Results 1 to 35 of 35
    Reputation: GTscoob's Avatar
    TransAm Geometry Gripes?
    Backstory, I'm having a custom hardtail made somewhat in the image of an XXL TransAm, long slack AM geometry. I'm 6'9" and have been riding a cramped Chameleon for a few years so now I'm having a friend build me a nice dream steel hardtail.
    Do any TransAm owners feel that their bike is too steeply angled? Most guys are running Lyriks/Fox36s and so will I, but even still, the bike is 2 degrees steeper than a comparable Ragley/On One/Sovereign.
    All bikes guesstimated around an unsagged 160mm forks most with geo based around 140mm fork.
    TransAM: 67.5 HA, 71.5 SA
    Ragley Bagger: 64.9 HA, 72.5 SA (based around 20" model)
    Evil Sovereign: 67 HA, 70 SA
    Santa Cruz Chameleon: 67 HA, 71 SA
    All have chainstays within 5mm of each other
    Ever feel like your TransAm is not slack enough?
    Reputation: brant's Avatar
    Everything is steeper than a Ragley :-)
    Look to have your designer see what the bike's geometry is WITH YOU SAT ON THE BIKE. Typical ride-height head angles for full suspension bikes are 66-68degs. With a suspension fork compressing 1-2degs under load, do you want to start at any less than 66degs to get a good head angle for a fun ride?
    Reputation: qbert2000's Avatar
    I'm no 29er advocate but you definitely shoul be looking at a 29er hardball at your height. Along the lines of a yelly screamy or a banshee paradox geometry wise
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    I think TransAm with 150mm fork is just fine. Would not change a thing on mine as far as geometry goes.
    Reputation: fireball_jones's Avatar
    Sure, compared to my Reign X, but I wouldn't expect them to be the same bike. If you're looking for a primarily downhill hardtail, the TransAM isn't the right bike. If you're looking for a great AM bike (that's best at 130mm but can run a 160), the TransAM is a good choice.
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by brant View Post
    Ah.. Speaking of the man who knows everything about angles.
    Could I ask if the talk on da interwebz that El Guapo is not as steep as it says are true? Sorry for thread hijack.. I am itching to get one of those frames..
    I figured you'd come into this thread What full suspension frames are you comparing to? The most AM bike I've ever spent time on was a carbon SC Nomad and loved the handling of it despite not getting full leg extension.
    I definitely want this bike to be slack, just not sure I want it as slack as your old Ragley bikes. I've got a 29er frame in the garage to build up as a lightweight rigid XC bike, but this bike is going to be built tough and ridden hard.
    I'm not looking for a downhill hardtail, just something that will be a lot of fun for Southeast/East Coast riding. North Georgia, Tennessee, and the Carolinas mainly with occasional trips up to Vermont to visit family.
    The Evil Sov is 68 HA & 71 SA. Any slacker & it'd wouldn't be much fun for me on my local trails which are just XC on hills. I'm using a 140mm fork & it's perfect for what I need.
    I looked at On-One 456 Inbred & the TransAM when I was trying to decide. Ended up saving more $ than I thought I could so went with the Sov which looks the best, I think. No regrets, super fun bike.
    Te mortuo heres tibi sim?
    Quote Originally Posted by GTscoob View Post
    I'd say you're barking up the wrong tree by looking at what else is out there for geometry.
    What was your fork/head angle setup on the Chameleon? Too steep? Too slack? Go based on the bike you've been riding, and what you want it to do differently, not what everyone else is riding. And what sort of riding you do with the bike.
    My TransAM feels perfect with a Revelation 150mm. Ran it with a Lyrik for a while, but I live and ride somewhere with lots of short and steep ups and down. Having it slacker with the bigger fork wasn't needed around here.
    Reputation: eurospek's Avatar
    With a 160mm 36 Float, I find it to be just about perfect for my needs. I wouldn't change a thing on my TransAM.
    And btw, I had a On-One 456 Summer Season with a 140mm Pike and I found that bike way too slack for anything other than DH shredding.
    konahonzo
    Reputation: ToneyRiver's Avatar
    If you want to change the angle you could try the new cane creek angleset headset. This would allow you to play around with your angles a little and tune the bike perfectly for you.
    Check it out Cane Creek Cycling Components :: AngleSet Threadless Headset
    Quote Originally Posted by ToneyRiver View Post
    Not at all useable on the TransAM. You need a tapered or a 1.5 headtube to make that work.
    Reputation: illini's Avatar
    Dec 2009
    Quote Originally Posted by qbert2000 View Post
    Absolutely, If i was that tall i would have a 29er. Once you max out an extra large frame the 26 wheels look out of place.
