Results 1 to 6 of 6
    ride hard take risks
    Reputation: dogonfr's Avatar
    Jan 2005
    Sweet 2.5 Tire, WTB Dissent
    Rode this tire around the pump track & it had no slide going through the corners. Now the pump track is not the real world it can be challenging to negotiate because of the very tight area. If the track is swept & maintained it's like cherry picking on a perfectly groomed track. Took a ride today with Atlas & the New tread on 1 of my favorite loops Dominican. This tire is Fast compared to the Maxxis Minnion i normally ride, were talking very fast not just a little faster. Single track along the hillside is awesome, you can do whatever you want with the front end on this tire it responds to input extremely well. Hitler is a mine field of silt & rocks the size of golf balls to rocks the size of a soft ball. The Dissent plowed through this section with authority, very little movement from the front end almost like a hot knife through butter. If you like a front tire that gives you confidence in braking without skidding & washing out the Dissent accels at this. Very controlled braking when descending, you can jab the brake before a corner & rip out with ease. I did get it to slide on 1 corner but it was a mix of pine needles & leaf's but the slide was very smooth & easy, jabbed the right foot down & all was cool.
    If your riding AM or DH i would highly recommend this tire in the front.
    Formotion Products
    http://www.formot
    40 & Fast
    Reputation: hiredgun's Avatar
    Good looking tire, I may have to try set on my ride.
    Ride hard, Drag the broken pieces back, Share lusty tales of adventure & Tell everyone, " I almost stuck the landing".
    Reputation: Karve's Avatar
    Mar 2006
    Whats the weight?
    Jan 2005
    Quote Originally Posted by Karve
    Whats the weight?
    Wait http://www.wtb.com/tires_dissent.html
    To fat for XC
    Formotion Products
    http://www.formot
    Flying Goat
    Reputation: mrpercussive's Avatar
    looks like a fatter minion but much lighter with the 50d and foldable beads... wonder how well it will hold the low preassures compared to tyres with steel beads though...
    Jan 2005
    Quote Originally Posted by mrpercussive
    25psi front 24psi rear no problem Atlas may give Blitz II a chalenge now with this tire. Time will tell all.
    Edit: Flip those tire numbers 24 fr, 25 rr.
    Formotion Products
    http://www.formot
