Poll: Which is more worth the $
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 10 of 10
    Trek 6000, Trek 4500, Specialized Rockhopper Components & Price
    Which of these 3 bikes have the best components? They are all within my price range and I have narrowed several mountain bikes at my LBS down to these as they fit pretty well.
    How good are the forks on each?? I've used the shifters on bike #3 for years and like them quite a bit. Are they very different from the shifters on these other bikes??
    BIKE #1 price: $719
    Frame:
    WSD Alpha Black Aluminum w/semi-integrated head tube, twin taper down tube w/integrated gusset, formed top tube, wishbone seatstay, forged dropouts w/rack and fender mounts, replaceable derailleur hanger
    Front Suspension
    RockShox Dart 3 w/coil spring, rebound, TurnKey lockout, alloy steerer, WSD Rider Right spring weight, 100mm
    Wheels
    Shimano M475-L hubs; Bontrager Ranger rims
    Tires Bontrager Jones XR, 26x2.25" front, 26x2.20" rear
    Drivetrain
    Shifters SRAM X.5 trigger
    Front Derailleur SRAM X.5
    Rear Derailleur SRAM X.5
    Crank Shimano M442 44/32/22
    Cassette SRAM PG950 11-34, 9 speed
    Pedals Wellgo alloy platform
    Components
    Saddle Bontrager SSR WSD
    Seat Post Bontrager SSR, 31.6mm, 20mm offset
    Handlebars Bontrager Approved Riser, 25mm rise
    Stem Bontrager SSR, 10 degree
    Headset VP-A42E, 1-1/8" semi-integrated, sealed
    Brakeset Avid BB-5, mechanical disc w/Pro Max levers
    BIKE #2 Price: $679
    FRAME Specialized M4 fully manipulated alloy frame, fully butted, externally relieved HT, forged dropouts w/ replaceable derailleur hanger, disc only
    FORK SR Suntour SF11-XCR-DS-26-LO-SP, mag. lower, 30mm steel stanchions, hyd. damping w/ lock out and custom tuned spike valve
    HEADSET 1-1/8" threadless, loose ball
    STEM 3D forged alloy, 7 degree rise, 31.8mm clamp
    HANDLEBARS Butted alloy riserbar, 25mm rise, 8 degree back sweep, 6 degree up
    GRIPS Specialized Enduro, dual compound Kraton, no flange, 131mm
    FRONT BRAKE Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
    REAR BRAKE Avid BB5, mechanical disc, 160mm G2 Clean Sweep rotor
    BRAKE LEVERS Alloy, linear pull
    FRONT DERAILLEUR Shimano Altus, 34.9mm clamp
    REAR DERAILLEUR SRAM X.5 8sp Mid cage
    SHIFT LEVERS SRAM X.4 trigger
    CASSETTE SRAM PG-830, 8-speed, 11-32t
    CHAIN KMC X8 w/ reusable Missing Link
    CRANKSET SR SunTour, Octalink spline
    CHAINRINGS 42S x 32S x 22S replaceable
    BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
    PEDALS Plastic platform, toe-clip compatible, reflectors, 9/16"
    RIMS Alex RHD 26", alloy double wall, pinned w/eyelets
    FRONT HUB Forged alloy, hi/low flange, double sealed, ground race, machined disc mount and flange, QR, 28h
    REAR HUB Forged alloy, mid flange, double sealed, ground race, machined disc mount and flanges, cassette, QR, 32h
    SPOKES 2mm (14g) stainless
    FRONT TIRE Specialized The Captain Sport, 26x2.0", 60TPI, wire bead
    REAR TIRE Specialized The Captain Sport, 26x2.0", 60TPI, wire bead
    INNER TUBES Presta valve
    SADDLE Specialized Rockhopper XC, Body Geometry, 143mm width, front and rear bumpers
    SEATPOST Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
    SEAT BINDER Alloy QR, nylon washer
    BIKE #3 Price: $591
    Frame
    Alpha Black Aluminum w/semi-integrated head tube, formed down tube w/integrated gusset, formed top tube, monostay seatstay, forged dropouts w/rack and fender mounts, replaceable derailleur hanger
    Front Suspension
    Suntour SF10-XCM-PM-HLO w/coil spring, preload, lockout, 100mm
    Wheels
    Wheels Shimano M475-L hubs; Bontrager Ranger rims
    Drivetrain
    Shifters Shimano M410, 8 speed
    Front Derailleur Shimano M310
    Rear Derailleur Shimano Deore
    Crank Shimano M361 42/32/22
    Cassette SRAM PG830 11-32, 8 speed
    Components
    Saddle Bontrager Race Lux
    Handlebars Bontrager SSR, 25mm rise, 6 degree bend
    Jan 2011
    Hi, are you looking at the 2012 model specs and is this in US? I have a 2011 Trek 4500 d and the specs look different.
