Page 2 of 4 FirstFirst 1234 LastLast
Results 101 to 200 of 314
  1. #101
    My commute
    My 2 hour commute on the TBC Double equipped with the awesome
    Suntour Durolux
    <iframe width="500" height="314" src="http://www.youtube.com/embed/7xUpqLMpxSk" frameborder="0" allowfullscreen></iframe>
    href="http://www.pinkbike.com/video/204252/">My commute!</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    RideOn
    Niko
  2. #102
    wiki
    Hi Nicholas
    With wiki I ment a page on wikipedia.
    Not that I've ever made one before but hey there's a first time for everything.
    And there's an good explaination on how to do it, http://en.wikipedia.org/wiki/Wikiped...ing_an_article
    I'll make a list tomorrow of stuff there's on the forum already post it here review it add some pictures and start a page
    Nice edit btw.
    Greetings Wybren
  3. #103
    Quote Originally Posted by stormeporm View Post
    Hi Nicholas
    Nice edit btw.
    Greetings Wybren
    I think that would be great Wybren.
    I would love to make a page and proper explanation on how to use this fork.
    I think I will make a video or picture slide show explaining how to overhaul the fork.
    It would take time but its very feasible.
    Please go ahead and look into making a page just tell me what I could do to help.
    This is a great fork and we can help make it better by letting people know all about it!
    RideOn mate!
    Niko!
  4. #104
    Seems like a fork for rookies,mainly
  5. #105
    Quote Originally Posted by NR 750 View Post
    so you a pro then dude?
    Right On!
  6. #106
    T.W.O
    Reputation: pfox90's Avatar
    Aug 2010
    My next fork will be this. Mark my words. Your inspiring nick keep up the great work.
    ------__o
    ----_`\<,_
    ---(_)/ (_)
  7. #107
    wiki setup
    I've made a first setup for the wiki page.
    Feel free to add and comment or tell me I've done something stupid. I've probably forgotten some stuff or added bogus.
    If you want to help editing stuff let me know.
    For the moment I can do the introduction and about the fork.
    I'll try to explain the differences on the dampers but I think you (nicholas)will have to add some since your knowledge about them is much better.
    Nicholas if you can write the howto's with pictures and video's
    You don't have to post the video's and pictures here, because I think we can upload them to wikipedia so the article is not depending on this forum to exist. I have to check this.
    I'll start a wikipage tomorrow it time to go to bed now, and I'm trying to safe someone crashed hard drive. Which makes a more awful sound than my fork bottoming out.
    If you post the text or pm them to me I´ll put them in a decent html layout and upload them.
    Greetings Wybren
    TypeOn
    Setup:
    introduction
    • short history
    • specs
    • nice photo
    About the fork:
    • Different versions of the durolux.
    • sf9
    • sf10
    • sf11
    • Explanation of the dampers.
    • tad damper
    • rca damper
    • The Qloc
    Pro's
    Con's
    Howto's
    • Lowering the fork
    • Adding spacers for custom heights
    • Adding oil to the air chamber to prevent nose dives and bottoming it out. ( I haven't done this yes so I'll take pictures probably this week I found a place who has proper oil)
    • Overhauling the damper
    • servicing
    • regular service
    • big service.
    Oil types to use?
    Stuff I forgot
  8. #108
    Greetings Wybren
    TypeOn
    Setup:
    introduction The Suntour Durolux RCA 180mm of plush fully active travel with a great air spring, Rebound and Compression.
    • short history The Durolux is a nice low cost but very awesome riding fork.
      I have been riding it since April of 2011 and so far find it to be stiff, full adjustable, burly and a pleasure to ride.
    • specs= The Durolux is a versatile fork that can be used from XC all the way to DH!
      180mm of adjustable travel that can be lowered internally in 20mm increments from 180mm to 140mm by moving the negative springs top out bumper.
      Suntour had done a wonderful job making it serviceable and easy for most people to overhaul and adjust.
      The fork has 35mm stanchion legs with a nice slick golden surface!
      External adjustments=
      Rebound on the bottom of the right leg
      Compression on the top of the right leg
      Air adjustment on the top of the left leg.
      Internal adjustments=
      Travel from 140mm up to 180mm
      RCA damper oil overhaul.
    • nice photo
    About the fork:
    • sf9
    • sf10
    • sf11
    • tad damper
    • rca damper is a full adjustable damper with external Rebound and Compression. The Compression has 15 clicks to a nice firm platform.
      Rebound spins free and goes from full open super fast to full closed super slow.
    • The Qloc
    Pro's
    Con's
    Howto's
    • Lowering the fork
    • servicing
    • regular service=
      would include cleaning of the fork.
      air pressure checking every couple of rides.
      a light grease of the seals with slickhoney to keep it smooth.
    • big service.
      disassembly of the fork and a full cleaning of all the seals and changing
      the grease.
      An oil overhaul for the RCA damper.
      About 6-months to a year depending on your regularity of rides.
    Oil types to use?
    Grease slick honey.
    Oil any proper frok oil.
    Scram oil 5wt is what I am using in the RCA damper.
    Stuff I forgot
    You did a wonderful job.
    I don't have any pictures at the moment but I think we could get some very easily.
    Tell me what else we need to do!
    RideOn man!
  9. #109
    Quote Originally Posted by pfox90 View Post
    That would be cool man!
    The fork is stiff and rides very nice.
    Like any fork or new product once set up properly for you bike and style it will perform to the utmost ability.
    The air spring really helps this matter!
    RidEOn!
