    Reputation: Udrija's Avatar
    Wheelset for my size
    I know this isnt probably in the right forum but I trust you guys here in the all mountain forum. I'm 6 feet tall aprox. 255 pounds and am looking for a good all mountain wheel set. I've been trying to do research on wheelsets but just cant find any good info. I also ride a HT Diamondback response comp 06 with sun ditchwitch double wall rims. I'm looking for any and all suggestions.
    MK_
    MK_ is offline
    carpe maņana
    Reputation: MK_'s Avatar
    Quote Originally Posted by Udrija
    Definatelly strong rims. The true strength of the wheel comes from how it is built. 36 vs 32 spokes helps too. If the wheels are still fairly new, I would take them to a local bike shop which builds good wheels and have them tension and true them properly. They should last after that. The rims are definately up to the task.
    _MK
    Before you diagnose yourself with depression or low self-esteem, first make sure that you are not just surrounded by a*holes
    sounds good I wasnt sure if these rims were going to be that great because they are stock rims but I guess stock parts can be good as well
    MK_
    MK_ is offline
    carpe maņana
    The stock parts which tend to be crappy are hubs, headsets and suspension elements, brakes. This is where the companies can cut the most cost. Low end derailleurs like Deore and LX, are far from crappy, they're just kinda heavy, but they function just fine.
    _MK
