Results 1 to 39 of 39
    Tune a XC to be AMish
    Recently dusted off my ol '02 giant NRS Air and have been hitting the trails around houston. Still love the old bike but i don't know if the trails have become more rooty and technical or im just riding harder nowdays, but I've already supermanned once and seem like i have to bail at times I'd rather not, all because of the really low and forward weight bias of this bike. I know that's what it's designed to be, but am thinking I'd like to tune it a bit to handle slightly more technical stuff, but try to maintain it's lightweight responsiveness.
    Things Im considering are:
    -replace long neck with shorter one, bring the bars back maybe an inch or more. Use as an excuse to upgrade to a CF if I can justify it.
    -noticed my seat post has no setback, so replace with a post with at least 1" setback, and use as excuse to upgrade to cf also?
    -replace flat and narrow handlebar with one with some rise and more width, and again use as excuse for CF.
    -maybe put a fatter tire up front, currently running wtb nano 2.1 front and back.
    I've already dropped my seat which has helped a lot, since I don't do much distance riding it works well for running the trails.
    Ground clearance also seems to be becoming an issue, but I think my shock just needs more air to prevent some sag.
    Nor planning to yet, but would a longer fork be a terrible idea? (I'm thinking yes...)
    Any thoughts or input? Am I adulterating a XC to try to make it into something it's not?
    Shorten stem to no lower the 70mm maybe 90mm depending on what u have. Riser bars would help clearing obstacles easier. I guess a setback seat could help to get some more weight behind the rear tire. 2.1's on a XC bike are fine, and maybe upgrade to a nicer fork like say a Reba, or Fox RL all 120mm of course. Or you could just buy a new bike!
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    On the XC spectrum, the NRS is VERY XC. Just ride it how it is. Get a new bike when you can.
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    Yeah the geo just isn't going to be cut out for riding gnar gnar stuff, sorry to tell you. The wider bars won't actually pull your weight back, it'll pull it forward even more; as I found out. You will need to compensate with an even shorter stem, one that your bike wasn't probably designed around. Other geo that will affect your bike handling and descent stability will be the head angle which without looking yours up I would say would be over 70* which for descents isn't the most confidence inspiring. You can make the changes you said, and they may help a little bit, but in the end you'll spend money into your bike and you still won't be confident.
    My .02
    ------__o
    ----_`\<,_
    ---(_)/ (_)
    Reputation: Fix the Spade's Avatar
    The NRS is NOT built for taking hits, so don't try it.
    If you want it to stick to the trail better, some fat-ish 2.3 medium compound tyres will make it hold lines better. A short-ish stem 70-90mm will make it a bit sharper, but leave the rest as is.
    The NRS is a very xc type bike, trying to make it tougher will just leave with a heavy NRS that doesn't handle very well.
    if you're not heavy, go for it. a light person hitting stuff (not doing feeride stuff, but reasonable sized stuff) should be well within XC race design limits i think..
    also if you're still running the original shock, a 100mm reba or similar might work massively better.. i'd give it a go if you're not planning on anything too hardcore.
    Yeah I'm not looking to take big hits, and I probably need to add that I still love this bike in 90% of what I do. It really just comes down to trying to be more stable flying over increasingly rooty trails. The balance of the bike just gets sketchy in these situations and sometimes with the wrong speed and root spacing, it can grab and toss you forward. It feels like a little bit of repositioning could help a lot, but I'm just not sure if this is acceptable or a big no-no
    the modifications you mentioned will definitely make that bike more "AM" and less XC.....I have the same bike and I did the same thing before I got a "real" AM bike.
    My bike was designed around a 80 mm for and I slapped a 100 mm fork and it felt fine....but eventually I moved on to a different bike because I started to injure my wrists from always bottoming out the fork.
    Reputation: Jeff in Bend's Avatar
    Jun 2010
    Shorter stem ( IMO no longer than 70mm), wider bars (28"-30"), dropper seat post, and little longer fork would be ok. These things will make the bike handle better while descending but proper riding position is most important. I would sell the bike and buy something more "all mountain" before I dropped a bunch a $$ in this bike though.