  10. #110
    Hey man,
    Hope you can keep this up. I'm planning to get this fork for my do-it-all bike and i'd love to learn how to service it my self. If you can, please do a step by step tutorial with pictures so noobs like me can follow it.
    Thanks a lot.
  11. #111
    Quote Originally Posted by vonichi View Post
    Hey man,
    Thanks a lot.
    hhahhahahaha
    I don't think your a noob but yes, I plan on doing a picture or even video tutorial of how to
    change the travel, change the internal oil on the RCA damper and overhaul the fork completely.
    But, my fork is running so smooth right now I have no desire to overhaul and take it apart.
    I have it set up smooth and progressive and she is a blast to ride!
    I hope you enjoy the fork.
    In words I have described how to overhaul it here on this forum so, please ask if you have any questions. Im sure I can help.
    here are some pictures from last weekends ride that my buddy took !
    Im on my Durolux!
    http://www.pinkbike.com/photo/6873692/
    http://www.pinkbike.com/photo/6873687/
    http://www.pinkbike.com/photo/6873695/
    My fork is riding very smooth at the moment and cant tell you when a tutorial will be
    but, I promise I will make one just for the Suntour teaching the necessary techniques.
    RideOn man!
  12. #112
    it's the ride....
    Quote Originally Posted by nicholas poetker View Post
    RidEOn!
    Nick, a (not so) interesting review from bikeradar here:
    http://www.bikeradar.com/gear/catego...-fork-11-45003
    What do you think..?
    Personally, the Durolux deserve a more thorough test and find out why such (could be isolated) issue existed. They don't even try to explain how the components configure the whole fork (like when they tested the big brand).
    I see the fork potential, I got it couple of weeks ago and after more than "few-Bikeradar-test-days" thrashing and bashing, it's still hold up fine to the point I like it more than my Talas 36 and Marz66,
    Ulating blencong sejatine tataraning lelaku...
  13. #113
    Quote Originally Posted by softailteamrider View Post
    Thats a very bad review on BikeRadar I have to agree!
    I too read it before buying the durolux.
    They left out lots of important details like you said.
    I think they also failed to give it a full test with a preconception of its a cheep fork.
    As for me I too love it.
    The new 2012 model has high and low speed compression so my next fork for my Rune will be the 2012 model once my 36 float goes out on me.
    The float is still rocking great at a year old but I will never pay the price I did for it again.
    The Durolux is very sufficient and rides very smooth.
    I have been on mine for 3-4 months now and love it.
    Im also very interested in the Durolux air shock.
    I have roco air's on both of my bikes and love it.
    Im curious to see how it compares to the roco!
    But, cant find it being sold anywhere.
    Im sold man,
    Suntour has great top notch suspension at a great price and low weight to the burly strength.
    Just many people cant get over the name! hahahhaah
    RidEOn!
    Niko
  14. #114
    it's the ride....
    RidEOn!
    Niko
    Bikeradar may return with different opinion in next 6 months with the 2012 Durolux. Suntour should come back to them with the right sample. Their review on the Durolux TAD on 2009 was better than this recent RCA review.
    Yes the 2012 Durolux is very tempting with separate high and low compression adjustment. I don't see how it will be that much different on performance with others big brand, given the reliability though.
    I should've wait the 2012 out, but no remorse since I got it pretty cheap, almost 1/4th of my Talas 36 price .. For the value of the money it's unbeatable.
    It's on the Mach 5.7 now (as a testing rig). I may get the 2012 one for my Nomad v-1
  15. #115
    Mar 2011
    Do you think you'd be able to buy the new cartridge from the 2012 ones, to fit in my 2010?
    And I'd like to know how much suspension fluid you put into the damper side?
    Obviously I'm not the same weight as you, but I'd like to guage how much you've put in. thanks
  16. #116
    Quote Originally Posted by GreyCloud View Post
    That would be cool, but I have no idea where to by small parts for these forks.
    The new damper most likely fits but I don't know if they sell it.
    As for the damper I put 110ml or just a little over a half a cup of 5wt oil.
    It will be same for anyone as the amount increased is very minute.
    Any more and you will not get full travel.
    But at 110 you also don't get a harsh clack on bottom instead it feels bottomless.
    I actually filmed myself overhauling the RCA damper last weekend and need to edit it.
    RideOn!
  17. #117
    Mar 2011
    I just followed your advice, I put 15wt in the top of the air chamber and it does feel a lot better.
    I attatched a picture, can't link because I don't have 10 posts
    Attached Thumbnails Attached Thumbnails Sr Suntour Durolux forks?-img_0180.jpg
  18. #118
    Awesome bottlerocket man!
    Looks like my bike, hahahhahahahha
    The extra oil in the air side will make it very progressive and have a nice bottomless feeling.
    But if you put too much it will bottom too soon.
    Also the extra oil in my opinion gives the bike a much firmer ride while still maintaining the plush sensitivity the fork has!
    Good job man!
    In the next couple of weeks I will try to get the RCA damper video edited.
    RideOn!
  19. #119
    Dripping sweat!
    a nice ride with my buddies.
    I took the Durolux out for a day of DH fun followed by some jumping!
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/207817/l/' /><embed src='http://www.pinkbike.com/v/207817/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/207817/">Dripping sweat!</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    RidEOn!
  20. #120
    Member of The Yeti Tribe
    Reputation: swan3609's Avatar
    Not to rain on anyones parade but I am seriously disappointing with Sr Suntour..
    I bought a Gt Dj bike that had a Duro DJ on the front of it and I rode it for a month, given I do ride stuff hard, but it was nothing a Dj bike wouldnt see in normal use..
