Results 1 to 36 of 36
    Reputation: El Cheap0's Avatar
    Mar 2013
    What type of MTB should I get?
    I had a Walmart 26er that had dual suspension, weighed about 42 lb.s, brakes didn't work (mechanical disk on both wheels), and wheel bent on a tiny little crash. I sold it for $80 and need a new bike.
    I am fine with a SS or any number of gears, hardtail or dual suspension. No rigids. If I get a hard tail, I would prefer it to have at least 150 mm travel. Obviously, since I'm posting this in the All Mountain forums, I want an all mtn bike. I don't care what brand it is, it can even be a Mongoose, it just has to ride well and not be as heavy as I am.
    I have been looking on Craigslist for the past 5 months and have only found about 6 bikes that would work for me, but had too big of a frame, too old, or just 100 mm hardtail. What works for me is: under $600 used or new, newer than the year 2000, also my wants in the above paragraph. I haven't ridden for 3 months and would like to get back to riding ASAP.
    If you know of a bike that goes along with my criteria and, preferably, have ridden it, please reply to let me know! All thoughts are welcome. Thank you very much!
    Reputation: hardtailrider2013's Avatar
    Jun 2013
    First, you probably won't be able to find a 150 mm fork for under 600$ at this price go used! I suggest a Kona Mahuna it's a great bike for his price but it's not a AM.. And if you realy want an AM bike you will need to spend a little extra!
    Mar 2013
    Do bike shops sell used bikes as well as new? Besides Craigslist, eBay, and pink bikes, are there other web sites like these that sell bikes?
    Reputation: charging_rhinos's Avatar
    Yes, bike shops often sell used bikes. But when a new 150mm fork costs upwards of $900 alone, you are going to have a very hard time finding a decent AM bike, even a gently used one, for $600. Usually, MTBR frequenters seem to encourage people to save up at least $1000 for a used bike, and somewhere around double that for a new bike. Those numbers are flexible, but they are a good general guideline. I know that's not what you want to hear, but that would be my advice. Save up a little more money, and then your options will be MUCH better.
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Jun 2013
    +1 rhinos
    Keep an eye out for a 2008 or newer Santa Cruz heckler or nickel/butcher. They're selling a bit cheaper because they are being blown out on SC website. You're still going to have to drop about a grand though. Maybe $1200. Keep eating Ramen and saving up.
    Reputation: masterofnone's Avatar
    Finding a hardtail with a 150mm travel fork is very unusual, and if you find a used bike that's had one swapped on be suspicious. Many hardtails are not designed for a fork this big and may be susceptible to frame failure if not properly reinforced around the head tube. The front end would probably ride really high unless the geometry was compensated for and at full compression may cause the handling to go wonky at the worst times. The max is typically 5 inches or less, which for a HT is more than enough. It sounds like you're a candidate for FS. Save up, you'll be happier if you can spend a little more.
    To appreciate the flowers you must also walk among s**t to know the difference
    Mar 2013
    I've researched a little more about what kind of trails I ride and how much 150 travel really is, so I think that 120 mm HT would be OK, but my minimum. I also have some gel shock absorbing gloves and they work well, so those w/ a 120 travel hardtail, I would be fine.
    Thanks for all the info and thoughts! I'm relatively a newbie to MTBing, so I only know a little.
    Oct 2010
    If new to mtb why not just go for the typical trail bike to learn with and move up as you go??
    Mar 2013
    Quote Originally Posted by 93civEJ1 View Post
    Well I know enough of what I want to wisely decide on how to blow $600 and I learned quite a bit from that great Walmart experience, but because of my limited experience, I'm asking, If that's alright with you.
    Reputation: bigfruits's Avatar
    Mar 2011
    dont be a dick, he was making a suggestion that you should actually consider.
    youre going to get 150mm of crap with $600. dip into your kid's college savings or sell meth for a while.
    Reputation: sagitt77's Avatar
    Oct 2010
    I think 100mm fork should be enough for you, especially in 29-er. Work of fork depends mainly on settings. It's is rather impossible to buy a new full suspension bike for 600$, but you can buy basic new hardtail. Did you check here: Complete Bikes > Cross-Country Mountain Bikes | Jenson USA Online Bike Shop ??
    Mar 2013
    How good are older bikes? This is a Giant, from I think 1999 (same pic. On bikepedia), and msrp is $1,200. I don't think it weighs a ton, at least not the 2000 model.
    Giant XtC DS2 Mountain bike (full suspension)
    Older bike tech isn't the problem. The problem is that aluminum has a certain life span and due to fatigue will eventually crack. Could be decades, could be only a few years. But chances are that the older the bike, the more its been ridden and the closer it is to the end of its useful life. Just be cautious when buying used bikes.
