Results 1 to 51 of 51
    Reputation: Pauldotcom's Avatar
    Aug 2010
    Tire blew off rim with Stans??
    I just ordered a conversion kit but I heard a couple stories today regarding tubless conversion. A couple riders I spoke to said they had the tire blow right of the rim!!!
    Everything I've read online about Stans is positive. Does anyone have negative thoughts on switching to tubless as far as tire blowouts goes?
    I ride a lot of roots/rocks, typical North East terrain.
    People fear death even more than pain. It's strange that they fear death. Life hurts a lot more than death." JM
    Reputation: hado_pv's Avatar
    You'll be fine. Run just enough pressure to eliminate 'burping'.
    http://facebook.com/CharlemontTrails
    NEMBA Past President...
    Mar 2005
    Too much pressure can also blow a tire off a rim and also some tires just don't seat well. I try to never run over 35psi and never under 25psi. Higher pressures are just to seat the bead which is very important and I suggest taking lots of extra time working the bead into the socket as good as possible. In general, I recommend being patient when you first start trying tubeless and read the recommendations on Stans site. Or you can just run tubeless tires and usually have an easier time, but not get the weight savings, only the lack of pinch flats.
    I did my first conversion last year on my front tire with the stans kit. Only had a burp episode on a drop (not enough to cause a crash) and after 6 months (depends on temperatures) I started losing air pressure - had to change the sealant.
    Thinking about converting my rear tire in the near future.
    Trail Ninja
    Reputation: Varaxis's Avatar
    Depends on the tire and rim combo. Loose tire fitting on a rim is the basic recipe for a blow out.
    Good signs to look for:
    Rims that support the tire bead on a shelf (the wider it is, the better) to keep it tight
    Thick and sturdy tire bead
    Thick and sturdy tire sidewall
    Beads that "pop" into place when inflating
    Tight tire fit
    Bad signs:
    Loose tire on rim
    - Rims with tall bead hook sidewalls
    - Tire can be rotated the rim while slightly inflated
    Flimsy sidewall
    Thin tire casing
    There's a reason why good conversion strips are thicker at the edges and why they recommend rims with a flat "shelf" for the bead to rest on as opposed to a curving inner rim profile. The bad signs can be fixed by "building up the rim" with tape or whatever--some have successfully converted rims with a curved (no shelf) rim like various carbon clincher rims with foam tape as build-up. If you choose an unideal tire, don't be surprised by any problems you might encounter.
    Also, flimsy tires that fold and twist under their own weight tend to be poor candidates for tubeless conversion. Some of them even get eaten by the solvent that keeps the latex based sealant in liquid form (ie. makes rubber into liquid). Especially if you leave the tire sitting in the same place for a while, and the solvent has days/weeks to pool into a spot and eat the rubber, seep through the casing, and eat the rubber on the other side. *cough* Kenda Nevegal *ahem*
    The best results come from properly designed rims and tires. Something with Stan's rim profile or converting a rim to be like the Stan's rim profile and tires that have a sturdy bead and sidewall to support the thread and keep its profile. Tubeless ready tires (Specialized 2bliss, Geax TNT, WTB TCS, etc.) will work great on such rims. UST is a very well designed inner rim profile with a hump built into the bead shelf to prevent the bead from unseating and doesn't require tape and no guessing regarding BSD (bead seat diameter) and ISO/E.T.R.T.O. with tape buildup to better support the bead. Bonty TLR rims with Bonty tires and WTB TCS wheels with WTB TCS tires produce great results as well.
    Dec 2009
    I think the riders you spoke to were referring to the tire 'rolling' off the rim from hard cornering, i.e. the lateral force acting on the tire is great enough to unseat the bead. This is a separate issue from burping. I have managed to roll three different rear tires since going tubeless off the rim while cornering hard (usually drifting into berms), while others don't seem to encounter this issue at all. Thus, I think it will depend largely on your riding style; some riders just don't put enough lateral force on tires for this to be a concern.
    Mine blew off the rim once already. Attempt #2 this afternoon.
    I have maxxis ardents with folding bead. They are really loose on the rim, so I know that's why. and it will probably happen again. Running more air pressure this time and just hoping my rim doesn't take any hits.
