Results 1 to 32 of 32
    Huckin' trails
    Reputation: David C's Avatar
    Stem spacer height
    Hi,
    Had new seat post, RaceFace Deus, and I realize that I cannot clamp it in the graphics area, because it's not made strong enough in that zone to support stress (so they can make the seat post even lighter - 260 g @ 400mm ).
    Now I have to raise my stem in order to have proper position. The thing is I do not have a lot of choices for the spacers, as I have to use the ones I already had installed, but rearrange the order (I'm at my summer home, so not much parts around).
    I've read somewhere that you should not use more then a X number of spacers or more then X mm height to preserve the stability and prevent any parts failures, etc.
    So how high can I go ? Is this setup ok ?
    Pics of how I did it.
    Thanks,
    David
    Attached Thumbnails Attached Thumbnails Stem spacer height-imageuploadedbytapatalk1312306454.243573.jpg
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    meow meow
    Reputation: b-kul's Avatar
    stem spacers look fine.
    Huckin' trails
    Here's the new setup. I used 2 alu and 3 carbon.
    10mm alu
    15mm carbon
    15mm carbon
    15mm carbon
    10mm alu
    65mm spacer height. 2,5mm left between the top cap and the steering tube in the stem.
    My concern is really about stiffness and that the carbon does not crack.
    I'm worry a little that the carbon may cause some play in the headset in long term due to his flexibility, but I had many hours on it and winter riding and it doesn't cracked (I had the 3 carbon spacers over the stem before).
    Pics below.
    Thanks,
    David
    Attached Thumbnails Attached Thumbnails Stem spacer height-imageuploadedbytapatalk1312308130.729938.jpg
    meow meow
    why would it crack? there is a slight downward pressure on it. other than that no forces should act on it if you have everything installed right.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    The bending load will be put through the steer tube mostly, the spacers are mostly just there to preload the headset, that's not a large force.
    What did you mean by "I realize that I cannot clamp it in the graphics area", that's really throwing me off. What were you trying to do with your seatpost and why does that affect your stem? I think I must be reading something wrong.
    Feb 2007
    I've read in Rockshox manuals that recommend no more than 30 mm of spacers beneath the stem. I'm assuming because of the extra stress on the steerer and more leverage on the headtube. I haven't read/heard anything from frame manufacturers about it, but I would trust Rockshox. That said, if you aren't too heavy or aggressive, I've seen people run stems higher than yours...
    Reputation: nixgame22's Avatar
    I would rather run a different seatpost, than having to run that many spacers to get your fit. I know that doesn't help with your question, so yes, your current setup should be fine.
    I am curious why you bought that seatpost if it didn't fit your initial application. I see many other areas that you could have swapped out for weight savings. Also, did you add an extension to the steer tube, or was the oe tube that long?
    Maintain internal heights.
    Stray Bullet
    Reputation: Nagaredama's Avatar
    I would run a different bike!
    Jai
    Jai is offline
    Quote Originally Posted by mountainbiker24 View Post
    The same for Fox forks, no more than 30mm. I wouldn't ride my bike with 65mm of spacers...
    Huckin' trails
    Quote Originally Posted by zebrahum View Post
    Hey all, thanks for the responses.
    First, I bought this seat post for weight saving and looks, as I also had a great deal on it. I did not realize that I could not clamp it over the beginnings of the "RaceFace" graphics, because the instructions that came with the seat post says that this area is weaker in order to save weight (could not support the clamp compression). So I have to run it high. Doesn't matter since I'm tall enough, but I had to raise the stem to be in a good position for riding.
    Next, yep, it's from my RockShock manual that I read that. Thanks, now I remember
    So for the stress, it was about the leverage on the headset that might cause a slight bend in the whole spacer assembly that may cause cracking in the carbon, considering that its the weaker piece of the setup. I'm about 110 lbs and 5'6" (maybe more) and I like to beat the bike once in a while, but otherwise, I do not ride completely stiff and not helping the bike when taking hits.
    So I think I'm gonna give it a try. And no, it's not that I do not want another bike, it's that the bank doesn't want to.
    Oh, and yes, it's the full steering tube that run all the way, with 2,5mm left before the top cap. The reason why I did not cut it short is because I use this cockpit on another bike during the winter (to keep the cost down and get a better bike one day )
    Thanks all,
    David
    Reputation: BaeckerX1's Avatar
    Oct 2007
    Quote Originally Posted by David C View Post
    So you're saying you were running your seat too low before? The primary thing here is to get yourself setup for proper leg extension first. Then you worry about bar height.
    Gotta get up to get down.
    LMB
    Feb 2007
    Quote Originally Posted by BaeckerX1 View Post
    Yep.
    Reputation: GTscoob's Avatar
    This. Get your saddle high enough to pedal comfortably, otherwise its pointless to worry about the rest of the cockpit.
    I've always heard no more than 40mm of spacers. And you shouldnt have to worry about the carbon spacers since they're not loaded at all, personally I'd run a higher rise stem and riser bars rather than 65mm of spacers.