    Bicyclochondriac.
    Quote Originally Posted by boomhauer View Post
    Shorter stem, wider/higher bars, bigger tires all around. Saddle position should stay where it is best for pedaling. Same with saddle height. If you want to drop it for descents, get a quick release seat collar, of if you have the $ to spend, a remote dropper post. What do you mean by "ground clearance"? If it is an issue of your chainrings, think about replacing the big ring with a bash guard.
    These things will make it feel more stable in the rough stuff. Just keep in mind that this is a lightweight xc bike, and not meant for hucking off big drops.
    I would not bother with a bigger fork or wheelset, if you are pushing the limits of the fork and wheels, you are likely also pushing the limits of the frame.
    small member
    try an adjustable fork 85-130mm; Tora U-turn probably the cheapest option
    Reputation: pleepleus's Avatar
    An XC bike is all you need around Houston. Any thing more than 120 mm of travel is over kill. I will agree that the trails at Memorial park have a lot more exposed roots than ten years ago. That is our most used trail system. Try riding Cypresswood or Double Lake, the roots are not nearly as bad.
    Let's not forget the roots of MTB. In the early days the first "free riders" were riding steep tech lines and eventually hitting drops with no suspension, long stems and steep head angles. By today's standards, you're not going to turn an old xc bike into an AM bike with modern AM capabilities, but a good rider could definitely ride a NRS down gnarly trails better than a poor rider on a modern 6" bike. Put the fattest tires you can on that thing, shorten up the stem, drop the saddle, and go ride any trail you want. Of course hucking is not recommended for fear of equipment failure, but riding steep tech won't brake an xc bike.
    Reputation: lew242's Avatar
    I agree, wide tires, shorter stem/wider bars and slam the seat, it is surprising what an XC designed bike can do, particularly for riders who weigh less than 150 pounds (70 KG).
    I have a Trek 4900 frame with a Bomber 100mm fork on the front. I've been bashing the hell out of that thing on Western PA roots and rocks for about 10 years now and it has held up fine. I'm about 150lbs geared up though.
    Reputation: FNG RIDER's Avatar
    I had an NRS back in 2002, good xc bike, mine had 80 mm forks, I measured the true travel to be 1 1/2inches of travel. front and rear. they lied and said it was 3 inches. I added a 115mm fork, but it altered the geometry, not good.
    Gets some trail rated tires for loose over hard and wet. I recommend WTB weirwolfs. 2.1, I don't think the 2.3s will fit. like everyone else said, just ride it and no technicals. BTW with the low bars this bike is scarey on drops and downhills it feel as though you are going head first rather than bike first.
    good luck, I think it's time for new bike!!
    Reputation: el_chupo_'s Avatar
    I am just estimating on pricing here, but..
    CF Stem - $125
    CF Bars - $80
    CF SP - $75
    New tires - $70
    New Fork - $300 +
    So you are talking of getting about $600+ of parts onto your 9 year old XC bike, in order to make it more like a modern trail bike. Why not save that money, keep saving for the rest of the summer, and then toward the end of the year, when the '12 bikes start hitting shelves, find a good deal at your local shop. Something like a Jamis XCT, Specialized Camber, Trek Fuel, ETC, ought to run you between $1000 and $1200. Then sell your old bike, and enjoy the new ride!
    Good luck!
    Bicyclochondriac.
    Quote Originally Posted by kapusta View Post
    One more thing: I would not waste your money on carbon fiber anything on this bike until you KNOW you like the changes and plan on keeping the bike.
    I agree, I wouldn't invest in any nice parts. You can find used parts that will still be an upgrade over 02 parts for super cheap on ebay, pinkbike, etc.. You should be able to find a 70mm stem on ebay for 20 bucks, wider bars 20 bucks.... There are so many deals on used parts it's crazy. No sense in dropping cash on high end parts for an 02 bike when you don't even know if you'll ever be happy with it. QR seat collar is a must if you don't have one! Guys that don't lower their saddle don't know just how bad they are cheating themselves.
