Poll: sun charger pro vs stans flow rim ztr hubs vs mavic crosstrail
Results 1 to 50 of 50
    stans flow wheels vs sun charger pro wheels ?
    i hate to do another which one thread but i dont know squat about wheels other than mine are really heavy and im hoping this will help my bike come alive and climb better,
    im riding sun ditchwitches which i beleive are the same as rhynolite xl which are 600grams per rim. also heavy hubs. total wheel weight is 2500gram mark. these wheels are all around the same weight, and pricepoint. all are tubeless compatable, and would save me almost 2lbs of rolling weight.
    sun charger pro wheels 1699g.
    mavic crosstrails 1685g
    stans flow rims ztr hubs 1725g
    any opinions or owners with any opinions appreciated.
    Reputation: pow77's Avatar
    Aug 2010
    Hi,
    I recently replaced my stock ditchwitch wheelset (yep 2500g) and am glad I did. I cant comment on the wheelsets you mentioned but I went with some hope hoops with flow rims and am more than happy with them. They weigh around 1880g and I also grabed some lighter rubber and my bike is a new beast. Definately worth the upgrade, you will love it!
    'keep the mission alive!'
    ZTR Flow........light, very strong and love em
    Reputation: roxtar's Avatar
    I'm a big fan of Flows but there's a new sheriff in town.
    I built my last wheelset with Hadleys and WTB Frequency i23s.
    WTB Products Wheels Rims All Mountain Frequency i23 TCS WTB
    Awesome rims, the 4D drilling design really is a game changer IMO.
    Locks the bead in like a vise for tubeless.
    Democracy is two wolves and a sheep voting on what's for dinner.
    Liberty is a well armed sheep, contesting the vote.
    Reputation: Joules's Avatar
    I'd cross anything sun off your list because of the proprietary spokes which they apparently don't sell.
    Normally I don't complain about straight-pull spokes, because their availability is more of a hypothetical problem (see how long it takes to get easton spokes, for example. You can probably get them quicker than your LBS can get normal DTs if they don't already have the right size)
    But not Sun-Ringle. I broke a spoke on my charger pro, and have been totally unable to get a replacement. It's been nearly a year now.
    Quote Originally Posted by Joules View Post
    man that sucks. Well I gonna have to look into that with the guys at my Lbs. Its hard to imagine you cant get them from sun directly atleast? If thats the case it does help narrow things down. Like the crossmax there is only 24 spokes on the charger. I wonder how sturdy that can be also?
    Reputation: Dango Dog's Avatar
    Apr 2005
    I recently upgraded my Bontrager Rythm Pro's to ZTR Flow's and can tell a difference in the increased stiffness of the Flow's. Not sure on the weight but a good upgrade as far as I am concerned.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by roxtar View Post
    +1 I too just have had a set of the i23's laced to CK hubs. Total weight is 1880g including tape and valve stems. Builder was impressed with the rigidity and ease of the build, and they are supposed to be as stout as a Flow.
    i went searching and found some spokes at Sun Ringle Pro Wheelset Straight Pull Spokes | Buy Online | ChainReactionCycles.com
    Note that the Stans Flow rims are 28mm wide while the i23s are only, you guessed it 23mm wide. So if you like a healthy girth to your tire and a good contact patch, you might want to think about your choice a bit.
    Quote Originally Posted by OO7 View Post
    Like I said, the 4D drilling adds so much.
    With 4D drilling, when they drill out the spoke hole, it isn't just angled from left to right side like other rims, it's also angle for front and back for leading or trailing spokes. That means the nipple is perfectly seated in the rim with no side stress.
    I found out how much difference this makes by accident. I screwed up and started my second set of trailing spokes on the wrong side of the key spoke. Normally, this would just cause a cross above the valve. In this case, as I tightened the spokes, I could see a noticeable bend in the spoke, right at the nipple. The angled drilling was forcing the nipple to keep that angle, even when the spoke was pulling it the opposite way.
    It created an exaggerated view of how much difference that angled drilling makes
    Quote Originally Posted by MrBaker View Post
    No, they are the same width. The "23" in the WTBs stands for 23mm inside the rim, Flows actually measure 22.6mm inside
    Mar 2012
    I looked at the Sun Ringle too - but the Stan's Flows had a much better price point for 450 for the set vs 750 for the Sun Ringle Pros. Love the Stan's I've put on 3 different tires and had no issues running them tubeless. Hard to beat the flows for the price point.
    Quote Originally Posted by digktialx View Post
    i can get the charger pros for 550. where can you get the stans flows for $450? normally there about $540
    007 is offline
    b a n n e d
    Jun 2005
    This is correct.
    Mar 2012
    Quote Originally Posted by akiracornell View Post
    You may be right - I got them from jensonusa.com about a month ago - looks like they're $515.00 on there now. I think i got the numbers mixed up sorry!
    Bikebling.com sells the sun ringle stuff you could prob get them even less with the 15OFF300 coupon code.
    I haven't bought anything from bikebling yet myself.
    Aug 2010
    Dont froget you can get hope pro 2 evo hubs with flow rims for under $400, they are great, but I am biased .
    Oct 2010
    Hope
    What spokes did you have your wheels built with? I think i have decided on this combo, but will use aerolite spokes to save a little more weight.
    Juice
    Viva la Vida!
    Reputation: Camaleon's Avatar
    Ok now let me trough in another set of wheels in to this discussion.
    How about SunRingle Charger Pro VS Crankbrothers Cobalt 2 29"
    Crankbrothers Cobalt 2 29" 1773g
    We do not stop playing because we grow old;
    We grow old because we stop playing
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by Der Juicen View Post
    DT Comp's. Are the aerolite's bladed? I though about those too, but decided against them based on reports of them breaking more easily from rock strikes, which are common where I ride.