    Axe
    Axe is offline
    Custom User Title
    Quote Originally Posted by scrublover View Post
    Or 44mm. (1.5 traditional is 49). TransAm is integrated - as became standard on BMX. Perfect for a steel frame.
    Quote Originally Posted by Axe View Post
    Nope on the straight 44mm. Unless they are working on it. Seeing as how more and more frames are doing that vs. tapered, I'd bet they are.
    • ZS49-ZS49/30 fits: 49mm ID headtubes (1.5 traditional)
    • ZS44-ZS49/30 fits: Tapered headtubes- 44mm ID top (1 1/8" ZeroStack), 49mm ID bottom (1.5 traditional)
    • ZS44-ZS56/30 fits: Tapered headtubes - 44mm (1-1/8" ZeroStack) ID top, 56mm ID bottom (1.5mm ZeroStack)
    • ZS49 - TR49/40 fits: 49mm (1.5" Traditional) ID head-tubes - 1.5" to 1-1/8" Tapered Steerer)
    I like the headset setup on the TransAM, but it is a bit limiting if you want to do any tweaking of front end height or angles with the headset rather than fork height. I'd bet future generation(s) will be something else.
    Axe
    Axe is offline
    Custom User Title
    I thought they had 44 bottom... Maybe not yet. This page must be wrong.
    I hope not. Cheap, bulletproof integrated headset. I am not sure there is any need for tweaking there. Picking up fork a2c is good enough for me.
    The description of that angleset is this:
    ZS49/28.6|ZS49/30 fits 49mm (1.5") straight head tube and 1-1/8" straight steerer-tube (1.5" to 1-1/8" conversion)
    So yeah, the title on the page is wrong.
    Works components makes a 44mm angle headset
    1 0 Degree EC44 - EC44 - Angle Headset
    Ah, I think I'm wrong. Looks like CC now do have a 44mm version, even on their site. Didn't see it last time I looked. Cool. I don't need it, but it's nice as an option for future frames.
    Besides, there are quite a few cheap, bullet-proof, and non-adjustable 44mm headsets out there.
    Yeah, but it isn't about your or my needs - its about what the market wants. Adjustments. Able to take a wider range of dropper posts. Ability to tweak. Tapered is rapidly growing - will likely end up the new "standard" and you need at least a 44mm for that. Angleset if you want, or not. Tapered steer tube, or not.
    IMO, bumping up the seat tube ID and giving it at least a 44mm head tube is needed for future runs if they want it to compete well with other frames out there.
    Reputation: in the trees's Avatar
    Mar 2005
    IMO, bumping up the seat tube size and giving it at least a 44mm head tube is needed for future runs if they want it to compete well with other frames out there.
    Agreed. Those two small changes would make the TA even better! Fingers-crossed they make it to the next version.
    Quote Originally Posted by in the trees View Post
    I have a custom on the way - basically a clone of my TransAM. near identical fit and geometry, but no ISCG tabs, standard hooded dropouts, 44mm head tube for future versatility. Bottle cage mounts - I do some short rides from the house, and it's nice to not have to always have the pack. Didn't bump the seat post size, as I personally am fine with it the way it is.
    Adding what I want, getting rid of what I didn't. Builder assures me it'll be just as durable, and about a pound less weight. It's also getting a Pepto Bismol colored pink powder coat.
    Axe
    Axe is offline
    Custom User Title
    Well, Transition is clearly aware of that, as most frames got updated with 31.6mm posts - that had 30.0 before. And 44/49 (not sure why not 56 bottom) HT. 44 straight is probably my vote for HT on TransAM, if they change that, but I kinda like Campy.
    To be honest, headset type is usually the very least of my worries on a bike.
    Heh. Agreed.
    I just dig on the larger head tubes for possible tweaking. Hell, I'm looking at a cheap to pick up KHS frame NOS from two years ago. It's got a 44mm set up but a steeper HA than I prefer. The larger HT means you have some room to play with setup to get the angles you want, rather than just slapping a taller fork on and also messing up your BB height and seat angle.
    Axe
    Axe is offline
    Custom User Title
    Admitting a compulsive habit is the first step to recovery.
    (Yeah, yeah, I also obsess over a 3mm over 5mm spacer under stem...)
    Whatever floats your boat.
    Admitting you/I/we have a problem is the first step.
    My El G reads 66.7deg with my Lyric in the front. Please ask on the Titus forum for more info.
    Reputation: badgermtb's Avatar
    Geo on the TransAM...and custom...