    Reputation: ride the biscuit's Avatar
    Quote Originally Posted by Jonnyd3487 View Post
    i had ardents that worked with a normal rim converted tubless, but when i got a tubless specific rim (stans flow) the ardents fit way too loose and blew out pretty quickly into first ride. the ardents have a looser fit than most i think
    you can always put extra tape in the rim to make a tighter seal.
    i've been recommended to pump the tire to max psi to seat it really well when you first get it to seal...this pushes the bead up into the rim (on my flow, it will leak slowly thru the valve back down to about 40psi)
    Reputation: masterofnone's Avatar
    I've been doing conversions for years on everything from the downhill to the road bike. I've burped with way too low pressure in rock gardens or on landings, but with a real rimstrip and/or tubeless rim usually the rim will bottom and dent first, ghetto setup is much more prone in rough riding to blowoffs without the tire bead locked under the rim beadhook. The only time I've popped off was dirtjumping and I landed sideways, any tire would have blown off any rim in that situation. If the tire bead is loose enough you can install it totally without levers you're taking chances. On a tire that was tight enough to use levers but won't air up when in the bed I've had success layering tape or using weather stripping meant for windows under the tape/rimstrip. Consult the notubes website, chances are Stan has the solution already figured out for your rim or can give advice.
    Reputation: lew242's Avatar
    I really have serious reservations about all tubeless conversions, Stan's and ghetto both.
    To me the rim and tire just aren't designed to be used in this way, if they were the rim bead-hook and tire bead wouldn't look the way they do. I had a look at the way a Stan's rim strip sat in my rim, and really I can't see how the tire and rim can hook together as well as they can with a tube. If there have been any tests about how much pressure different aftermarket tubeless tire setups can take, I'd be interested, as being a heavier (200lbs in riding gear) who rides local goat tracks that have sheer cliffs, meaning any tire failure could be potentially deadly.
    For now I might experiment using Stan's on my commuter.
    Dec 2010
    I have been using tubeless specific rims mostly Mavic and have a set of Stan's Flow since 03.I have yet to blow off or burp a tire on Mavic's a set of 823's and 819's but have on the Stan's rims,plan to change over the Flows to 819's in my opinion far superior to Stan's.819's are a pretty impressive rim even though more a CC rim I now have them on my El Guapo a full season previously on a LT2 for two seasons,I am not a conservative rider and weight 185 without gear,other then a few small flat spots and dings these rims are tough! Big doubles,drops,high speed berms and rock gardens no worries!
    Like many have said, tire/rim combo plays a big role. I've watched a friends rear tire blow off the rim after landing a moderate sized drop. He was lucky he didn't crash. Another friend had a front tire blow off and he crashed hard but didn't get hurt. I've been running tubeless for 2 years no issues. I don't recommend single ply non ust tires on non ust rims, both friends mentioned above had this set up.
    Tubeless is messy, can be a pain to set up, and you'll never be 100% safe from a tire rolling off, or blowing off the rim, but it's unlikely you'll experience those things. You will flat many tubes in the field. That's something you can be 100% sure of. Be smart about your rim tire combo, and don't expect a tubeless conversion kit for a non ust rim to allow you to run any tire you want without a tube safely. UST rims go a long way in making tubeless easy and safe.
    Just want to chime in and say I haven't had any problems since that first time. Even with the loose fitting ardents, Just rode yesterday with the same wheelset on my new bike.. works great.
    Reputation: 0010 0110's Avatar
    I took a pretty small jump maybe a foot high with ghetto tubless at around 36 psi and was fine. but at 30 psi at the same jump. the front tire blew off and really went down hard. Imma try tubeless tires and the actual stan rim strip and ill report later.
    Reputation: Spindelatron's Avatar
    does burping damage the tire bead? once burped, is it more likely to burp again? I think I didn't have enough pressure in my TCS Weirwolf II...
    Don't know much about conversion kits but I like running tubeless. I have a pair of Stan's Arch rims, very happy with them. No issues getting the tire mounted and only a couple of small burps.
    Tubeless is the way go with a Mavic or Stan's setup.
    Quote Originally Posted by lew242 View Post
    On my downhill bike I've been using stan's rimstrips on non-tubeless rims, long before anybody else I knew was using it. Calling an order talking with stan himself on the phone years ago he didn't even have the ideal rimstrip for that rim back then, but it worked perfectly. Once running really low pressure in the teens going mach 1 through a rock garden the tire burped for a second but never flatted. As long as the beads are not loose the rimstrips hold air just fine. Play the video on the notubes site with him squeezing the tire to the rim with c-clamps. 5 of my 7 bikes are tubeless from the dh bike to the roadie, the other 2 aren't serious enough bikes for the effort. I'm not exaggerating when I say flats rarely happen anymore, maybe once a year or two, out of allof the tubeless bikes. But then I don't run crazy low pressure, maybe about 5 or so less than I would with tubes.
