Results 1 to 9 of 9
Thread: stems
    Feb 2006
    ... and if we just ... stems
    I just got my Nomad and I want a good stem with a rise. Unfortunately I have a wonderful thompson 70mm 0 degree rise with a FSA Downhill 2inch riser bar. The Bar is a 25.4 not a 31.8. I want to keep this bar. Thompson does Not Make a rise at this length in my bar size. They do have a 70mm with 10degree rise in 31.8. My Question is Who out there Makes a good Stem with 10 to 15mm rise, more like 12mm 15mm with 70mm length for a handle bar 25.4?
    I have no sterer length left for more spacers, fyi.
    Any suggestions would be apreciated.
    Thanks,
    M.C.tigre
    Dec 2005
    Congrats on the Nomad !
    Easton Vice 65mm or 80mm, 10 degrees, 275 grams.
    Ad-Vice is adjustable rise.
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    I checked Thomson's site and the 70 does not come with rise. Good luck.
    I got some bad ideas in my head.
    Feb 2006
    Travis,
    for 07 they do have a 70mm with 10 degree rise for 31.8 handle bar not 25.4. That is my delima. I talked with a rep yesterday about this.
    I love the way this stem is made, the Thompson that is.
    Take care,
    M.C.tigre
    Reputation: Ronnie's Avatar
    Can you not use the 0 degree Thomson with a few spacers to get your bar in the right position. I did that with my X4. The only problem could be that your steerer is cut to short.
    Ronnie.
    Dec 2005
    MCtigre has no space left for spacers!
    Quote Originally Posted by MCtigre
    M.C.tigre
    I guess I kind of missed that. I didn't know what a "sterer" is!
    Ronnie.
    Ive got a Delta 80mm with a 45 degree rise Love it..gives me like 2 inches of rise...and since the top part is basically welded close to the steerer (due to the intense angle)...its basically a 40-50mm
    8 is great
    Dec 2005
    Quote Originally Posted by Ronnie
    Ronnie.
    who needs dictionaries anymore...
    After all this talk of short stems, I just pulled a 90mm and replaced it with a 110. I guess I fancy a trip over the bars!!! Actually, I'm going to compare it with respect to climbing and hammering in the cockpit (no pun intended Ronnie). I often change things and never change back just to see what a switch is like bothways.
