Results 1 to 3 of 3
    Used CB Joplin - Maintenance Questions
    Found a used Joplin post. I think it's an older model. There is no play in the seat clamp assembly itself, or where it attaches to the internal shaft. However there is a considerable amount of play between the lower section of the post, and the shaft itself.
    Is this normal ?
    Can I do the maintenance myself ?
    If anyone who has experience with these CB posts can help out it'd be much appreciated.
    how heavy are you ??
    Reputation: Scottay5150's Avatar
    Call CB. They can probably rebuild it.... It's CB, why did you buy used?
    Sent from my DROID SPYDER using Tapatalk 2
    What does Marsellus Wallace look like, A BIT*H?
    Reputation: darkslide18's Avatar
    Quote Originally Posted by phoenixbikes View Post
    Is this normal ?
    Yes, this normal and was one of the huge complaints with the Joplin. Mine did it. As long as it is operating good, ride and have fun. You don't really notice the play that much in the saddle anyways.