    Burping does not damage the bead.
    BTW I have blown tires with tubes off the rims as much I have burped tubeless setups with Stans. There are probably a few setups like the Ardents where you have to be more careful, but overall it works really, really well.
    Reputation: brankulo's Avatar
    Aug 2005
    happened to me twice. one was on old bike with shimano tubeless rims and conti tubeless tires. another one happened on my new bike, stans flows with conti diesel. both fronts. not sure why as it never happened before or after, fortunatelly both occured at the begining of the ride going up so no damage to bike or me. both rides were at high elevation 10000ft above, i was thinking maybe change in pressure, otherwise not sure.
    Reputation: woodyak's Avatar
    I also ride in New England and I've been messing around with tubeless lately. On my XC rig (Yeti ASR5C) I have a set of Stan's Crest rims and I've mounted 2.4 Conty Trail Kings, 2.4 Ardent's, 2.25 Ardent, and 2.25 Racing Ralphs. I did have my front tire blow off the rim up at Kingdom Trails on a high speed turn. I was thrown hard and was lucky that I didn't get damaged. Otherwise, it's been stellar at keeping the flats away on this bike.
    My primary bike is a Knolly Delirium and I'm running Stan's Flow rims with 2.4 1 ply Ardents. I haven't had great luck with this combo. If I run pressure in the mid to upper 20's I end up blowing it off the rim at some point during the ride. I also had a couple of larger gashes that Stan's couldn't seal up.
    Another thing to note is that when my tires were new I could set the bead with a floor pump. Once the tires broke in I couldn't get it to set unless I used a compressor. I wouldn't mess with any tubeless w/o access to a compressor.
    Pros:
    - Thorn flats disappear .
    - Weight savings is instantly noticeable.
    - When it's working you don't even think about it.
    Cons:
    - For rougher riding you need higher pressure
    - Possibility of tires blowing off w/wrong pressure and/or certain tire rim combo
    - Swapping tires and repairing flats gets messy
    - Compressor access makes things more practical.
    Quote Originally Posted by woodyak View Post
    Pros:
    Cons:
    I agree with the pros/cons list but wanted to add that I've had good success running low psi in rough chunky terrain. I don't even burp that much. This is with crossmax sx, and spec sx 2.3 and 2.5 tires. I've heard my front rim contact rock a few times because of low pressure. I'm probably pushing my luck a bit, but no issues yet.
    My advice to anyone trying out tubeless is stay away from non ust singly ply tires and think about investing in a good ust rim. Mavic's design has worked the best for me. Stan's was ok, but tires set up easier and burp less with mavic. I've had ok success with non ust rims, but set up was always more difficult, and I burped more. I don't know how comfortable I would feel now with non ust tires and rims now that I know how solid mavic ust tubeless is.
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Once a tire blew off it is useless for tubeless. It will happen to it again.
    I dig trails!
    Reputation: Mr.P's Avatar
    Feb 2005
    I did have my front tire blow off the rim up at Kingdom Trails on a high speed turn....
    Stan's Flow rims with 2.4 1 ply Ardents. I haven't had great luck with this combo. If I run pressure in the mid to upper 20's I end up blowing it off the rim at some point during the ride. I also had a couple of larger gashes that Stan's couldn't seal up....
    Those are communications to you that your particular set-up is a risk.
    Varaxis's post above nailed when to use and not to use.
    loose = loose interface = easy to come off/burp
    For me, a few dollars for tires with a tubeless ready bead is less expensive than a hospital bill.
    IMHO, in a few years, almost all tires will have a TL bead.
    P
    Reputation: dunerinaz's Avatar
    All these comments are exactly why when I decided to go tubeless, I went UST. I have Mavic 823's and for a year and a half now, I've never even had so much as a burp. I weigh 215 without gear also. I definitely don't ride easy and I ride in some of the roughest terrain around in AZ. Nothing but big jagged rocks and thorns everywhere. I've had one flat in the 1.5 years and that was because I sliced the tire open with a 2 in gash on a sharp rock. UST is safer and worth the extra money in my opinion.
    "Don't feel bad. A lot of people have no talent"
    I dig trails!
