that I think people tend to expect too much out of.
    "It looks flexy"
    Reputation: 006_007's Avatar
    Also i think the weight difference is what you could be feeling a bit. 5 extra pounds on the bike will allow it to "plow" through technical things without being deflected (bounced around) quite as much.
    Reputation: sooner518's Avatar
    lets count the ways:
    - more travel. (6.7 vs 5.5 inches)
    - Coil rear suspension
    - Coil fork with more travel
    - Tapered steerer
    - 20mm thru axle
    - slacker geometry
    - wider bars
    - shorter stem
    - longer wheelbase
    - heavier overall, allowing it to effectively plow through obstacles better instead of getting popped up and to the side
    I would be confused if his bike didnt feel better on the downhills. If you want the SC equivalent of what he has, you oughta be on a Nomad.
    The LT2 is pretty slack as-is, and it'll take a 160mm fork. Its a pretty burly bike.
    fox float shocks kill everything they're on. Your bike would drastically change with a better shock! If you went 160mm up front and a good coil in the back, the gap between the two would close a good amount.
    I had a Nomad gen 1.5 that I just sold and still own a MotoLite. My Nomad was set up similar to your buddy's Reign and my MOTO similar to the blur. If the two bikes rode similar I'd be a bit worried... They are designed to excel at two different types of riding.
    You are trying to compare bikes in two diffrent classes. There is a reason why manufacturers make bikes in different categories, they behave differently. There is a right tool for every job.
    Mar 2011
    Had another ride today and watched my bike closer. The front does not keep a straight line well without rider input. The bar moves right left all the time, little movements but very visible. Another thing that I don't like is that the bike tends to fall into the turn when you lean, while the Reign keeps the line you are taking without many corrections.
    I am not talking intense downhill, just riding normal singletrack that is up and down.
    I am thinking more and more about a taller front. More sag in the back is little difficult with this bike since the BB is already low and pedals hit things all the time.
    About handlebars, I know. I have a problem with the brake hose. This is as wide as it will go. Changing the brake hose is a PITA but I guess its inevitable.
    It really is the combination of all things that have been stated above. You over analyzing it. Heavier is more stable. Stiffer front tracks more true due to stachion size, larger axles and who knows maybe even tire choice. Deeper suspension plus coil means over better compliance. I guarentee you this. Go do an xc race on his bike then yours. The overall pedaling effeciency of your bike will eventially become more evident. Somthing that wont show when just riding his for short segments.at a.time
    Even heavier wheels roll better when your not pedaling, but accelerate slower. Bar and stem combo and how the bars are rotatedwithin the.stem even completely changes steering characteristcs.
    General consensus is that fox 150 fork in 32 mm is a noodle. I have heard some say 140 fork feels more acceptable than 150 in stiffness with fox 32.
    [QUOTE=akiracornell;9460999Go do an xc race on his bike then yours. The overall pedaling effeciency of your bike will eventially become more evident. .[/QUOTE]
    Go ride uphill together for an hour or so and see who's bike works better....
    other differences that can attribute to what you are feelings are wheels, tires, axle etc. but you are right, going with a 720 bar and a 70mm stem will help.
    another thing - the same characteristics about the reign that you are talking about are the ones that make ripping through tight singletrack more burdensome. I'm not saying that it cannot be done, just that my statement above holds true in its entirety. the blur lt with a 150 fork should be a trail killer. I'd embrace the positive traits about that bike.
    As an experiment, trade bikes with your friend for a few weeks and go ride different types of trails. If you end up wanting that "plow through everything and hold on for the ride" type bike, get a used Nomad or other 160mm AM bike.
    The 32 150 is a noodle. They pushed the chasis too far with that much travel. It just wont track a line through the rough. My lt2 is soooo much better since i put a 36 float lowered to 150 on the front, went from 90 to 70mm stem and put on some enve carbon dh bars trimmed to 740mm. My 2 cents.
    Quote Originally Posted by Gravitythief76 View Post
    I beg to differ, at least with a Revelation 150mm on the new 2012 Blur. I just ran mine down some serious rock gardens at speed and off several jumps and it tracks like an arrow. I'd for sure run a F36 if I was doing dedicated downhill runs, but I'd rather stick with the lighter fork for general use.
