Results 1 to 10 of 10
    Jan 2009
    Listen! upgrades for my meta 5.5.3 2009
    hi there!
    i have a meta 5.5.3 2009.
    http://www.evanscycles.com/products/...-bike-ec017320
    i want to make these tweaks:
    1. i want to put a 203 mm disc rotor in the front and take the 185 (that is now in front) and put it in the back brake.
    first off, should i buy a G3 or a G2 rotor? secondly is the 203 mm rotor compatible with the revelation or does it need an adaptor? same for the rotor in the back (185mm)
    2. i want to put a thru axle in the rear wheel to add some stiffness. is it a good thought? does the rear end accept a thru axle? if yes, does the rear hub take a thru axle? if not, could you reccommend a good and cheap hub?
    3. also i'd like to put a chain guide, so i found this:
    http://www.chainreactioncycles.com/M...?ModelID=50905
    does anybody soeen this? does it work?
    thank you! Wink Wink
    Blue Pig
    Reputation: Blksocks's Avatar
    Dec 2009
    If you have, ISCG tabs and it has the, ISCG option, yes. If you don't have, ISCG tabs and see that there is an option for the BB, yes.
    Ragley Blue Pig
    Jan 2009
    it will be fitted in the BB since there are not iscg.
    what about the other stuff?
    Blue Pig
    Dec 2009
    1.) Yes. Both can be done. You will need an adapter for the front and back. If you don't already have them. Rev. can use max. 203
    G3 rotor(s) is lighter than the G2.
    2.) I think you can use a rear through axle. Someone should be able to chime in on the hub part.
    If you want a chain guide. Don't pay that amount of money. Check these out as an example. Blackspire Stinger Chain Guide should work.
    Ragley Blue Pig
    meow meow
    Reputation: b-kul's Avatar
    Quote Originally Posted by Blksocks
    best he can do with that hub if a bolt on not bolt through. this means the axle will be fixed in the hub and clamp on to the drop out using nuts. take the big ring off and you can use a stinger, if you want to stick with a triple though i think the e13 is your only option.
    Jan 2009
    where do i find that axle to make it bolt on on bolt through?
    meow meow
    Quote Originally Posted by sundace
    ideally go to your lbs and have them order you one. wheel manf. makes them. if you want to do it online i got one off of jenson.
    Jan 2009
    how do i search that online?
    Blue Pig
    Dec 2009
    Ragley Blue Pig
    Jan 2009