    Anyways I aired out of the backside of a Berm at our BMX Track and landed hard but nothing that bad. I land that hard on that jump my 20" or a rigid fork, and I bent the steerer tube on the Duro.. I didnt crash, both feet and hands stayed on the bars, It wasnt enough impact that should have bent that fork, Like I said I hit that with my 20" and I have hit it on my AM bike that has a Lyric on it lots of times.. and the Sr Suntour was the one that bent.
    The LBS calls the company and Sr Suntour tells me I am SOL because "We have pro riders that have ridden those forks for 2 years and they have never bent a steerer tube"
    So now I am without a working fork until I can save up for a Rockshox to replace it.. I know that they will treat me right if something goes wrong..
    I would understand if I had some huge crash that would break any fork but the situation was not the case, and the reply that they gave me drove me away from their company forever..
    Stop this Derailleur Madness!!.... De-Rail-er
    See what the God of bikes has to say about it..
  21. #121
    Quote Originally Posted by swan3609 View Post
    Sorry to hear your bad story man!
    There could be many reasons why it bent or didn't with your other forks.
    I ride the same trials and jumps all the time and sometimes things break off the weirdest stuff.
    I don't know much about the Duro and it looks good to me.
    The crown should be no different than that of a marzocchi or rockshocks.
    I hope you can settle things up.
    Remember what you get on a complete bike is not always top notch.
    The aftermarket products from all the companies are much better than the complete bike's specs. I don't know why they do it but they do.
    RideOn!
  22. #122
    I am fine if that's the case. But they should stand behind a product better than that.. I just refuse to do business with them again if they refuse to warranty a dirt jump fork that was bent while hitting a dirt jump that I have hit hundreds of times on lyrics and various other forks.. including rigid forks.
    It really is a bummer because I was actually thinking about a second long travel for li for my bike and I was looking at some of their offerings but with them putting me in a position where I have to buy a new fork, I will not be spending my money with them.. RS has treated me much better and will get my money and support.
    Magically generated from my Liberated Droid X.
  23. #123
    Sounds good bro!
    I understand how you feel and I would feel the same.
    Please enjoy your fork.
    If you looking for a bombproof DJ fork there are lots of offering out there.
    RidEOn!
  24. #124
    Suntour Durolux overhaul RCA
    Ok boy!
    Here it is!
    I just finished my RCA overhaul on the Durolux!
    I hope this will give you some better insight on the magic this fork has to offer.
    You can also see the forks damper is made of high quality metal.
    RideOn!
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/210368/l/' /><embed src='http://www.pinkbike.com/v/210368/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/210368/">The Suntour Durolux</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    &#x202a;2011 Durolux RCA rebuild - 720p.mov&#x202c;&rlm; - YouTube
    I hope this helps and gives a clear view of how great this fork is inside as well.
    I tried talking very slow to help explain and kind of over explained as well.
    enjoy!
    RidEOn!
    Niko
  25. #125
    Reputation: mullen119's Avatar
    Ok boy!
    Here it is!
    RideOn!
    enjoy!
    RidEOn!
    Niko
    That is by far, the funniest "how to" video I have ever watched. I Was hoping for some close ups of the internals though.
  26. #126
    Quote Originally Posted by mullen119 View Post
    Thank you!
    My personality comes out no matter what, hahaha
    As for close ups what did you want to see?
    If you watch it again you can see everything inside the damper.
    The Rebound rod has a flood gate that regulates how much oil is being pushed through the shim stack which was in the video.
    Then the compression shim stack was what I took off as I took the assembly apart.
    I did not disassemble the either shim stack as the balance is great.
    The compression damping is nice and with the external adjustments is very soft to stiff and the same for the rebound.
    next time around I will keep it in mind to get some pictures of the parts up close and throw that into the video.
    Just let me know and will see what I could do!
    RidEOn!
  27. #127
    it's the ride....
    Ok boy!
    Here it is!
    RideOn!
    Niko
    Niko, thanks for posting great Durolux overhaul video.., and it's amusing..
    Glad to hear the internal quality is no slouch either. I wonder in next one season or two this fork will be respected on par with other big boys.
  28. #128
    Dec 2009
    you have some great vids. keep um comn
  29. #129
    Thank you!
    RidEOn!
    I want to see a close up of the compression piston and rebound piston so I can compare it to the ABS+ and Mission Control designs I am used to working with. The RCA damper sounds like it makes the Durolux a good fork fork and at half the price of my Lyrik, It may be my next fork.
  30. #130
    Thank you for liking my video tutorial!
    I hope it sets a being of present normality in the realm of Great forks!
    The fork is no different than any of the 66's or 36'd I have owned and there is no noticeable
    difference in performance between the big boys so, in the next couple of years without a doubt the durolux will gain its potential being!
    RidEOn!
  31. #131
    Sorry,
    I will have to get some close ups of the shims them self.
    But I assure you the shims are stacked nicely and with either 2.5 to 5 wt oil your adjustments will work beautifully.
    As for the lyric which is a great fork but, I have never been on. Im sure you will find the durolux just as smooth.
    I have had and worked on lots of air forks.
    The internal systems are very close in reference to what they are trying to accomplish.
    I have overhauled some domains and totems and find the system to be very cool.
    They use the stanchions inner tube as the dampers walls.
    Other companies use a cartridge like you saw in the video but the working idea is the same.
    hahahhahahhaah
    I think im confusing myself now!
    For a fork thats half the price its performs up great quality.
    I will try and get closeups for you next time I think about taking her apart.
    I had a bad crash 2 weekends ago dislocating my shoulder and fracturing my coracoid process.