    Feb 2005
    Quote Originally Posted by dunerinaz View Post
    I've had a similar positive experience as you, but with good rim strips (DT Swiss & Bontrager that have beadlocks) or Flows & wire bead or TL ready bead tires. XC to NorthStar. 3 years +.
    P
    Axe
    Axe is offline
    Custom User Title
    This.
    Now that there are plenty of light tires designed to run with sealant and with proper beads, UST are stupid easy to use.
    Stan's was fundamentally a gimmick to make use of tires that had not been designed for UST. I do like Stan's rims, but I do run them with tubes nowadays, and tubeless ready tires on Shimano UST wheels. Peace of mind.
    Wēk Ss
    Reputation: IAmHolland's Avatar
    This thread scares me. I just went to UST tires and Stan's Flow rims. I haven't ridden it yet. I didn't want ghetto, but should have gone full UST.
    Wēk Ss
    dup
    Aug 2005
    you will be fine. just take proper care to mount tire on your flows. check no tubes website if you need to.
    i run flows with conti diesel 2.5 front 22psi and mnt king 2.4 rear 25psi or something pretty close. non UST i should add.
    Dec 2010
    I have a set of wheels Stans flow that came with Mojo SL and have had some issues with burping,but have been using UST specific rims,Mavic 823 and 819's for seven years and never had one burp,plan on dumping Stans for Mavics
    I dig trails!
    Feb 2005
    Quote Originally Posted by IAmHolland View Post
    I've been jumping, dropping and railing UST beads on Flows for almost 2 years without one burp.
    UST or TL Ready bead on Flows is a reliable combo.
    P
    I've been running ghetto tubeless with Stan's sealant & Atomlab rims with a Geax Dhea TNT on the front & Maxxis EXO Ardent on the back. The Ardent was very easy to get on unlike the Geax which has beast of a bead. No problems of any sort & I'm 230#'s.
    all day long
    Reputation: DickemDown's Avatar
    Quote Originally Posted by Pauldotcom View Post
    Yes, it happened to me twice, but that still did not stop me from running Stan's Flow rims tubeless.
    1st time I went off a little drop (and I mean little) and the rear tire blew right off the rim. The 2nd time was inflating a tire with my air compressor. The common denominator here is the tires. I've had great luck with DH or 2 ply tires. It's the EXO compound that failed me. I went with the EXOs trying to be a weight weenie. I've got back to running 2 ply tires. Yeah, they're heavy, but it's a fair trade off.
    Smokey, this is not 'Nam. This is bowling. There are rules.
    Quote Originally Posted by DickemDown View Post
    I had a bad experience with EXO too. They are just too thin. I heard Maxxis may do a TR (tubeless ready) EXO soon?
    the train keeps rollin
    Reputation: snowdrifter's Avatar
    Here's my thoughts.
    UST Rim and UST Tire = most reliable setup, almost never burp or flat
    Stans Rims and TR/TL Bead = next most reliable, but sidewalls are skimpy compared to UST, major weight savings though
    Stans Rims and Standard Tire, varies greatly, some tires work very well, other suck, burping can be an issue, especially in slow chunky tech at lower PSI.
    Conversion Kits and Ghetto setups, can work great, lot's of trial and error to get the correct setup.
    beaver hunt
    Reputation: mestapho's Avatar
    Good job!
    For those who haven't seen this.
    Bicycle Wheel Warehouse has Mavic 819 wheel sets laced to XT hubs for $200 right now.
    Got mine delivered yesterday.
    Bicycle Wheel Warehouse - Mavic 819 Tubeless, XT 6bolt SALE
    I thought the EXO had something to do with the reinforced sidewall on Maxxis tires?
    Trail Ninja
    The EXO feature is a reinforced sidewall layer, but he's referring to the DHF DH ply vs DHF EXO which has a lighter casing, more akin to riding a Nevegal or XC version of the High Roller. Maxxis single ply tires are kind of loose and I wouldn't be surprised if you peeled 'em off your rim recklessly slamming into a really well made berm with more speed than what is considered sane.
    The rule of thumb on tubeless/stans that a wheel expert told me was that if you can't air the tire up with a floor pump, chances are somewhere down the line its going to be prone to burping.
    In my experiences this wrings true.
    My EXO Ardent was very easy to get ontot he rim when I set it up ghetto tubeless. I was a bit worried so I added more sealant than I have int he front. No high speed berms or drops over a foot here so not really an issue. I would rather have a tighter bead for tubeless. The Geax Dhea is a monster to get on/off the rim even after riding it with a tube for months.