    BLAH BLAH
    Im all for trying things but I don't think you guys suggesting stuff have ridden an NRS. It rides like a hard tail XC race bike. Changing the cockpit for comfort is one thing but "tuning it AM" well It just isn't suited for this, ride it like it was meant to be or move on IMO.
    Whats this line for?
    I agree it's not worth spending the money to try and turn a NRS into and AM bike by today's standards, but a good rider could certainly ride a NRS with the best of them as long as we're not talking about drops, gaps etc.. Fatter tires alone even on a full rigid will let a good rider have a go at riding more advanced terrain. I learned to ride steeps, tech, drops, and gaps on a hard tail with 100mm travel fork and 110 stem because that's what I owned and I couldn't afford to buy a better bike suited to my style. Now I have a bling nomad and laugh at what I used to ride on that pos hardtail, but I had no choice back then. If you can't afford a modern AM bike but want to make the bike you own more of an all around type bike, simple things like stem, tires, bars will make a noticeable difference. Of course a NRS will never be a nomad, but changing the build will let an NRS owner ride a grater variety of terrain with more confidence for little money.
    Don't waste your money. It's SUPER geared towards XC and it will never ride like an AM bike. You will end up sinking a whole lot of money into it to find this out.
    update on the NRS
    Sorry didnt realize so many posts on here.
    I need to reiterate - Im not trying to take big drops etc. It's just really rooty trails out ehre and I want to fly over this stuff faster, and part of being faster is not fearing that I'll fly over the bars every time I encounter a root!
    I came back here to update because I had a strange occurrence- my rear shock had apparently been leaking air and was getting softer, which in turn gave me a bit of sag and made the rear a lot floatier. Before I noticed this was happening, I first noticed that the bike was handling the trails friggin great... roots just seemed to float by, and cornering started to get less scary. I figured I was just adapting to it and getting back in the groove.. although it seems like I was starting to hit my pedals on more stuff. then a friend noticed how much I was sagging, and sure enough, on the last ride, i managed to bottom it just doing some simple stuff. Rear shock had lost about half it's pressure in the top (and apparently the bottom doesnt hold air at all). I added the air back before riding today, and it back to scary forward-biased root jarring rides again
    anyway, lesson learned - a floatier ride, and transferring everything rearward a bit made the bike WAY better for these particular trails. So this tells me taller bars etc will help quite a bit, but ultimately I really need something that can float of this terrain a lot better.
    and btw guys, thanks for all the input.
    Yeah although the NRS will take lots of abuse, the rear-shock will definitely limit how far you can go....its supposed to be setup with zero sag, but like you mentioned, having it sag does help it float over the bumps....good luck....
    Also like I mentioned in my earlier post, I tried a 100mm fork but it was not nearly enough for what I was doing with the bike. My next bike had a 140 mm fork and boy could I tell the difference.
    not to go too far off topic but... any thoughts on the anthem x 29er as a replacement? still xc but bigger wheels and a bit more travel sounds well suited... lbs is highly recommending them as a great fit for local stuff.
    Paste eater
    Mar 2006
    It's a great bike, but again very much an XC bike - geo, specs etc... I mean, it's essentially the NRS's replacement.
    If you are truly looking for a little more bike, this ins't it.
    @Boomhauer
    You should definitely trail test the niner to see if it is for you.
    Good for bumps and rollover, if you ride were there are tight switchbacks, burms or whoops, you should ride a niner there first. Some love them, others prefer the 26 or 650. I was very interested in the
    Niner Jet 9 with 120 forks. until I tested it on my favorite trail, felt like a big truck on the switchbacks , fell off of the burms and sluggish on climbs. but thats me. you really should test one first.
    @Boomhauer
    Good for bumps and rollover, logs are not a problem. But if you ride were there are tight switchbacks, burms or whoops, you should ride a niner there first. Some love them, others prefer the 26 or 650. I was very interested in the Niner Jet 9 with 120 forks. until I tested it on my favorite trail, felt like a big truck on the switchbacks , fell off of the burms and sluggish on climbs. but thats just me, You may really like the Niner.
