Well what do you know. I bought the Pro about a year ago off my neighbour, he told me it was a 2004, just been on the Specalized website and found it's a 2005 model.
Stumpjumper FSR Comp 2007
FRAME - FSR M5 manipulated alloy frame
REAR SHOCK - Fox Triad, custom on-the-fly 3-position
FORK - Fox Float 120 RL,
BRAKEs - Avid Juicy 5, hydraulic disc
FRONT DERAILLEUR - Shimano M581 LX
REAR DERAILLEUR - SRAM X-9, 9-speed, long cage
SHIFT LEVERS - SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL - Shimano HG50, 9-speed, 11/34t
CHAIN - SRAM PC-951 w /Power Link
CRANKSET - Truvativ Stylo, 2pc crank/BB
CHAINRINGS - 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
BOTTOM BRACKET - Truvativ GXP, sealed outboard cartridge bearing
PEDALS - Shimano M-520 SPD
RIMS - DT custom for Specialized X430, 24mm w/eyelets, 32h
FRONT HUB - Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB - Shimano M-525 disc, 32h, alloy Q
Stumpjumper FSR Pro Disc 2005
FRAME - FSR technology, M4 Manipulated Alloy frame
REAR SHOCK - Fox Float Septune. Custom on-the-fly seven position adjustable
FORK - Manitou Minute 1, 100-130mm travel
BRAKES - Shimano M-765 XT hyd disc, metallic pads, 6� XT Rotor
BRAKE LEVERS - Shimano M-765 XT hydraulic disc with integrated shifters
FRONT DERAILLEUR - Shimano M-760 XT, 34.9mm clamp, bottom pull
REAR DERAILLEUR - Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS - Shimano M-760 XT, STI integrated shifter/lever combo
CASSETTE - Shimano M-760 XT, 9-speed, 11x34t
CHAIN - Shimano HG-73
CRANKSET - Shimano M-760 XT Hollow Tech II, 2-piece crank/BB
CHAINRINGS - Shimano 44Ax32Ax22A, 4mm thick outer, 4-bolt 104/64mm,
BOTTOM BRACKET - Shimano M-760 XT, Integrated with crank
PEDALS - Shimano 520 SPD
RIMS - Mavic XC717 disc, 26�, black, welded seam, eyelets
FRONT HUB - Specialized Stout disc, 32 hole, sealed cartridge bearings
REAR HUB - Shimano M-756 XT, 32 hole, alloy Q/R
