Results 1 to 34 of 34
    Reputation: innovator8's Avatar
    What pressures are you running on your Conti Trail king UST?
    So I have had these tires, Black Chili compound for a short time now running full UST with some pretty narrow, (19mm internal) older Mavic crossmax wheels.
    I have been airing down little by little just to see how much I can push the grip.
    I bombed down some local trails the other day, (Midtown and Crazy Ivan) and when I got home, found that my front tire had only 13.5psi!
    I really love these tires and I know that 13.5 I likely wont do again, but I did not feel any rim contact with the ground, even on decent sized drops.
    I also could not lock up or slide the front wheel even while breaking on steep, loose trail switchbacks.
    I plan to likely run the back around 25ish and the front around 20psi.
    They really do hook up and come alive with the lower pressures and with my narrower wheels and the sidewall thickness and height, I don't see an issues with it.
    Maybe when I ride a trail like Preston, that is really rocky, I'll add a bit more air.
    Your thoughts?
    I had a 2.2 UST on the rear running at 28psi. Rims were originally Mavic EN321 (21mm internal) in ghetto tubeless and then switched to WTB i23 (23mm internal) with rim tape. I'm about 240lbs kitted up.
    I did try lower with the Mavic rims, but found the sidewalls would fold in.
    I love TK2.4 ust and mavic rims (crossmax sx 21mm wide) but would burp on big hits if I was lower than about 25 psi. So I'd run them at 28-30 to play it safe
    Huffy Rider
    Reputation: motochick's Avatar
    Jun 2010
    2.2 on 21 internal, 155lbs kitted, 24/25 lbs. No squirming, no burbs.
    Hubby ran 2.2 on 19 internal, 185lbs kitted, 28 lbs or he would burb. Now he has a 23 inner but only has 3 rides on them so the pressure is still being tested.
    Brenda
    Where'd you get them?!?!
    Get what?
    Quote Originally Posted by innovator8 View Post
    Get what?
    I forgot I wasn't in a 29er forum. Still waiting to get the Black Chili Trail Kings for wagon wheels.
    Reputation: Fuglio's Avatar
    I had a trail king 2.4 on a spank stiffy 40mm rim that pinch flatted (through the tire) at around 20-25. Swithced it to the back with a tube and it stayed at 40psi till i switched it. I weigh 180 gearded up and aboit 160-165 without..
    I love hard tires... .
    Some people lower psi as much as they can without it being squirmy
    Not me i put as much air in with out it getting crazy on the rocks, deflection wise
    I was just about to start a thread for the same reason. what size tk Op? I just got a 2.4 used on ebay. not sure if its ust. its not labeled protection or anything. its is so huge I kinda tripped out once I mounted it. so I was kinda curious where to start with this thing. im 190 without gear and I ran a minion 2.5 at 20 and it didn't seem to fold over at all. im thinking I could probably get away with 20-25 on this balloon. 13.5! what do you weight?
    I'm with stupid
    Reputation: hitechredneck's Avatar
    I run 30 rear 2.2 on a croxxmax 19mm wheel and 22psi front on the older XT wheels 27mm worked great on the front at low pressure the back would fold over pretty good and feel strange.
    Reputation: bionicman's Avatar
    89psi...
    Quote Originally Posted by bionicman View Post
    89psi...
    hows compliance and grip? I was thinking of doing that to lessen rolling resistance.
    Re: What pressures are you running on your Conti Trail king UST?
    Quote Originally Posted by akiracornell View Post
    So I have a 2.4just on the front and a 2.2 non just on the rear.
    I weigh like 182 naked, likely close to 200 with all my dumb shit on.
    I love the fat ass 2.4 in front. I ride a 2011 enduro. I'm going to a lift access park tomorrow, I'm starting out with 21psi front and 25 rear. Can't wait!
    I also wear spandex & a roadie helmet for less resistance..
    Huffy Rider
    Jun 2010
    21 seems kinda low. I run a 2.4 on my DH bike and it works best at 24/25. Much lower and it squirms when pushing hard into corners.
    meow meow
    Reputation: b-kul's Avatar
    2.2 on sun charger tubeless, i still run about 30psi 3v3n though i am 150. i like my tires pretty firm.
    meow meow
    sorry, didnt notice the ust part, mine are non ust.
    Reputation: fizzywater's Avatar
    My rear is TK 2.2 and I run it at 25 psi on a Bonty Duster rim (22mm inner width). I am around 160 lbs riding weight.
    Few things to consider....riding style, inner rim width can make a big difference as to what pressure feels right (i.e. can go silly low on my 25.4mm wide Flow EX...18 psi with Specy Clutch 2.3 2bliss). Not to mention accuracy of the pump gauge. The gauge on my floor pump is pretty much useless. I use it as a rough guideline, but there is easily a 5-15 psi difference when I attach my digital air gauge. So keep that in mind...highly likely that all the psi numbers that are being mentioned here are not an apples to apples comparison.
    meow meow
    ^thats true, i use the gauge to guess but ultimatley use the squeeze test.
    I rode Stevens pass today, very bumpy and lots of opportunities for sharp rock impacts, I started out with 21 front and 25 rear, after a few laps, went to 23 in front, I still was gripping great, and less worried about renting my rim. After 41 miles at bike park, I still have many off my little rubber sprue thingies. These tires seem to be the best of both worlds, grip and longevity...
    OK, so I had my first Burp on the rear 2.2 non ust last night.
    I was running around 28psi and really railing corners on a trail called VooDoo Child at Duthie Hill.
    I was consistently sliding my rear around the corners, and bragging to my buds that these tires will often slide just a but then re-grab and stick. Sure enough, I ended up burping in one of the corners and lost about a third of my air.
    the tire had an awful wobble to it and I had to walk it down the rest of the trail as it was hitting my frame.