    I bought a Rockhopper Pro SL 29 this year and have been very impressed with the bike. Very upgradeable frame. It has a bit higher spec, so swapped the shifters for X-7 aluminum and zowie - fun HT to mess around with. The Rockhopper was my choice for a first 29, but the frame is pretty functional (I mounted a child seat for my baby daughter - Rockhopper has the braze ons for it in back).
    Good frame, M4 aluminum very nice. Which bike FITS best when you're on it? Forget spec and go with geometry first. I could just never get comfortable on a Trek. My other bike was a Rocky Mtn ETS-X50, but just built up an Intense Tracer. My Rockhopper can feel pretty stretched out, so flipped the stem upward to be a bit more upright. Fun Bike...
    Trek 6000 has best components, but I like the Specialized Frame and fork. If you like the Rockhopper, talk the the LBS guy about some upgrades to it - Fork (RockShox Recon is excellent) shifters, derailleur, even hydraulic brakes maybe for same price as the Trek or a couple bucks extra. depends on what parts he has around...
    I picked up a 2011 Rockhopper a few months ago. I've been riding it XC/All Mountain and around town. Great bike that can handle a variety of different types of rides. I can't compare with the Treks since I've never ridden them but I can attest to the RH being a good solid bike.
    HrznRider: Thanks for the input. I went w/the Trek 6000 as it fit better and component wise I think it made sense for me. I've only been able to ride in the city so far...it keeps raining right before I planned rides on the weekends Dying to get out there and really test her out.
    Quote Originally Posted by sanjayc View Post
    Actually I was looking and ended up buying the 2010 Trek WSD in US. I had a 4500 some years back and liked it but frame was too big for me. Stand over height is always an issue with me for mountain bikes as I'm short.
    Quote Originally Posted by csrjr View Post
    Yeah, after I rode the RH around I found the geometry didn't quite fit me. I'll wear out this fork a bit and then upgrade. Thanks for all of the guidance!
    Quote Originally Posted by Chicago Ryder View Post
    That's the best decision - the bike has to fit. Enjoy!
    Reputation: nauc's Avatar
    its a MTB, not a piece of paper. go ride in the rain!
    ps, the 6000 is the best of the 3
    Reputation: Tim-H's Avatar
    I have a 08 6000, it served me well but haven't been back on it since I bought my Mojo. The 6000 was definitely worth the money. I beat the hell out of it and it just took it all. Congrats on the new bike, get out there!
  1. Trek 4500 Disc vs. Specialized Rockhopper
    By bluehornet18 in forum General Discussion
    Last Post: 03-11-2011, 11:05 AM
  2. Specialized Rockhopper vs. Trek 6000
    By Txbiker12 in forum Beginner's Corner
    Last Post: 08-01-2009, 08:04 PM
  3. Specialized Rockhopper or Trek 4500
    By The R0ck in forum Bike and Frame discussion
    Last Post: 05-20-2008, 08:10 AM
  4. Trek 4500 vs Specialized Rockhopper
    By steve_ne in forum Bike and Frame discussion
    Last Post: 08-05-2005, 09:33 PM
  5. Replies: 2
    Last Post: 02-28-2005, 05:46 PM