    OP...I run my TA with a fox 36. I have no issues with the geometry numbers as they are. The bike is a good quality, durable trail bike. It is my only bike. I like to think of it is "capable" in most areas...not perfect in any. I ride chunk with it. I ride trail with it. I ride technical trail with it. Roots and rocks all over. I don't race at all with it. Commuting to the trail on it is less than ideal (compared to a 29er)...that may have something to do with the geometry? But I don't think it would rail trail as well as it does if it was a quick commuter. I have yet to find those two qualities in one bike. ;-(
    I ran it with a Rev at 150, and it rode well then, too. I wouldn't want to go shorter for my type of riding and positioning on the bike. If anything, I would have your builder build the bike to improve on the shortcomings of the Santa Cruz. If that happens to mirror the TA geometry, so be it. I also do think it would be worth your time to check out some of the long travel 29ers.
    scrublover...I am interested to see pics of your custom frame. Other details, too. I am thinking of having a TA clone of sorts built as well. I like the bike, and there are a few minor annoyances that I'd like to remedy with a custom frame. The weight would be on my short list...I love the the frame is durable, but I have to admit that I look at full sus frames often becuase they weigh about the same (or less). Are you going 650B?
    Attached Thumbnails Attached Thumbnails TransAm Geometry Gripes?-dsc_0323.jpg
    Quote Originally Posted by badgermtb View Post
    Nope, no 650. Swapping everything over, except for a new headset. Should be able to sell off the TransAM frame and other spare parts bin bits to offset the cost quite a bit. All my bikes are 26", and running near identical brake, drive, and control parts. Easy to swap parts from one to another if need be.
    Rode mine at first with a Lyrik, and liked it. But also wanted a bit more divide between the TA and my suspension trail bike, which was running the same fork, but slacker angled.
    The Rev 150 has been beautiful on mine. Ride mostly all the same trails as I ride the other bike on, just have to be a bit choosier on my lines.
    I am entertained by the fact that my "XC" bike is a 6" forked hardtail. Well, I am running skinny pinner little tires on it. Tubeless 2.1 High Roller in back, 2.1 ADvantage in front. With the Rev up front, and the dropper post and all, it's a ripper. Fast up, still fast down. Very nimble bike. The new custom is just because I can!
    NOT Team Sanchez
    Reputation: wasea04's Avatar
    Get the EG!!!
    Best bike I've ever owned! And for the record, although the head angle may be "steeper" than other similar offerings it adds to the bikes ability to rail corners, and respond much better on an average trail. The only time I wish my EG was slacker is when I'm dropping into the Pioneer Shopper, which is a B line chute down Grafton Mesa where you lock it up front and rear and control slide down it's so insanely steep. Like Brant mentioned, if you run anything at/overr 160mm you'll be in the 66.5-67 degree range depending of the rim-tire combo and the fork's a2c.
    To the OP, having a very slack angle only works if the bike's geometry allows for it, as in a short head tube and a steeper seat angle so as to keep the front end lower and thus weighted. Otherwise you're bike will ride like a chopper, which sounds cool but really isn't when you're washing out corners because the front end won't hook up.
    I like bikes.
    FM
    FM is offline
    Reputation: FM's Avatar
    Apr 2003
    ++1.
    I have both a canfield yelli screamy, and a AM 26'er which is similar to a transam/ chromag samurai. They are both sweet bikes, but the yelli outperforms the 26'er everywhere, up & down. Just did 2 days of whistler/squamish on mine....At the OP's height, 29" for an AM hardtail is a no-brainer.
    By the way, if you go custom for any kind of AM hardtail frame, tire clearance will be the biggest challenge for the frame builder. 73mm BB shell is a must. Otherwise I was pretty happy with my Curtlo. Scrub, stoked to see your new rig!
    Reputation: MMcG's Avatar
    Jul 2003
    RCP Fab??
    Quote Originally Posted by MMcG View Post
    RCP Fab??
    Yep. We'll see how it turns out.
    Reputation: mojojojoaf's Avatar
    Banshee Paradox with Fox' new FOX 34's - oh yeah that's a tall man's bike right there. Now if only I was 6'9" I to could enjoy its tall man factor being just a mere 6' I will have to dream of such things.
    Mar 2005
    RCP Fab??
    That was my guess as well. Curious to see this frame! Good luck, scrublover.
    What about an XL TransAM 29er? It might just happen.
    So Where's the Trans AM 29er?
    konahonzo
  1. Transam Geometry question
    By shift96 in forum Transition Bikes
    Last Post: 07-29-2011, 07:58 AM
  2. Anyone here quit lockon grips? What's yer gripes?
    By mcseforsale in forum General Discussion
    Last Post: 05-16-2011, 01:50 AM
  3. TransAm Geometry question. Help me understand
    Last Post: 09-26-2010, 07:56 PM
  4. Gripes on grips
    By girlonbike in forum Women's Lounge
    Last Post: 05-06-2008, 02:56 PM
  5. Grip Gripes
    By pinknz in forum Yeti
    Last Post: 08-12-2007, 11:38 PM