    So, I cant really do any overhaul work at the moment, hahahhahhaha
    nor can I go for a ride!
    RideOn!
  32. #132
    I hear there is a change for 2012 with a Hi-Lo speed compression adjustable damper.
    I wish to see a durolux with travel adjutsabilty AND an RCA damper. not sure why they don't offer this combination already. can the RCA damper be retrofitted to TAD?
  33. #133
    it's the ride....
    Sorry,
    RideOn!
    Sorry to hear you're having injury, Niko. Get well soon and post some more ride videos ..
  34. #134
    Thank's Nicholas, I've liked very much your Video tutorial .
    Sorry to read about your shoulder injury. I also had a dislocated shoulder three years ago. Everything is OK now and I can ride as I did before the injury. Just be patient.
    When I bought my RCA, it was harsh, didn't have small bumps sensibitily and was bottoming out hard easyly with 60/65 PSI for a 74 kgs rider.
    I sent an email to Suntour European Support and asking them how to make the fork working.
    They answered me to fill the air chamber with 80 WT oil to reduce the hard bottomings out and tu put 15 CC 10wt oil in the both legs for sensibility.
    That was working but I still had sometimes harsh bottoming out and the fork was too low in is travel.
    Just before you've your vidéo I've filled the cartridge (by the rebound side, not by the middle)with 100 ml 10wt oil.
    I was very surprised to find only 75 ml of oil in the cartridge
    The feeling is much more better than before I apply your trick. The fork is really a lot better now. A bit incomfortable on small bumps but I think the 10 WT is to hard. The fork now is more higher in his stroke and my bike is now well balanced
    Next step is to change the 10 WT oil for a 5 WT one.
    Here After My bike with this fork
  35. #135
    Really good tips and tricks for the Durolux Nicholas. I've owned the fork for one season and saw some really great potential in the hardware but was a little disappointed by the harshness that was the result of having to over compensate for the fork constantly bottoming out and brake diving.
    Now I've applied the extra oil in both damper cartridge as well as in the air spring chamber. This really makes the fork maintain the responsivness and plushness while adding a nice progressive end stroke.
    I think the construction is solid and simple which makes mods and adjustments really simple and fast. There are some improvements to be made especially on the compression unit that could make the fork even better.
    First, the Durolux RCA DOES have a shimstack on the rebound rod that does look well adjusted and works very well. What it DOES'NT have is a real shimstack on the compression side. Instead it has a single 0,6 mm (ID10/OD20) shim (washer?) that does control the compression oil flow but not by flexing (like a thinner shim would) instead it is adjusted by adding pressure to a spring on top of the shim making the compression flow harder or softer. The return flow of the oil is handled by a unadjustable one way return valve. I think that this construction is the main reason to why the Durolux RCA is hard to adjust within decent hi/lo speed compression results, epscially good low speed compression while maintaining good high speed characteristics.
    I've never seen this kind of construction before and was quite surprised when opening the cartridge up for the first time. I own a Epicon RL (and too many other forks of too many brands) that also has a very solid build but has a much more traditional build on the compression unit using a two way shimstack head. I haven't seen the construction of a RS TST damper but I don't think it is similar.
    That said I believe that there are some really simple and effective mods that can be done on the compression unit especially by ADDING a real shimstack. I've seen some base setups on a german forum (mtb-news.de) that gives better low speed compression results. The solution is to add a small shimstack below the 0,6mm washer consisting of a series of thinner shims in a classic pyramid setup. This will result in a sort of Two stage shim stack and add better low speed compression characteristics even when adjusting the compression to a mid or hard setting to avoid brake dive.
    The hardest part of this mod is finding fitting shims since 10mm ID shims are hard to find. I've made a setup of my own that consists of a 0,1 ID10/OD22 return valve shim from a Manitou damper and a couple of 0,1 ID10/OD16 from the local hardware specialist but I have trouble finding hardware for a more varied setup. I believe that this mod really makes the Durolux a valid competitor to the bigger brands compared on a bang for the buck level.
    I'm attaching a couple of images originating from that german thread and I hope the owner will forgive me for spreading them in the name of worldwide Durolux improvement.
    Best wishes to all you Durolux believers out there and big thanks to Nicholas for inspiration and "DH-Luza" for the shim stack mod and photos.
    Attached Thumbnails Attached Thumbnails Sr Suntour Durolux forks?-ds_durolux.jpg
  36. #136
    Mar 2011
    Does anyone have trouble with the forks losing pressure?
    I've recently done some big hits on these fork & after a while the pressure dropped to zero.
    I've had these forks for abit 3-4 months & it's only happened the last 2 days. Would new seals fix this problem?
  37. #137
    Great job adding shims to the system.
    for my fork I found the compression is very stable and rides nice,
    In the video I did the compression with 6 turns in with 5wt oil is very stiff.
    I weigh 200 lbs.
    I added enough oil to allow a smooth progressive stroke with out a harsh bottom out.
    for my application the shims would be overkill.
    I also added a spacer in the air chamber to allow for a nice progressive stroke as well.
    The fork rides great and and as you stated making shims is actually very difficult.
    for anyone finding the fork bottoming or diving do my overhaul and then add some oil to the air chamber. I would say about 50cc!
    The shim upgrade is great but my fork is wonderful with out it!
    Remember there is 15 clicks of compression.
    So, if anything over 10 is still to soft try adding more air.
    As for the small bump compliance mine is a charm.
    I grease the stanchions with honey grease after every ride the fork stays too plush for me truthfully.
    hhhhahahahhahaha
    I think a smaller air chamber is a perfect way to correct the problem of bottom out and fork dive.