    I have Stan's ZTR Flows on my Tallboy and ran Geaux Seguaro's in the summer at 38 psi and I weight 240 lbs loaded. NEVER had any issues except they are awesome. I did run over something that tore a 1" hole in my tire. It took me 15 minutes to get the damn tire off the rim!
    Since it's fall and there are move leaves now. I have on WTB 2.2 Brosnan's which are great and no issues. If you run Stan's with appropriate tires, sealant, and pressure, I don't think you'll have any issues. I always carry a tube with me....just in case.....like when I cut my tire open over what must have been a sharp edge of a broken branch.
    ... and if we just ...
    Quote Originally Posted by nevermiss View Post
    Wait these tires:
    Or these tires:
    I use stans arch rims with conti x-king 2.4's at quite a low psi (enough to put a slight ding in both rims) and have had no issues with burps or tyres rolling in the rims ir coming off.
    Reputation: qbert2000's Avatar
    Had my minion exo's blow off the rim on a high speed turn twice. Thought the first time was too low air pressure, same corner more pressure same result. Ate it hard both times. Tubes back on front tires for now until the tires tread are pooched then i'll try specialized minion copy in tubeless ready
    Quote Originally Posted by qbert2000 View Post
    EXO+tubeless IMO. I know two guys that blew their EXO's off in corners, I just blew a hole in the casing in mine. I'll never run an exo tubeless again. Spec butcher sx is a great tire set up tubeless! I like spec sizing better than maxxis too. Do they have a UST butcher now?
    Reputation: monstertiki's Avatar
    I've burped 2 exo's off of flows using stans at ~30psi in the front. I really like the minion dhf but won't run it tubeless while hitting more aggressive terrain. For DH if I use a dhf exo I'll run a tube in it,or I'll use the dhf supertacky version in the 2 ply casing. Butcher 2bliss are a good alternative, but I prefer the clutch over the butcher.
    I have WTB Bronson 2.1, on Sun Ringle Black Flag Pro wheels, which use Stans rims and kit. Those tires were a PITA to wrench on. The bead seated very well, under compressed air. So well in fact, I could've used a floor pump.
    Multiple Lines Rock
    Reputation: Acrophobe's Avatar
    Oct 2011
    great thread, thanks!
    makes me want to stick to full on UST setup- have yet to flat or have a blow off rim incident myself. I too wouldnt want a tire failure as a reason for a crash
    I had stans on my last set of 5.1D rims I used tubeless nevegals I rode the living crap out of them i took them to downieville on a weekly basis they took a few trips to northstar! I never had any issues at all with my stans conversion! i am now running stans flows and i couldn't be happier!
    Reputation: wilsonblur's Avatar
    Quote Originally Posted by snowdrifter View Post
    Here's my thoughts.
    This dude is right on!
    I ran Stan's with non-UST tires for years. Then I moved to Colorado and the rocky chunder on the trails started to take its toll on the non-UST tires. I started a regular diet of 3-6ft drops. This is when my tires started burping and unseating. I ran Mavic 717's with Schwalbe Albert 2.25 or Nobby Nic 2.4's. I had sealant leaking out of the beads almost every ride.
    I changed to true UST with Fulcrum Red Zone UST Wheels and Kenda Nevegal 2.35 UST's with no issues. I didn't realize that my gauge on my pump was 7-8psi high. So I thought I was running 28-30 and I was running 20-22psi. The only time I have sealant leak is when I let the tires get below 20psi and hit Apex or Dakota ridge at warp speed. I know it's too low when I hit the rim. I gained almost a Pound and a half in weight but I'll never go back. UST is the best!
    Narrow is the path to life, few are those who find it.
  1. minion blew off of my stans flow...what to get
    By altezza2k2 in forum Wheels and Tires
    Last Post: 11-14-2010, 10:50 PM
  2. Replies: 8
    Last Post: 09-05-2009, 04:07 PM
  3. Stan's ZTR: Blew Tire Off Rim. Tire Still Good?
    By 177ark in forum Wheels and Tires
    Last Post: 02-02-2009, 03:57 AM
  4. E that tire never blew!!
    By JJ29 in forum Nevada
    Last Post: 09-29-2006, 07:25 PM
  5. Tire blew off rim...
    By Allroy in forum 29er Bikes
    Last Post: 06-30-2004, 04:37 PM
