Results 1 to 7 of 7
    Upgrading Montague X50 Bike 16" Frame...
    i have a budget of $600-$700....
    what should i get to upgrade this bike...?
    Also post links to the parts if possible...
    I plan to do trails/parts/gravel and some city biking...
    Stock Specs:
    Specifications
    Color Gloss Black
    Frame = Custom drawn 7005 Series Aluminum with FIT System. Power Angle geometry.
    Fork= SR Suntour. Suspension XCT V2. 80mm travel. Alloy one piece lower. Disc Compatible.
    Rims = Alex. Alloy, 36 hole.
    Tires Kenda. Knobby. Front and Rear Specific. 26 x 1.95”.
    Hubset= Sealed front & rear with CLIX™ front quick release.
    Spokes= 14 Gage
    Saddle= Performance comfort with Springs and “Center Gap”.
    Seatpost= 27.2 X 300mm.
    Handlebars= 30mm rise.
    Stem= Kalloy UNO, quill type, height adjustable.
    Shifters= Sram Twist Shifters.
    Front Derailleur= Top Pull.
    Rear Derailleur= Shimano Tourney.
    Crankset= 42/34/24. 170mm crank arm. Black.
    Speeds= 18
    Brakeset= Alloy V-Brake. Alloy Levers.
    Pedals= Resin Black Body.
    Bottom Bracket= Sealed Cartridge
    Reputation: fotu's Avatar
    Jan 2005
    I would upgrade to a different bike. Personally, I would rather have eurospek's kona kula with a tune-up than a montague with $600 worth of upgrades.
    Full Size Folder
    Oct 2012
    I just completed my x50 upgrade. Like you, I intentionally bought the x50 so I could strip it down to the frame and then build it up. This is an old post, so I figure you already made all of the purchases you wanted to make, but here's a parts list of everything I put on my bike:
    - Rock Shox XC 30 TK
    - Crank Brothers Iodine Headset
    - Kore Stem and Flat Bar
    - Crank Brothers Iodine Grips
    - Shimano Hone M600 Dual Control Shifter / Brakes
    - Shimano Deore M591 Rear Derailleur
    - Shimano Deore M590 Front Derailleur
    - Shimano M430 Crank (22-32-44T, 170mm)
    - Shimano BB-ES25 Bottom Bracket
    - Clarks C9 9 Speed Chain
    - Shimano Deore SM-RT61 160mm Rotor
    - Shimano HG61-9 Cassette 11/32
    - AlexRims DP20s
    - Schwalbe Crazy Bobs
    - Shimano 160mm Rotors
    - Specialized Carbon Seatpost
    - Sunlite Folding Pedals
    I configured it for urban riding, but I have a second set of wheels and tires that I put on it for trail riding. Hope this helps!
    Jan 2013
    JRSR / casshern69 how did you mount your rear disc brake caliber? I have a X50 also and would like to upgrade to disc brakes, do you have any advice?
    Full Size Folder
    Oct 2012
    I used an A2Z Universal Adapter and it worked just fine. It was easier than I anticipated. You can find more about them here:
    www.a2zcomponents.com
    Just do a little hunting for the part number and you should be able to find one on eBay or though Google. I did find one on Amazon:
    Amazon.com: A2Z Rear Disc Brake Mount for Tabless Frame, DM-UNI: Sports & Outdoors
    Hope that helps.
    Jan 2013
    How did you route your hydraulic cable in the rear? Do you have pictures?
    Jan 2013
    How did you keep the Adapter from rotating? It rotates backwards when Im sitting on a hill with the brakes on.