    Its very interesting to hear your news and will keep it in mind if it happens to me.
    As for the fork losing air its possible.
    The fork's air chamber is in the upper half of the fork and the air can seep out 3-4 ways.
    1 through the top cap.
    if its loose it can leak air.
    2 if the seal in the main chamber is too weak it will lose air and get trapped in the lower leg.
    3 if air is trapped it the lower leg the fork will become very soft.
    4 if air has leaked into the lower chamber it can leak out the bottom of the fork through the bottom bolt or through the seals which is not good because if there is too much pressure on the dust seals they will pop out!
    If your fork is losing pressure you might need new seals but wear are they purchased?
    I will try to make another video about the forks travel and air chamber.
    Making a great fork is the best way to get out of your ride what you like!
    RidEOn!
  38. #138
    Mar 2011
    I live in NZ and I bought them off chain reaction.
    I had 15wt oil in the top of the air chamber to make them feel bottomless like you said. but..
    the last 2 days, after about 10 minutes of doing a freeride track there is no pressure and my forks compress completely like they do when you release all the air.
    I took them apart and all the 15wt has seeped into the bottom legs & air has been bubbling out the top of the leg seals.
    i'm thinking of ordering a new air piston and seal, unless you'd know another way to fix this?
  39. #139
    Aside From the durolux, are any of the other sr suntour forks worth anything?
  40. #140
    Mar 2011
    The RCA seems to be their only high end fork at this time. there's the TAD version but apparently it doesn't have a good damper.
    you can set the RCA to any travel length so I don't see it being a problem for any kind of riding
  41. #141
    Quote Originally Posted by patrick2cents View Post
    Epicons with speed lock are decent entry level forks, equivalent to the RS Tora with the TK damper. Not a great fork, but its good enough for entry level to intermediate riders.
  42. #142
    Your Nukuproof looks super cool man!
    This looks like a very fun bike!
    The Durolux looks great on there too!
    If you add oil the way I did in the video you should be able to get the right amount in there.
    I too think 10Wt is too stiff even for me.
    5 wt is a nice option.
    For the oil level 75 is too low I think in my video I measured it to 110 115 ml of oil.
    That should give you a nice progressive stroke.
    As for stiction I dont know what to say because mine is very smooth.
    I rubbed slick honey grease on the inside or each dust wiper seal then before a ride I rub it on the stanchions and the seals cycle the fork and then wipe it off.
    This keeps it very smooth.
    I have been doing this on every fork I have ever owned, slick honey really keeps the stanchions and seals running stiction free.
    Good luck and enjoy your killer bike!
    RideOn!
  43. #143
    That's sorta what I thought. I wonder why they decided to build this fork? It seems (for the current sr suntour) out of character....
  44. #144
    Mar 2011
    Could you show me a picture of how you did it?
    Just so I can get a perfect idea.
    I was trying to get in touch with distributors before these started giving me trouble since I wanted the 2012 parts. They said they're able to order parts but I'm holding it off as I'd want the 2012 parts
    So just a few pictures of the piston and possible the inside of the stanction if you can, that'd be very helpful. I'm sort of worried they're going to give me trouble from now on..
    Do you know if these forks have a warrenty?
    [Sorry I had to reply here as I don't have 10 posts. I do now so PM me back please]
  45. #145
    Quote Originally Posted by p_cycle View Post
    For 2012 the Durolox will have a high and low speed damper in all models as a top notch option. Im not sure if the current damper is will be available but the RCA high and low will be on offered on the TAD as well.
    Also the damper its self can be purchased for the current 2011 model and fit with no problem.
    rideOn!
  46. #146
    When I get the time I will make a video and some pictures of the air side damper.
    When air is leaking any where its bad news but if you can control it then the fork should be great.
    I might have some time tomorrow to film the overhaul and then edit it or even some pictures but its very time consuming.
    I have been using silicon in forks and all over my bike for years.
    The silicon dries and hardens like a rubber seal making it very worthy of many different repairs.
    For the durolux I siliconed the top piston to the air rod and made it one unit.
    Let it dry for 2-3 days as the inside of the silicon can still be wet and outside air is great.
    Then I made a thin layer of silicon around the air's piston to support the seal all ready there.
    If you have too much it will cause lots of stiction so just a thin layer a little skinnier than the seal thats sticking out.
    After this the air spring feels very smooth.
    The black piston is no longer free to move and creates a much more stable spring curve.
    The air is should no longer seep into the lowers.
    As for the 2012 stuff I had the chance to talk to Suntours about the fork and they said the 2012 damper will all be made to fit the 2011 fork as well.
    When its available I have no idea.
    Try what you can.
    As for a warranty if you contact chainreaction and get a warranty number they will take it for you. You have to mail the fork back and wait for their reply.
    For me I love the fork and decided to fix it with the silicon like I did.
    RideOn!
  47. #147
    Pinkbike recently reviewed the RCA forks a few days ago.
    SR Suntour Durolux RCA Fork - Tested - Pinkbike.com
  48. #148
    Mar 2011
    That is good. If anyone read what I wrote, disregard it entirely
  49. #149
    icalebkim
    Guest
    I think I like the Durolux's method of damping instead of RockShox's. Seems a lot simpler, and cleaner.
  50. #150
    Quote Originally Posted by icalebkim View Post
    I think so too mate!
    The damper is a self contained unite and its really easy to work on.
    The rock shocks system is great but you have to realize the inner tubes of the stanchions are the damper assembly and in reality its the same system, hahhahahahhahha
    Just this in the Durolux is easy to understand.