    Mar 2013
    Quote Originally Posted by mnigro View Post
    So is $350 worth this bike? Because I am on a budget, but don't want some heavy, broken thing.
    Reputation: nauc's Avatar
    you can buy an AM frame for $550. a full bike?, good luck
    Santa Cruz Bicycles
    most AM bikes are $2k+, unless its a HT, and theres not many of those
    Pinkbike would have some sub-1000$ options shipped. You could probably get a low end Blur LT or Trance X for 700-900 before shipping. Thats likely your best bet. At 600$ you should be looking at hardtails. I'd save a bit more money, honestly.
    For hardtails you could go older, but for full suspension, I'd aim for something from 2006 or later. Lots of suspension improvement happened by then.
    Mar 2013
    Are custom bikes something to be afraid of? It looks like what I want, but This guy broke the rear derrailuer and bent front wheel. Its up for $300, but how much would I have to put in to fix it (considering I would use decent parts)?
    The link's here: Full Suspension Custom build
    Clueless genius
    Quote Originally Posted by El Cheap0 View Post
    Almost every used bike on the market is a "custom" build. Most people throw the term around to make their bike seem more impressive than it is. In that person's case...that's not much of a custom built bike. He swapped out a few small things, which everyone does, but I wouldn't call it custom. It looks to me like a Giant Yukon FX, which is an alright bike. It's does not have 6.5" of suspension travel. That is the shock length. It is a 100mm travel bike, and an entry level FS. Bad? No, but very entry level. I personally would pass on it. It will be heavy, it will need a fair bit of work to get to 100%, and it wouldn't be worth your money. Get a hardtail, it will teach you better bike handling skills as you start, be more durable, be better bang for your buck, and will be far cheaper to maintain. I'm seeing plenty of good upper entry level hardtails in your pricerange. Tell us your size too, that will be very helpful! And good luck!
    1994 Cannondale M400 2017 Felt Surplus 30
    1997 Marin Point Reyes 2013 Pivot Mach 5.7
    Are you in the Atlanta area???
    Clueless genius
    No, I do not live in Atlanta, but I did look through your city's craigslist! And remember, you can always haggle with people. And it's hard to help someone find a bike without knowing their height so the size of bike needed can be determined.
    I also would like to reccomend some reading material: MY GUIDE: Buying 2nd Hand - What You Should Look For - Pinkbike Forum
    I meant the OP, is he in Atlanta? LOL. he posted a Craigslist ad from ATL and I was curious if he wanted some local help. I live in atlanta.
    Aug 2013
    I recommend getting a +-3 to 5 yr old trail bike. One that was pretty damn good when new. Something like a Giant Trance, Specialised stumpjumer, Santa Cruz Heckler. People will be asking around a grand for said bikes, but you can often bargain them down - particularly if the bikes have average components - i.e. trance 4 as opposed to trance 1.
    Make sure the bike is in good working condition. No squeaks etc and that the fork is smooth and has been regularly serviced. If the fame is dialed and the fork in good condition, you can upgrade the components when you get the cash. On that budget, you do not want fork/frame failure as it could cost as much as the price you paid for the bike to replace it.
    Happy hunting.
    Reputation: ride the biscuit's Avatar
    hey El Cheapo, admittedly most of us have spent way more than $600 on our bikes so we it is understandable that we recommend to save up 1000
    however, if you are patient and diligent in your search you can probably get a solid ride
    check this thread out from a few weeks back and take heart: Which Specialized Enduro?
    we helped find that guy an unbelievably nice bike for $800. the used market is so flush with nice bikes right now. basically pinkbike is your one stop shop. happy hunting and people here will help narrow down any specific options you find so post up
    Quote Originally Posted by masterofnone View Post
    i get your point about the intended geometry, but overall that statement isnt really true anymore
    2005 Specialized Stumpjumper HT Disc All-Mountain Build - Pinkbike thats pretty close at 140...didnt read full add but looks fine at a glance
    i saw plenty of hardtails with 150-160 mm forks doing a simple search. a lot of them were local pickup in canada only but point is theyre out there and can be had for much less that 1000. now you may end up needing to replace some worn out stuff fairly soon but still it is totally poss to find a decent riding bike in your budget
    Mar 2013
    Quote Originally Posted by Spykr View Post
    My frame size is 18.5, but I guess 18-19 would be fine as well.