    Reputation: boomn's Avatar
    I think you need to get over this assumption which probably isn't even true. As some others have said those warnings about the amount of spacers are to prevent damage to the steerer tube, which is the part that sees the vast majority of the stress. I personally haven't had a single problem with the 20-25mm of carbon spacers I've run at times and I'm much bigger than you. I'm sure it's been done somewhere, but I've actually never heard of anyone breaking a spacer at all, carbon or aluminum.
    Oct 2007
    Yep.
    This thread makes me cry inside.
    LMB
    Reputation: pleepleus's Avatar
    I like the 200mm disk brake in the back and v brake in the front. I've never seen that before How do you change gears in the front with no derailleur?
    Huckin' trails
    Lol, I was not running my seat too low before, I did not had my seat post xD, so I had to get the stem simply basic. Now that I have my seat post, I can adjust the stem. And no, the seat post is not too high. it's just perfect.
    Thanks anyway,
    David
    Huckin' trails
    Quote Originally Posted by boomn View Post
    Thanks. I was just not really sure, since I do not have a lot of experience with carbon fiber components
    Thanks,
    David
    Huckin' trails
    Quote Originally Posted by pleepleus View Post
    Well, I'm on a budget for the bike, and I had to put disc in the back, as the frame cannot take v-brake, otherwise it would have been v-brake. But for the front, it's because I use all the front components for a winter bike, so I just switch everything back when winter comes... I would love to have a disc up front, but I also have a Freeride bike, so this one is more for training then super performance.
    And up front, well, I just forgot my fd at home , so meanwhile, I stay on the middle or switch by hand (my chain is super clean )
    Thanks,
    David
    Huckin' trails
    But 203mm at the back is nice
    I was just giving you a hard time about the brakes. If it's just a trainer/ around town bike I wouldn't worry about the spacers your not going to be putting that much stress on the steerer tube any way.
    Feb 2007
    No, I was just agreeing with what you said. It's not my bike. Don't cry!
    Huckin' trails
    Yea, but I like arguing xD
    My worries are ok now.
    But for info, those v-brakes up front are even more powerful then mech disc, even during snowing winter... So I will stick with them anyway, as they save me weight and money.
    And for the one who asked about the weight saving feature, I only tried to get the best components for the price range I had. So far, it must be around 27 lbs.
    1:40 AM local time. Getting up at 7:00 AM for riding. Get you info after the ride.
    Thanks,
    David
    "Yea, but I like arguing xD"
    Well in that case your pick a part bike is ugly as hell! And your steerer tube is going to break in half if you ride it like that
    Reputation: d.n.s's Avatar
    as i know, in manuals for forks they write recommender spacer stack height, i use 25mm and high top cap of the headset.
    I'm from Ukraine, Kiev
    I'm graphics and web designer
    Follow me on Behance
    Picture Unrelated
    Jun 2005
    You shouldn't be setting up your saddle height based on where the logo is, you need to be setting it for proper leg extension; and that's completely independent of the stem height. I wouldn't run more than 30mm of spacers under that thing if it were my face hovering over those bars.
    Huckin' trails
    Just got back from the ride.
    Position is lot better, I have proper legs extension and good pace.
    I had more vibrations on the handlebar due to the higher stem, but only on rough path. I might consider to run full carbon for the spacers to reduce a bit of weight and get the vibration reduction to the max.
    I think I will also go with a shorter stem, to get the best fit.
    Now I will finish my Cheerios and clean the sand if the bike
    Thanks,
    David
    Oct 2007
    I know. I was agreeing with you agreeing with me.
    LMB
    Oct 2007
    Thanks,
    David
    Carbon spacers will not help with vibration reduction lol. The spacers aren't taking any loads. They're just there to preload the headset bearings and give your stem something to sit on while you clamp it down.
    LMB
    Huckin' trails
    Hey, don't crash the party
    But anyway, carbon still lighter and look good. The thing is I can't afford a carbon stem for the vibes, so I said myself some wonders
    It's all inside
    David
    30 posts and I'm still wondering if this is a joke thread.
    Huckin' trails
    Quote Originally Posted by GTscoob View Post
    This is serious shitz man !
    I could get seriously injured if those spacers were inadequate ! And even not have proper leg extension
    But really, it was because I read that 30-45mm max of spacers in my rockshox manual last year and that I did not remember where I did read it and I just wanna make sure that my face does not kiss the dirt.
    So now it's over. I just received my red housing, so I will instal it right after lunch
    David
  1. Lower stack height spacer
    By crips in forum Shocks and Suspension
    Last Post: 06-05-2011, 09:23 AM
  2. Stack height spacer for 1-1/8" fork?
    By mwarner57 in forum Shocks and Suspension
    Last Post: 05-03-2011, 04:34 AM
  3. Exceeding Max Spacer Height
    By partydollagogo in forum Shocks and Suspension
    Last Post: 08-06-2010, 12:33 PM
  4. Need Help ASAP: Stripped Stem Cap Bolt
    By MrEconomics in forum Tooltime
    Last Post: 07-03-2008, 08:31 PM
  5. Bar Height and Spacer Stacks
    By Kaparzo in forum General Discussion
    Last Post: 03-03-2004, 03:36 PM
