Results 1 to 5 of 5
    Upset HELP NEEDED BADLY!!! Can't ride: Terrible noise and no power on older Saint
    - I just posted this on brake time forum but as I'm in such a distress I'm spreading ti here as well, so sorry for that -
    SO my front brake - older Saint - is making noise so bad I don't want to go riding. So that's pretty bad! It's not the usual disc brake noise. it's something much louder. It also doesn't brake well. My rear brake is as silent and as powerful as it should and I love it.
    The weird part is I have changed the pads and the rotor and have re tightened the caliper many times so the position would be correct/different.
    One thing I haven't tried though is to try another wheel with the same rotor..
    But if it's not the pads, rotor or wrong position of the caliper what could it possibly be?!? Anybody had or heard about similar issues with disc brakes or specifically with the older Saint model?
    Hope i can fix this soon as I really love the brake when it works and I want to go riding... NOW!!!
    Reputation: ride the biscuit's Avatar
    Did you try bleeding it?
    Without hearing the noise and looking at it, this is going to be difficult to diagnose over the internet.
    Describe in more detail what you've done so far. How did you alighn your calipers?
    My hunch is that its something with your specific setup rather than something common to old saints, but that's just a guess
    Actually, I think a seal in your caliper is leaking brake fluid on your pad and rotor. You should either rebuild your caliper or replace it
    Can you see a leak near the piston?
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Contaminated pads and rotor, possibly from a caliper seal leak or line leak. Could also be external contamination like lube overspray or riding through a contaminated puddle. That happened a lot in PA where the dirt bikes were out.
    New pads (or the sometimes effective "baking" of pads) and a rotor cleaning is in order once you figure out where the contamination came from. Lots of advice can be found on how to do these things.
    are you sure the wheel is mounted right and spinning true? I've had some awesome sounds from my rear brake before when I didn't get the axle seated correctly so the rotor was scrubbing the caliper.
    2013 Trek/Gary Fisher Rumblefish Elite XXL/23"
    120mm 29er
    2004 Santa Cruz Bullitt XL White
    170mm 26er
  1. Replies: 0
    Last Post: 03-21-2013, 01:34 AM
  2. oh noise in older XTR system
    By Julie in forum Brake Time
    Last Post: 01-02-2013, 07:51 PM
  3. Replies: 179
    Last Post: 12-20-2012, 07:39 PM
  4. brake pad noise/low power debug
    By cjcrawford in forum Brake Time
    Last Post: 10-08-2011, 08:46 AM
  5. Race Face X-type BB making terrible grinding noise
    By Varaxis in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-06-2011, 12:51 AM