    Its also the same as the fox's fit damper.
    just lacking the high speed compression!
    RidEOn!
  51. #151
    icalebkim
    Guest
    Is there any benefit with the oil being held in the stanchion? That makes it seem more difficult to hold the oil in, with the rebound damper holding in all the oil.
    Are durolux's parts easy to get?
    *singing* I want a durolux...
  52. #152
    Mar 2011
    I'm currently in trying to get a new airseal, and I asked about getting a new damper. they put me through a distributor & haven't had much luck so far.
    Although I'm from NZ, you could try your region, might have more luck.
  53. #153
    I know if you cant order a Druolux Chain Reaction sells them.
    As for the oil I dont understand what you mean.
    There is the Rebound and compression side on the right with oil in the damper.
    Then the left I add oil to the air spring to make the fork more progressive.
    Its good!
  54. #154
    After I did the overhaul video I had the chance to talk to Suntour.
    The Knolly team is stoked to ride the forks and actually requested it!
    I have been saying I love the fork and its just as smooth as my Fox 36 float as the
    system is the same.
    If anyone likes a Fox you will love the Durolux.
    As for it being **** I said before dont mix up their low level forks for this as its an after
    market upgrade and not a part off a low level complete bike.
    I have a new video coming in a couple of day on how to adjust the air spring!
    Im in the middle of editing.
    RideOn!
  55. #155
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/215831/l/' /><embed src='http://www.pinkbike.com/v/215831/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/215831/">How to change the travel on your Durolux</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    How to change the travel!
    RidEOn!
  56. #156
    it's the ride....
    [QUOTE=
    RidEOn![/QUOTE]
    Great descriptive video Niko. I am thinking to lower my Durolux to 150mm with a pvc spacer now.
    Currently still going strong after 3 months on my Mach 5.7.
  57. #157
    Thats great!
    150 is a good length and you can easily be done with a plastic spacer!
    The fork is smooth at any length and I love mine at 130mm.
    RideOn!
  58. #158
    Guys, maybe a dumb question, but the RCA fork has replaceable bushings, right ?
  59. #159
    Quote Originally Posted by Vuco View Post
    Not a dumb question.
    The durolux can have anything replaced on it.
    Where to buy extra parts for the forks I have no idea.
  60. #160
    Thanks Nicholas.
    There's a shop in my country that services Suntour products, so I'll probably give Durolux RCA a go. They've told me they have everything for Suntour products (or can order it from the EU distributer).
    Also, I've seen dampers and travel adjust cartridges for the Durolux on ebay.de but that's all.
  61. #161
    Thanks Nicholas.
    Very nice!
    If I need some extra parts I will order from you, hahahhahah
    All of the parts can be replaced very easily even the seals.
    But, Like I said I havnt seen any small parts for them!
    The fork is a blast to ride man!
    RideOn!
  62. #162
    Reputation: dhbomber's Avatar
    Nov 2006
    Hello there! I've been reading this thread for a while now, and even though I started it, I didn't actually posted! So, THANKS A LOT to everyone who has pitched in and made this thread a good way to know more about the Sr Suntour Durolux! And Thanks to Nicholas for his awesome videos and super energetic personality! I wish there were more tech videos like his!
    After much thought and reading and such, I'm ready to buy a Durolux...there has been a lot of interest in the business in these forks! The new catalog came out, and I'm so happy my Dad is in there! (Team Turbo picture). Edit: Page 22
    Now that the fork has low and high speed compression adjust, it's even better! Interested in trying out the shock! Hope I can get them soon!
    Thanks again, and keep this thread going! It DOES help a lot!
    Heres the link to the catalog...
    SRSUNTOUR 2K12 catalogue
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
  63. #163
    If anyone knows german language, there's a large thread on mtb-news.de about Durolux and tuning abilities for it - LINK
    If my google translation is correct , first they talk about Duorlux 2009 which had some problems with slow rebound (resolved with lighter oil) and after they talk about 2010 models, and if I google translated it good , some of the users made new cartridges or something (start reading from the last page ).
    There's a lot of info about it, they mention some problems about it (winter problems, some slang was used so google couldn't translate it ).
    Only if someone could summarize all the things they talked about in there - problems (and how to resolve them), tuning capabilities, how are bushings doing after a year or so (some one said they are really short, like 1cm in lenght and that that is weird) etc.
  64. #164
    @Vuco:
    I am German, so if you want to know anything specific, just go ahead and ask me. I should be able to translate it.
    I bought a used 2009 Durolux RCA myself just recently and I was also talking to Niko a lot.
    I serviced it from top to bottom, but I was not able to test it by now.
    I'm really curious about how the fork will perform, but what I can say is, that it does feel kind of sticky when I try to compress the fork in demounted condition even though it is freshly serviced.
    Maybe, however, this is going to be a temporary issue, I can't say since I didn't ride it yet.
  65. #165
    Hi Guys,
    I just bought a Suntour Durolux RCA 180mm from chain recation cycle but they send me a 160mm one. Is there a different between the 180mm and 160mm? Can i open up and remove the spacer to increase the travel(Thanks to nicholas poetker for the video)? Or i need to return the fork?
    it's the ride....
    Quote Originally Posted by hwtan13 View Post
    Hi Guys,
    Short answer: yes,
    You can remove/install the spacer (or relocate the pin) to adjust the travel. Pin hole pre-set location is at 140 - 160 - 180mm travel.
    Nicko vid is a great reference for the travel adjustment.
  67. #167
    Hi thanks for the quick reply. So there is only one version of the RCA? I was worry there is 2 different version for the RCA (160mm-140mm-120mm) and (180mm-160mm-140mm).