    Quote Originally Posted by TwoHeadsBrewing View Post
    It really depends on the rider. If found even the Lyrik to be a flexy flier. Of course, the NomadC is my XC bike
    "It looks flexy"
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Maestro compared to VPP is really like night and day.....
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Mar 2011
    Quote Originally Posted by Zachariah View Post
    Night and day in what sense?
    Theres much less difference between vpp and maestro than there is between a float shock and a good coil.
    Reputation: Surfas's Avatar
    I think this BLT rides great
    <iframe src="http://player.vimeo.com/video/44807594?title=0&amp;portrait=0" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/44807594">Here Come The Boys, Ft Joel Moore & Chris Kenward</a> from <a href="http://vimeo.com/eyesdownfilms">Eyesdown Films</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    One thing, or two that change a lot my BLT was the change 90 to 70mm stem, from hi rise monkeylite to low rise Easton Haven carbon bar
    Quote Originally Posted by Surfas View Post
    Nice vid! My BLT came with a 70mm stem, and I swapped over my Easton Haven 711mm bars. Great combo!
    Reputation: aliikane's Avatar
    I have a Blur LT2 and an Intense 6.6 with similar specs. 6.6 has a Van 36 and RC4 coil and weighs 36ish. The Blur LT2 has RS Revelation Air 150mm and RP23 and weighs 28ish. My 6.6 tracks way better in rocky or rooty chop because of the weight is more stable and the suspension is much more active and better equipped for choppy conditions. The Blur LT2 is pretty light and gets tossed around in really choppy conditions but is awesome in certain technical trail riding. Just different bikes for different conditions.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    How does tire pressure compare? I know my bike is all over the place if I go too high on the pressures
    No moss...
    Quote Originally Posted by One Pivot View Post
    Agreed.
    Again, like many of us stated earlier for you Croscountry you are comparing apples and oranges. Compare the BLT to the Trance and compare the Nomad to the Reign X. Even then you'd still have to compare a coil to coil not air to coil. The BLT will never be as stable or good a descender as the Reign X. Some people have the skill to ride it that well but most do not.
    I moved to a Nomad from a BLT for many of the same reasons you pointed out. The BLT just isn't built with the same kind of riding the AM bikes are. You could go with a 34mm or 36mm fork in 150-160 and that would improve things a lot. Also running wider bars and a shorter stem. But in the end its still just a trailbike trying to be an AM bike.
    I have ridden both the Maestro and the VPP. They both work really well, its really about preference not performance.
    Mar 2011
    Points taken about the coil. I did ride a titus with 36 talas and it was also a stable bike, but it was also huge and heavy. I am thinking its more a head angle handlebars combo.
    is RAD
    Reputation: Van Cuz's Avatar
    Jun 2010
    I have run the new revelations, and some 2011 fox 36's, back to back on the same bike on the same trails and the 36 chassis is noticeably stiffer. The Revs were 20mm axle too.
    I love my Revelations, and they're the fork I kept, but for inspiring confidence the 36's win.
    Ride On
    Reputation: geraldooka's Avatar
    Based in what your describing about the front end I'd say you'd have a dramatic change installing a much wider bar and a much shorter stem. I went from a 680mm to a 780mm bar and from a 100mm to a 60mm stem. Initially thinking I would cut the bars down to size... They're staying as is! It has made city travel more awkward but trail riding is awesome!
    Cheers,
    M
    Sent from my MB860 using Tapatalk 2
    Michael
    Ride on!
    Whoops...wrong thread!
    Feb 2012
    Sounds like this isn't about suspension and travel as much as about seating position.
    I agree about trying a shorter stem (50/60mm) and a wider bar (720mm at least) as the 1st thing, and making sure the bars aren't much lower than the seat (bar rise, stem angle, headset spacers).
    Tire width and pressures are next, make sure you run just enough pressure on the front that the tire doesn't collapse during hard leaning over on flat turns.
    Next, you can play with your seat postition - maybe move the seat a few mm forward.
    Sag - make sure you run enough. You can tune the effective angles to a certain extent by e.g. running a bit more sag in the rear and a bit less on the front (within limits).
    I wouldn't go changing forks or the whole bike before you have tried these cheap options - maybe you can even borrow a bar & stem for a day.