    I tried to let some air out but i could not get rid of the wobble. The bead was seated evenly all the way around as I could see the little line around the circumference indicating so.
    What happened was the bead broke, one side of the tire rotated slightly then the stans did its job and resealed the tire.
    I had to break the bead and just put a tube in it.
    I think I am just going to run a tube in this one as it is the non ust and I have a whistler trip coming up in a week and a half and don't want to muck with it.
    I have heard of others burping and they just put more air in and they are fine.
    Just an update, I still love the tires and intend to use them going foreword.
    Jun 2012
    I run the non-UST, BC compound, TK 2.4, on Flow EX's at 26psi front and rear, tubeless with Stans. I haven't had any issues with burping or pinching even plowing through some gnarly rock gardens. I've run them down to 24psi but I didn't like how they felt that low.
    Huffy Rider
    Jun 2010
    NON UST and UST are two different tires, made of two different compounds in two different countries. Next.
    Jun 2012
    That may be the case with CURRENT production tires but the ones I have are Black Chili, Handmade in Germany, Apex sidewall versions. This version has been discontinued and replaced by one with the ProTection + Apex sidewall. Next.
    Next...
    Both tires are black chili made in Germany.
    I agree that the tires are different, beefier and non porous sidewalls in addition to a more standardized UST bead are the main diffs between my two tires.
    My plan is to keep the tube in the rear till it wears out and get the UST 2.2 to replace it.
    Also, I am making things more difficult as my wheels are mavic crossmax almost 10 years old and the internal width is pretty narrow my today's standards at 19mm.
    Quote Originally Posted by motochick View Post
    Ok, so I fear something awful happened, I was going a bit crazy with low tire pressures and I burped the front a bit and wound up with a bit of a wobble. It was on the way out of the trails for the day and it wasn't rubbing so I rode it back to the car to fix it later.
    I figured I could just break the bead and reset it and it will be good.
    I tried it last night three times with soapy water and I still have the wobble, maybe not quite as bad but it's still there. The bread indicator seems to be pretty consistent around the wheel.
    Has anyone gotten a permawobble in a ust tire? Or any tire for that matter.
    Thanks,
    Jeff
    Sent from my SGH-T999 using Tapatalk
    Reputation: crank1979's Avatar
    Feb 2006
    I've had the wobble with a brand new tyre. The tyre was replaced under warranty.
    Big Test Icycles
    Reputation: Hangtime's Avatar
    I got the wobble. Running a mavic 819 and Conti X King 2.2. Psi was to low and after a massive burp the tire seemed to stretch in that area and is disfigured to this day. I have also lost a 2.4 Rubber Queen on the same rims. Burped and completely came off the rim. I'm currently looking at new rims. Very interested in the WTB i23 for the rear and i25 up front.
    I bought a new tk 2.2 protection. The side wall didn't appear like standard rubber. I mounted it and and soon later realized I didn't seat the bead. I added almost 60 lbs to get it to seat .. a few days later I went to ride it for the first time and it had a halacious wobble. I took it back to my shop and he warrentied with the distibutor. It definatly has somthing to do with tpi sidewall casing. I think if it stretches too much it ruins the thread or rubber or both. My guess is it may have something to do with making the black chili compound layering. So far its a design flaw in what is great tread , rubber compound, and casing sized tire. If you really like the tire I suppose maintain a minimum pressure is a precation.
    Yea, from now on, no less than 20psi front, and a bit more on faster, bermier stuff. I've had it for 3 months, bought from Amazon. I sent conti an email asking for warranty, we will see.
    Reputation: wilsonblur's Avatar
    Did you use any kind of soap or liquid to help the tire seat? I discovered with mine that if I sprayed the bead and rim prior to inflation they snapped in much quicker. I have heard several people having the same issue as you had but continuing to inflate the tire when the bead isn't seating and it deforms the casing if you go over 50psi.
    I run 24 in the front and 25 in the rear on my 2.4's tubeless ready protections. My pump was 10psi high and didn't realized it meaning I only had about 14 in them and pinched the casing cutting it on one of our rockiest trails. So I agree, don't go under 20psi. The are my favorite tires. I tried the Han's Dampf's as replacements and they are a little better cornering but every where else they are inferior. Especially in the wear department. I wish the TK's had a 2.3" size.
    Narrow is the path to life, few are those who find it.
    Reputation: BigHit-Maniac's Avatar
    I run my UST Trail Kings at approx 20 psi front, and 25 psi rear.
    I weigh 185lbs w/o clothes or gear.
    I've had zero issues with then on Crankbrothers Cobalt 3 rims.
    You in Oklahoma City? If yes, come ride with us.
    Unfit Norwegian
    Reputation: Dazed's Avatar
    That would actually increase rolling resistance.
    http://www.mtbonline.co.za/downloads...llustrated.pdf
    Quote Originally Posted by Dazed View Post
    That is a great read! Thank you.
  1. Conti Trail King
    By minnanation in forum Wheels and Tires
    Last Post: 04-19-2013, 06:29 PM
  2. Replies: 9
    Last Post: 01-21-2013, 09:06 AM
  3. Conti trail king 26 x 2.2
    By Hutch3637 in forum Wheels and Tires
    Last Post: 10-28-2012, 03:33 AM
  4. 29er Conti Trail King/Mountain King... Anyone?
    By Helmetless in forum 29er Components
    Last Post: 10-15-2012, 02:43 PM
  5. Conti Trail King 2.4 - Not so big?
    By RaptorAddict in forum Wheels and Tires
    Last Post: 07-20-2012, 08:47 AM
