Results 1 to 11 of 11
    May 2012
    Trek Fuel EX 5 Fork Upgrade?
    I have a 2011 Trek Fuel EX 5 that has stock forks on it and I want to upgrade to a new fork of 140mm or more and being an air fork. I have been told to get a fox float 32 fork, but know nothing about forks. I want to upgrade to an adjustable fork by air pump. Anybody have any recommendations for upgrading my forks?
    Lots of guys post about wanting to get a new fork and in the process, also want to add more travel. The problem is by adding too much travel you can put added stress on the head tube, the front end can wander on climbs, you jack up the geometry, etc. but if it's within reason you can over fork the bike a little. I'd say a general rule of thumb would be +20mm max. I wouldn't put a 150mm fork on a bike designed around 120mm. It will probably climb like crap and raise the bottom bracket too much
    If you bought the bike new from a trek dealer I would call up a shop and ask them if bumping the travel would void the frame warranty. If so, don't bring your bike into the Trek shop to instal the upgrade, use another shop and keep the old fork in case you need it.
    Another thing to think about, if you had a nice 120 or 130mm fork it will feel loads better than a cheap POS fork if that's what came on the bike. You may realize that you don't need more travel, just a better fork. Especially if your fork is coil and the wrong spring weight.
    I really like the Rockshox Revelation. I have one and have owned a Sektor which is very similar. If on a budget, a Sektor is another great fork for the money. With Rockshox solo air forks you can adjust the travel with internal spacers from 110-150mm, depending on the model. Do some research before you buy. This is a good option in case you want to put the fork on a different bike later on or you can tinker with the travel and see how you like 120/130/140 on your bike.
    Last...You would be a fool to spend $350+ on a new fork and keep a quick release axle up front so factor in the cost of a new wheel if you run QR on there now. QR is going away and it wouldn't make sense to upgrade without TA.
    Good luck.
    May 2012
    Thanks for your input. I am going to see if I can just put a spring that is heavier and stiffer. I will definitely keep in my mind the the next time to look at the quality of the front fork.
    Reputation: rockhammer's Avatar
    Aug 2013
    Having just upgraded from an old bike with a spring fork to a Trek EX8 with the Fox Float 32 I have a few pointers:
    1. Air forks are tricky to set up and require some tinkering to dial the ride to your weight and environment. I kinda miss my set it and forget it coil.
    2. Fox shocks and forks have had reliability/quality control problems lately. Notably the Float fork dampers were recalled recently because because allowed the shock to over extend and seperate! My 2013 rear shock and my fork have both been rebuilt (under warranty for sure) leaving me bikeless for 2 weeks. If you go the Fox route make sure you get one with the 2014 internals.
    Reputation: nauc's Avatar
    first, id contact Trek and ask them whats the longest fork you can put on your bike without ruining your bike
    it does matter
    then go from there
    RAKC
    Reputation: tigris99's Avatar
    The fork that comes on it isn't bad, decent for a coil fork. Not a cheap pos as others say. I wouldn't try anything more than 120mm travel but simply going to a decent air fork would make alot of difference. All the hype keeps being fox forks, and after extensive reading in deciding what forks to get for my bike, im avoiding fox. Fox is great when they work. Overpriced and alot of reliability issues with some models.
    Manitou and rockshox imo are the way to go. Not for sure models available in 26" now but 29er wise (what im buying im a few weeks) rockshox Reba or manitou tower pro seem to be the best for the money. I know there are other great forms out there and fox by no means is bad, just have to get the right model, and imo ur way over paying just to have the fox name. For the price issues should be few and far between beyond normal wear and tear, and not the case lately.