  68. #168
    There is only one version of the Durolux RCA.
    As for the TAD I don't know whether there are two different versions. But, whent you don't want to change the travel yourself, you can return it to them and have them send you one with the correct travel adjustment, since it's their mistake... not yours.
    The guy I bought my Durolux from, bought it from CRC too... and guess what? As I opened the fork up, it was also travelled to 160mm... He obviously didn't even notice it.
  69. #169
    Hi mazze,
    I want the fork badly for a upcoming trip so i open it to check. I am a little confused as on nicholas poetker video the 160mm setting should be the middle pin hole but my fork is current on the 3rd hole which is nearest to the spring.
  70. #170
    Mhh... that is strange. Yours must be in the 140mm setting, then.
    How is it, that you are so sure, you have 160mm of travel? Did you actually measure how much travel you get? The length of the stanchions does not have to equal the "actual" travel you can get... for instance, when I compress my RCA to the fullest, so it actually bottoms out, I have still easily 1cm of the stanchions left but I can feel the bottom of the travel already. You can test this best, if you release all of the air of the fork and then compress it to the maximum.
    For the 180mm setting, you need to set the pin/needle to the highest position, like Niko says in his brilliant videos.
  71. #171
    Oct 2011
    Im planning to buy durolux, can it be installed on a gt avalanche?
  72. #172
    Reputation: KRob's Avatar
    First I heard about these forks was an ad in this month's Bike magazine. The Knolly the guy was riding is what caught my eye.
    I looked all over the ad for some clue as to who made the fork but couldn't find it. I was just about to search on here for it and found this thread.
    Googled it this morning to see what the price was and found CRC has them for under $500 with free shipping. With fox and RS forks going for $1000 or more that certainly got my attention. (I'm cheap)
    Then I read this favorable review on Pinkbike and combined with Nicholas' positive comments here, I'm thinking this fork sould be worth a look.
    With the travel adjust 140-160-180 I could use it on my 5 Spot or as a lighter option on my Knolly DT. (Still can't figure out why Fox doesn't offer the TALAS with these three travel options)
    Hmm.
    Isaiah 58:14
    www.stuckinthespokes.com
  73. #173
    Careful!
    The Durolux RCA does not have an on-the-go travel adjustment option!
    The description of CRC is misleading on that... you only can adjust the travel internally, like Niko shows in his video.
    However, there is the Durolux TAD with travel adjustment for the same price.
  74. #174
    SILENCE! I KILL YOU!
    Reputation: suicidebomber's Avatar
    Feb 2007
    I think I'm getting the 2012 DX RC2.
    Hunter, Simmons, Berrecloth, Watson,Vanderham, Semenuk, Schley, Gulevich, Bourdon, Smith, Moreland, Shandro, Boyko... Bieber.
  75. #175
    Mar 2011
    My banshee scythe with 2010 suntour RCA
    I hit a tree at around 40km/h breaking my neck.The forks are awesome, sad to see they're ruined now.
    The stantion popped out of the steerer, as the steerer bent back, stantions are still completely straight.
    I'm yet to see if I saved the damper, but I was looking at the 2012 range anyway
  76. #176
    Reputation: mojojojoaf's Avatar
    ^^ one word: DUDE!
  77. #177
  78. #178
    Feb 2007
    Nasty, nasty hit. I don't think any fork will survive that without major damage done to it.
  79. #179
    Jan 2011
    Does anyone know where to buy small bits for the durolux RCA 20 QLC?
    I am not able to post link so copy-paste it...its an exploded view of this fork:
    preview.srsuntour-cycling.com/customGates/scripts/download.php?filename=explosions2010%2FSF10DUROLUX +RCA+20QLC.pdf
    Somehow I have bent the damper fixing bolt (no. 4), so I need a replacement as the fork not rideable like this because I cannot insert the bolt all the way in and when assembled it makes bad knocking sound (and a pain to get the lowers off...)
    and to prevent any further damage its not the best idea to ride it like this....
  80. #180
    Get Some!
    Reputation: Theycallmebrown's Avatar
    i called up the north america contact number and just told him what i needed and he shipped it to me. no middle man required. You can order what you need directly from them
    SR SUNTOUR Cycling
  81. #181
    Great work man!
    If we need something just call them up!
    Makes perfect sense.
    What did you order?
  82. #182
    Reputation: wankel's Avatar
    Does anyone know what the axle-to-crown height is in 160 mm mode?
    Thanks.
  83. #183
    Get Some!
    Great work man!
    What did you order?
    I ordered the seal and wiper kit, and the travel adjust lever. I messaged you on youtube a while ago before i realized you were on pinkbike.
    Im gonna attempt to rebuild my fork today, i got all the seals and wipers, and im going to change the oil in the damper.
    the tops of my fork keep coming loose and so i have no air pressure, and no oil, and im positive that there is a ton of dirt inside too, so im just gonna do my best to tear everything apart and clean it all. i dont have honey grease though, i wish i did, but looks like im going to have to go with standard 80wt gear oil. i downloaded the pdf service manuel last night while reading through here so even though my fork is the 2009 oem version i think i learned enough about how forks work just from watching your videos that i should be fine. this will be my first major bike project.
    i usually take this stuff to a mechanic but i really want to ride it now! lol
  84. #184
    That sounds wonderful!
    Im sorry to hear your having trouble with your fork but the rebuild your going to do will ensure she is back to new.
    I wish you good luck and if you have question just ask me here or on Pinkbike.
    as for the top caps coming loose thats odd but you might want to try teflon tap around the caps threads, that should make the threads lager making it harder to come loose.