    Don't be a sheep
    Sep 2004
    In the process of building a wheelset with I23's DT 240's and Sapim Race spokes. I almost went with Lasers to shave a few grams but decided against it as I too have personally taken some mean rock strikes to spokes and would worry about their durability in the thinner size. 1740g for what should be a bomber wheelset is fine with me.
    "Do not touch the trim"
    wheelie king
    Reputation: 661lee's Avatar
    I broke a spoke on my Charger Pros. I called Sun-Ringle and left a message. Someone called me back later that day. He sent me a spoke and nipple for free. He also gave me part numbers for the spokes so that I could order spares.
    Charger Pros are great wheels.
    Reputation: eurospek's Avatar
    Did you call tech support at Sun-Ringle? I called this week and they picked up their phone right away. Quite helpful too.
    Only bummer though if you do need parts from Sun-Ringle, it's all via LBS or finding it online.
    konahonzo
    Oct 2010
    yes the aerolites are bladed. lighter, and a bit more expensive. not really too worried about there durability, a friend just laced up some i23/hope pro 2evos w/ aerolites, as well as another friend running dt swiss tricon 1950's on an sx trail being ridden through plenty of rocks!
    i'm no weigth weenie, but i know it makes the biggest difference when lost in the wheels, so i am willing to pay the extra for the lighter spokes.
    just glad to know they will come out at a resonable weight.
    Juice
    meow meow
    Reputation: b-kul's Avatar
    sun rimes have eyelets and a higher sidewall, just sometime to consider if it matters to you.
    Reputation: honns's Avatar
    Quote Originally Posted by Camaleon View Post
    I think you would want to look at the Iodine, the cobalt are their XC line.
    Viva la Vida!
    No iodine 29 :-(
    im pretty much deciding the same thing. stans vs the i23's. but im also looking at the spank subrosa rim. just a tad lighter, but 30mm wide, look cool, and seem pretty damn strong. for me i think its between the i123's and subrosas
    meow meow
    Quote Originally Posted by mrsa101 View Post
    maybe you mean the oozy? the subrosa is about 100g more than the i23.
    007 is offline
    b a n n e d
    Jun 2005
    I will say that the i23's are a fantastic rim so far. Time will tell, but they are stiff and light with a nice wide profile.
    Reputation: Whip Chop!'s Avatar
    Just put a set of Flows/Hope 2 Pro Evo on my GT Sanction and love everything about them! Very light and stiff. I have them set up tubeless and it was easy.
    Looks like another viable candidate.
    Do you know the inside dimension of the Spank rims?
    It's kind of stupid (and even misleading) for companies to use the outside rim width.
    That measurement means nothing.
    I have been looking at the i23's for a while now, but the fact that they are sleeved and pinned vs welded has me a bit worried. I am also looking at the new Pacenti TL28 rims
    Quote Originally Posted by pow77 View Post
    where would one find this?
    Quote Originally Posted by jojotherider View Post
    +1
    Big Boy
    Reputation: texasnavy05's Avatar
    Where can you find this price?
    -It's time to shred some mild to moderate gnar!!
    nero
    Reputation: nerofinis's Avatar
    Mar 2011
    Just bought hope evo and flow ex rims on CRC for 450. Shipping was free to the US.
    You can get the flow wheelset with the stans 3.30 hubs from excel sports for 450 with the new EX rim, mine were delivered today. Their customer service is hard to beat, they swapped the front hub to the right axle size for free for me!
    Sep 2012
    How do the flow ex rims look? I ordered an ex with ck laced with sapim bladed spokes. I'm looking forward to getting this rear wheel. How much did the flow ex wheel sets weigh?
    Jan 2013
    Pic are needed for this thread!
    Jan 2009
    ZTR Flows 100% Have had them for some time now and they work flawlessly!
    Wiggle when they run 10% off wheels is the cheapest for the Flows on Hopes. Got a set for $400 free shipping, and they are straight pull, which I think is about $40 more expensive, so could easily be under $400. Their stock are EX's now as well.
    Jan 2013
    i m using sun charger pro and i love it!
    Viva la Vida!
    Quote Originally Posted by MaXXimus View Post
    I am also running a set of SUNRINGLE Charger PRO and so far (A couple of months) so good I have used them on 2 new different bikes now I am having a set of FLOWS w/CK's build so I will let you all know what I think after I ride those.
    I am hoping to love the POE on the CK hub but we'll see if it really makes such a big difference.
    Aug 2010
    Quote Originally Posted by seanpatrickb View Post
    yep got mine from wiggle. Payed under $400 shipped to Australia! They are always having deals going.
    Great wheelset. Very happy.
    Flow EX 25.5mm.
    mike
    Reputation: bushwacker72's Avatar
    Jan 2009
    I put some charger pros on 2 months ago and love them so far. I have been riding through mud, snow and ice and the wheels still spin forever. I go about 210lbs geared up.
    mike
    Jan 2009
    here are a couple of Pics of the charger pros on my stumpy fsr
    Attached Thumbnails Attached Thumbnails stans flow wheels vs sun charger pro wheels ?-sr2.jpg
    Reputation: goodoljake's Avatar
    250lbs and my charger pros kick a$$. had them close to 2 years and no issues. i have re-greased the free hub two times though. Think i paid $450 for them. to me the 28mm external width is a benefit only american classic can match with their all mountain wheels. i have a set of charger pro sl on order too. i won't go near stans wheels with no eyelets and their narrower format.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Flow EX
    Unless I'm building carbon hoops, the Flow EX is a no-brainer.
    Awesome, wide rim.