    Sent from my Nokia Stupidphone using Tapatalk
    I'm on the same boat. I have a 2010 ex8 and wanted to upgrade to a xfusion slant 120mm with thru axle or a manitou minute pro. Anyone else go this route and have you noticed a difference in handling since they are not 51mm offset?
    mtb n00b
    Reputation: Frankie Figs's Avatar
    To the OP, what fork do you have now? Its a RS Tora 120mm right? Look into either upgrading to an air fork or getting the right coil spring for your weight in your existing fork. Also, you can upgrade the damper to one with compression adjustment. Just get a Motion Control damper for a RS Argyle. If you want to ditch the 9mm QR front end and get a new wheel, I'd say hit eBay for slightly used forks or year old models. I just picked up a 2011 150mm Revelation RL dual air for $330 shipped. It had been installed on a bike and ridden once. It still looks new! Like someone else said, the RS air forks are ride height adjustable so if you get a 140mm or 150mm fork you can space it down. Just be careful with height changes. I put a 130mm Recon 351 on my XC bike and it wouldn't climb for sh*t! I lowered it to 100mm and it was great. Once you lift the bottom bracket height up and tilt back the seat post (too much travel increase), climbing is nonexistent. Make sure you look at axle-to-crown height as well as travel. A X-Fusion 150mm fork sits about 10mm taller than a RockShox 150mm
    26" IS STILL ALIVE!
    May 2012
    I far as I know it is a Rock Shox Recon coil 120mm. I road a couple of demo bikes this last weekend. 2014 Trek Remedy 9.8 27.5 & 29er and the biggest thing that I notice was that my bike needs is a stronger front fork for my weight. I was looking at this fork for my bike: Rock shox 26" sektor r suspension 150mm mtb bike fork 1 1/8" white sra
    I would have to upgrade my axle and front rim. Any shox with about 120mm with adjustable air would be great for this bike and for the time I have it. I am currently going to college and wont be able to invest in another bike for another couple of years. I'll just spend a couple of hundred bucks here and there to upgrade components and a fork.
    mtb n00b
    The Sektor is a good fork, think of it as a cheaper Revelation. All that one would need is an all travel spacer to lower to 120 or 130 and toss a Motion Control damper in it. You can use any damper from a Reba, Sid, Revelation, or any other 32mm aluminum stanchion RS fork. The rebound damper could be upgraded too but that fork has no compression damper at all so look there first! A RLT DNA damper can be had for $50-60 on eBay and then you'd just need roughly 120ml of 5wt fork oil (local motorcycle shop) and you would be ready to go.
    As far as wheels go, look for a set of Bontrager wheels on eBay, like Rhythms or Dusters. The tubeless system is the best I've seen and the tires that came on you bike work very well tubeless. Ask me how I know I run them at 22psi and they're great!
    EDIT: I just realized yours is a '11. I'm running the newer Bontrager XR3 Experts in a 2.2. They came on the '13 models, not sure if they came on the '12 too but I know they redesigned them at some point
    26" IS STILL ALIVE!
    May 2012
    Having a better fork on my bike would help a lot, but I'm looking at getting a newer all mountain bike. Trek and Specialized had a demo day at Beacon Hill in Spokane, WA that was awesome and I learned a lot about what kind of setup I like. My Trek Fuel has worked great for me up until this point, but the frame is a little small for me. I'm about 6'2'' and my frame says that it is a 17.5, virtually a 16.5. All the bikes that they set me up with on the demo day were all around 19 in frames. I'm looking more into getting a Trek Remedy or Specialized Enduro. I just need more suspension and correct frame size. Thanks for all your input!
  1. Trek Fuel Ex8 2005: Upgrade or save it for a new bike?
    By LewisQC in forum General Discussion
    Last Post: 07-05-2013, 02:17 PM
  2. Trek Fuel EX 8 Fork and Shock Setup ?
    By heavyp in forum Trek
    Last Post: 06-11-2013, 07:24 PM
  3. 2009 Trek Fuel Ex 6.5 Fork question
    By romeslipslide in forum Trek
    Last Post: 08-21-2012, 10:24 PM
  4. Wheel upgrade for 2011 Trek Fuel EX5
    By tavorh1 in forum Wheels and Tires
    Last Post: 10-11-2011, 01:16 PM
  5. Fork for 2003 Trek Fuel 90
    By w98seeng in forum Bike and Frame discussion
    Last Post: 03-26-2011, 06:56 AM