    I add teflon tape to lots of places I think will come loose and dont want to add loc-tight.
    Good luck it sounds like a good project!
    RideOn!
    Niko
  85. #185
    Quote Originally Posted by wankel View Post
    Thanks.
    Its about 545mm in the 160mm setting and 565 in the 180mm setting.
  86. #186
    Reputation: Fix the Spade's Avatar
    To Hell with the fork, how's your neck and how are you healing?
    Get well soon man.
  87. #187
    WOW thats a sad story!
    Please take care and heal up!
    A broken neck I cant imagine!
    RideOn!
  88. #188
    Get Some!
    RideOn!
    Niko
    So i took it apart, and its very different on the inside than your fork, but being a total novice, watching your videos helped me understand what does what and why, so i was able to just wing it. i have the fork with the remote travel adjust, and after calling suntour today i learned they can not be pushed to 180, so I'm stuck at the 170 that it is, 10mm is not a deal breaker for me so I'm still happy with the size. Also on that fork (manufactured December 2008) the damper is not supposed to be serviceable, so when i called to ask how much fluid I'm supposed to put in they told me if there is oil leaking or i have access to the inside of the damper then it is beyond repair. even though its threaded and obviously serviceable they didn't have a value for me, but told me i can buy a brand new damper off the new model durolux for 50 bucks that comes with compression adjustments too, so i did that because I'd like to have that adjustment.
    The damper on my fork did not come apart in the middle like yours did, it is a solid tube that comes apart at the 27mm top bolt, so with the leg fully extended i filled her up and slowly pushed the rod up, allowing it to over flow into a catch basin, then back down, and back up a few times until i was satisfied there was enough oil on the other side of the damper, i screwed the top back on and put it all back together, it feels better than it did by a lot, but if i put enough air in to be able to take large drops, i have very little small bump compliance.. hopefully the new damper with the compression adjustments is all i need to fall in love with this fork. Ill update when it arrives.
  89. #189
    Get Some!
    When I ordered a seal and wiper kit from them it came with bushings. i asked them how i get the bushings out and they said it needed a special tool that they dont sell... so im just going to leave the old bushings in there.
  90. #190
    Reputation: uzurpator's Avatar
    Dec 2005
    Hey guys.
    Anyone stumbled on information when MY2012 duroluxii are going to be available. Along with MSRP.
    I am eyeing the SF12 Durolux R. 2000grams of 180mm fork sounds sooo cool :P
  91. #191
    Awesome job dude!
    You did a very nice job and sounds like the damper is working on par.
    I know the forks differ between models and years but thats to be expected.
    I think 50 bucks for a new damper is great!
    I hope it will allow you to enjoy your fork more!
    My Durolux on the other hand with the set up I did in my video is very plush but ramps up for a bottomless feel.
    I hope you can achieve the same feeling with the new compression damper!
    Let us know how it went!
    RideOn man!
    Niko
  92. #192
    Quote Originally Posted by uzurpator View Post
    Hey guys.
    I have no idea man!
    But the new damper looks amazing!
    With hi and low speed compression the fork is going to be in a new realm of wealthy plushness.
    RideOn!
  93. #193
    Get Some!
    Niko
    It came in the mail and i immediately went to my shop and installed it. first thing i notice is that it is so much more adjustable. the rebound has a much bigger range of speed, and the compression nob is a much needed upgrade. i do feel like in a month or two i will need to tear it apart though and put thicker oil in it, it seems kinda soft now, im 225 and im pretty sure it was set up for someone 170. ill ride it for a while though before i decide to do that.
    on the trail it has given me noticeably better tracking and my traction has improved a ton, im taking it downhill and to dome dirt jumps tomorrow ill update how it goes.
  94. #194
    Thats Awesome buddy!
    Is it the same damper that I had in my video?
    If so with oil wt and volume you adjustments are infinite.
    I too recently decided to swap out the 5wt for 10wt in the damper because Im also about 200lbs. The damper's compression is very stiff and gives an overall balance to the fork.
    I think a heavier wt oil will improve your ride even more and a little more volume will increase bottom-out resistance for big hits jumps drops and G-Outs!
    The Rebound to has a huge range of adjustments so your ride can be set for better performance.
    Please have a nice ride man!
    RideOn!
    Niko
  95. #195
    Get Some!
    Niko
    yep, same damper. first thing I noticed after taking it on the shuttle runs, and the jumps is that the blue compression nob is nowhere to be found... it bounced right off, and looking at the design it was quite a poor design to not have it latch on is any way. oh well. for jumps i filled it up with a bit more air and it was fantastic. I couldnt adjust my compression though, which sucked, but the more air helped. haha. overall i liked it. i dont think im going to be upgrading for a long time.
  96. #196
    Dec 2011
    Quote Originally Posted by istandalone View Post
    anyone who puts suntour on an Intense frame should be shot and then stabbed in the eye.
    it's like putting shitty walmart wheel covers on a ferrari.
  97. #197
    anyone know what would be comparable (if it exists) for their 29" forks?
  98. #198
    Feb 2007
    Anyone uses the TAD? The RCA's price tag is a bit steep for me (I can get good used forks for the RCA's price). I saw guys using the TAD and they said its very good like the RCA, only works differently.
  99. #199
    Mar 2011
    The price difference between the TAD and RCA is only $50NZD
    The RCA has a very good damper, where the TAD is apparetly rubbish. My RCA damper was very nice, and easy to work on
  100. #200
    anyone have experience using it for 650b?
Members who have read this thread: 8
