Results 1 to 2 of 2
    teocali super suspension help
    hi all
    i have a mongoose teocali super 2009.
    i had this problem for a long time but only now i want to fix it.
    the problem are the loosening of the rear suspension bearings and the creaks and squeaks i hear from it (especially when i pedal hard).
    i have put a lock-tight on all bearings.
    one of the bearings keeps opening and my questions are:
    1. does the creaks is the result of the bearing not being lock tightly enough? should i open them and put a new lock-tight and then close them really tight.
    2. how tight should i close the bearings?
    3. do i need to grease the bearings? how it should be done?
    10x in advance
    waiting for your help
    Reputation: drj85's Avatar
    Dec 2011
    One if my buddies has that bike and no matter how tight you tighten them they always come loose even with loctite.. he ended up getting skateboard bearings for it and some better bolts for that linkage