    BTW I test rode a Jamis 650B2, really liked it, didn't like the $5K price tag!! so many choices and so many decisions! hoy!.
    Not sure how you can get this:
    to become this:
    I made alterations to my 1996 carbon fiber hardtail race bike a couple years ago.
    Got rid of the 63mm SID(was no longer serviceable anyways) and replaced with a 100mm Reba ($300 new).
    Got rid of the flat bar and replaced with a cheap steel riser bar ($30 new).
    Got rid of the long stem and replaced with a cheap steel 70mm riser stem ($30 new).
    Got rid of the 2.1 nanoraptors and replaced with DH 2.35 minions ($100).
    I left the saddle just the way it was.
    Loved it right away.
    Love it so much, the cheap bar and stem are still on it.
    So for less than $500 I am riding (and loving it) my old race bike... had I left it in race mode, it'd never come down from it's perch in the garage.
    The bike has so many good memories I was not going to sell it. Had I not made the changes, it would have just sat.
    Click "Soupy" in my signature.
    All mountain bikes are awesome, I'd love to have one, but, I'm riding the same trails on my "souped up" old xc bike... allbeit with much more caution. .
    My bike, Slayer 70
    Omnipotent
    I agree with most of what's been said here about NOT converting... I've got an older XC type frame and I thought about beefing it up as well... NOT a good idea, since the frame itself just isn't modernized, nor designed to handle even occasional big/monster hits and dings often encountered on AM terrain. 1 bad fall/mistake could cost you your bike and possibly a $3000/night stay at the county's finest ICU...
    Just get on CL/Fleabay and bid against the noobs like I'm doing... You'll hit pay-dirt eventually.
    Yeah Im going to test ride my brother's niner (tho hardtail) and see how I like the overall handling.
    the-one1- that looks like exactly what im after. I hear wooden spokes are the rage for rumspringa!
    well guys, I bought a cheap set of (oversize) riser bars and 100mm neck, and tried em out today. good lord these make such a difference. i feel rock solid on my trials now, and dont feel like im about to flip over the front all the time. actually dont feel like im going to lose it in the corners now either (extra leverage seems to stabilize things a lot). I havent finished reprogramming my brain to adjust for the less sensitive steering quite yet, but this bike feels just amazing on the trails now.
    The bars i had on there before were flat and < 22" wide...
    Now to just get all the other small issues worked out and ill be really happy with this setup, for now at least
    btw this is a vid of the trials we most often ride, shot by my brother. inner city houston. http://www.youtube.com/watch?v=JEcN2S0nIVY
    Jan 2011
    I have a 2002 NRS 2 with the Manitou Black 80/100 mm, I run iit on the 100 mm setting all the time and it does great. If those are the trails that you guys ride those are a NRS's wet dream, I would just put a 100mm fork and 2.2 tires on it and call it good
    Reputation: Daemon[CRO]'s Avatar
    Daemon
    "Worship the Machines."
    www.nivas.hr | www.worship.hr
    Freakin Amish Lasers!
    @918 yeah those trails really are good xc, theyd o get a little crazier in other parts. My biggest problem was, the few good drops on them, i couldnt launch at all with my crazy low narrow bars. And, the occasional wrongly spaced roots taking me out (just went over the bars again last week, too old for that!). amazingly the new bar/neck setup feels like a whole new bike, I think it has a new lease on life. Now to see what parts I'll start breaking with my 200 lbs...
  1. my new AMish build
    By saxen in forum All Mountain
    Last Post: 03-07-2011, 01:59 PM
  2. Push - MX Tune or Factory Tune?
    By dulyebr in forum Shocks and Suspension
    Last Post: 12-01-2010, 09:12 PM
  3. Amish on a Surly?
    By treesmasher in forum Surly
    Last Post: 11-23-2010, 10:06 AM
  4. PUSH'ed RP23 - Question on compression tune and rebound tune
    By parkp81 in forum Shocks and Suspension
    Last Post: 10-31-2010, 01:54 PM
