Results 1 to 9 of 9
    mbtr member
    Reputation: scottzg's Avatar
    trouble switching to flats
    I've been riding clipless for a while now, and decided to give flats a try mostly for things like logs and wheelies and drops and other low speed hooliganish stuff. I'm comfortable riding at the same level as with the clipless, but i've run into a few problems that are really killing it for me.
    1) when i have my seat in the 'high enough' position, i clamp it with my thighs when i go over rolling jumps. My feet move an inch or so on the pedals, so i get a little 'yike!' and have to readjust. If i lower the seat then it's not an issue, but thats no good for rolling singletrack.
    2) i seem to have horrible body geometry, or something. i point my toes outward as i pedal, so half my foot isn't supported when im comfortable, while my heals bump the chainstays if i move my feet inward. I have an injury in my left knee, and the left side suffers more. Longer pedal spindles would fix this (i need wider Q factor, right?) Clipless keep my feet aligned.
    3) in fast singletrack, i keep lifting my feet off the pedals at the top of my strokes, especially at high rpm. I figured that would stop as i got used to flats, but it's still happening. When combined with #2, it's really annoying having to constantly readjust my feet..
    I think im gonna go back to clipless, and im a little bummed. Any advice?
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Reputation: jetta_mike's Avatar
    Feb 2007
    What kind of flats are you riding? and what kind of shoes are you wearing?
    I ride with skate shoes on my DH/FR flats and have no foot moving issues.
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    I ride flats, Easton's, but i always recommend riding what is most comfortable for you. You sound like your comfortable with clipless.
    Formotion Products
    http://www.formot
    mbtr member
    I'm riding skate shoes on admittedly crappy flats (hey, they came with the bike) The pins are a cast part of the pedal body. I borrowed a set of old Prime bmx pedals, but it hardly made a difference.
    Do you put the spindle under the ball of your foot or on the inside of your arch? I'd tried both and neither seems ideal.
    Mikhail Kalashnikov
    Jan 2005
    Quote Originally Posted by scottzg
    Quality flats make a huge difference. My top 3 pic's
    1) Easton Flat Boy
    2) Azonic A-Frame
    3) Wellgo B67
    http://www.pricepoint.com/thumb/3-Pa...ntain-True.htm
    Shoes also will help greatly. I have used the 661's for a long time & they are awesome. 5-10's get the best reviews & might be the best choice.
    http://www.pricepoint.com/thumb/1-Cl...ntain-True.htm
    Formotion Products
    http://www.formot
    attending to my vices
    Reputation: moshelove's Avatar
    Jun 2005
    1) good flats make a big difference. I had some redline ones that were all cast and they did not grip that well and wore down. I recently got the Wellgo's and they are sharp as daggers. My feet feel pretty stuck laterally to the pedals. You can also get some 5.10 impact shoes, I have not tried them but if you read the reviews people rave about how sticky they are.
    2) Don't ride like a duck!
    3) This one is pretty simple, you just need time to re-train your feet to apply consistant downward pressure to the pedal. stop trying to pull it up and just keep steady pressure down.
    There is no substitute for proper technique so go get some decent flats with replacable pins and a nice concave shape and put the power down. I dig riding flats and don't think I will go back to my clipless set up again.
    OVER THE LINE SMOKEY!
    Im about to go t flats from stps.
    I've heard from a couple of people that it can take quite a while to adjust.
    One thing someone told me was that your hand position on the bars should be adjusted. More curled over the bar so that you tend to pull your body onto the pedals.
    Jan 2005
    Quote Originally Posted by Sabbah
    You will have to be able to go from spinning circles to mashing, this means sacrificing climbing ability unless your leg's are built like rods & feet pistons.
    Formotion Products
    http://www.formot
    Get Down Do you
    Reputation: Muggsly's Avatar
    Get these and I promise no matter what shoes you are wearing you will grip without issue. Just get some shin guards too.
    Progression is fine just remember to respect your roots.
