Results 1 to 7 of 7
    SS Chainrings on Geared bikes?
    I am looking at a 38t chainring to eliminate my 32t and 44t rings, but most that I'm seeing are SS. How do these work on geared bikes? If it matters, it is 9 spd.
    Old man on a bike
    You mean by itself or still with a granny gear? Before they started ramping and pinning chainrings and cogs, plain old chainrings/cogs were used on multi-ringed cranks/multi-geared bikes if that's what you're asking. Might work better with friction shifters, though.
    suum quique
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    Good point bikin'
    Using an SS ring as basically the second ring in tandem with a granny is going to result in awfully sucky shifting going from granny to the SS ring. The suggestion of a Grip Shift style front shifter would help.
    Reputation: Hardtails Are Better's Avatar
    May 2005
    Ya, but that is $65. I'm cheap.
    Aug 2005
    Yeah, but your paying for a ring that is going to last a little longer than most. If you go over to the drivetrain forum some are using SS chainrings with no ill effect.
    TLL
    TLL is offline
    Reputation: TLL's Avatar
    A non-pinned/ramped chainring works just fine on a 1 x 9. You should have no problem.
    Hadley rear hub service here and here.