    Mar 2013
    I wouldn't mind a single speeder, (but then again I haven't even ridden one ever), but how is this 1x1 Surly? It has 115 mm fork and it's for $550, but on surlybikes.com it's $500 for a rigid. Is this an alright bike?
    Surly single speed
    Jun 2013
    Surly single speed
    Looks pretty good to me if you are going to be riding XC this is a really good starting bike! I don't know much about the frame, but the fork is great, and the bike has some great components, and you can always upgrade it if you want!
    Hit it first, then we can see where to put the landing.
    Mar 2013
    I also saw this higher end mongoose: Full Suspension Mtn Bike
    Its dual suspension, a little heavy, hydr. disc, and $300.
    I like that this is full susp., but the 115mm surly would be fine as well. The surly is a lot lighter, which I like a lot, and I don't have a preference of SS to mongoose's 27 gears. And as my name implies, I don't want to spend a lot if I can get a good bike for cheaper.
    Between this Mongoose and the 1x1 Surly I asked about above, which one would you guys rather get?
    Jun 2013
    I would get the Surly, the Mongoose is just too old and heavy, if you want to do XC get the Surly.
    Reputation: MSU Alum's Avatar
    You need to focus. Single speed, 150 mm fork hardtail, 14 year old full suspension....take a deeeep breath, go to an LBS and pick their brains about the local trails, your level of experience and what would work in your area.
    Jun 2013
    Or re-think your budget :P for just under 1000$ you could get a pretty good used full suspension cross country bike like the Giant Anthem, you will save alot of time and maybe frustration! That's what I did, I didn't want to spend more then 500$ for a bike, and 6 months later I'm LOVING the sport and I'm looking for a bike in the 1800$ range! :P Wish I would have done that before I bought my 500$ bike, and if you get a used 900$ bike and don't like the sport after a couple months you can sell around the same price, so no big deal!
    Reputation: lotusdriver's Avatar
    Sep 2013
    It also depends on the type of riding you are planning to do.
    I came back to mountain biking this year and started with a hardtail. Soon however l realised l wanted a full susser and sold it after four months.
    Fortunately l did not lose much, as l had bought it on end of year offer.
    Reputation: traffic002's Avatar
    Dec 2008
    Quote Originally Posted by lotusdriver View Post
    +1 on realizing what type of riding you will be doing. I don't recall any trails that required an AM bike when I rode there. I rode my sister's Giant entry level hardtail and did just fine. Sure, a trail FS bike would be the best for a new rider. But I would think an AM bike is almost overkill.
    I'm helping a new rider to the PNW. He's on a XC race FS bike. I've been working on adjusting the fit to be a little more relaxed and basically working on the basics. In the time I've met him, he's picked up a couple used AM/FR bikes. I was like, "what the hell are you going to do with these???" It takes a certain amount of skill to ride the aggressive trails and if you ride slow and your timing is off, you can get into a lot of trouble. Don't waste your money on finding a bargain or something you can afford. You could just be throwing that money away rather than saving up for something a little nicer but better suited.
    So I helped him pick out a 2005 Cannondale Prophet. 130mm single pivot FS bike with a LEFTY max. Since he's small, he was able to find a bike for pretty cheap ($650). Size medium and large go for $800 and $1000 even if it is over 5yrs old (I think they ran till 2007).
    But I consider it to have very advanced technology for the times. They are very basic but solid engineered frames. The simplicity makes it relatively easy to maintain.
    Do the maintenance, ride the spit out of it. Get a real feel for what you like and don't like. Then upgrade when the time comes to something different or a newer version of the same bike.
    Just get out and ride!
    Mar 2013
    I finally found a decent full squish for my price. 2012 giant yukon fx (heres the link- Yukon FX (2012) - Bikes | Giant Bicycles | United States). it was on craigslist for $550, i met the seller at a bike shop to get it checked out, it was like new, seller never rode it off road, bought it in May for around $1100, so I'm pretty ecstatic! can't wait to really start riding again!
    Thanks for everyones help and suggestions, helped me think through it a bit more.
    Sep 2013
    Superb! Always nice to get a bargain.
    Looks a great bike for the money.
  1. E-Type
    By NightOWL in forum Yeti
    Last Post: 06-23-2013, 05:20 AM
  2. X7 vs X9 type 2 RD
    By beater32 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-16-2013, 02:58 PM
  3. Wear rate on your Clutch type or Type 2's jockey wheels
    By jasonwfreak in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2013, 11:17 AM
  4. What type of cog to buy
    By attomixt in forum Singlespeed
    Last Post: 06-03-2011, 08:49 PM
  5. E-type
    By thomas20 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-23-2011, 08:21 AM
