Page 12 of 13 FirstFirst ... 2 8 9 10 11 12 13 LastLast
Results 276 to 300 of 311
  1. #276
    Reputation: mojojojoaf's Avatar
    I loved the above Scapegoat- nice. I have a 2012 Scapegoat and 2012 Suntour Durolux 180mm. Love the fork and love the bike.
  2. #277
    I've got the 2013 Durolux RC2 and I've only had one ride on it unfortunately (I'm trying to sell my frame to fund another) But it was without a doubt the best performing fork I have ever ridden. So much so that I've convinced my mate to order a set! I'm really trying to be a bit more mecanically minded, and although I understand the negative spring and air chamber etc. I'm still unsure as to how the damper works? What sort of volumes and weights of oil should be used for a 65kg rider?
  3. #278
    Mar 2013
    Re: Sr Suntour Durolux forks?
    Quote Originally Posted by mojojojoaf View Post
Name:	AAA-DBSCGT2014 (1024x741).jpg
    I could not agree more....
    Sent from my SM-N900P using Tapatalk
  4. #279
    Is there anywhere I can get the Q-loc2 axle aftermarket? I'm fed up of the q-loc jamming inside my wheel :P
  5. #280
    Reputation: SRvancouver13's Avatar
    Absolutely. Just give us a call to place an order.
    Cheers. Nick 855-205-BIKE
    SR Suntour warranty/technical advisor
  6. #281
    @Hertz32: I see you live in england. I've been looking to buy a RC2 upgrade cartridge and Q-loc2 axle from GoCycle in Germany.
    http://www.gocycle.de/f.php/shop/goc...-_Ersatzteile/
  7. #282
    Brilliant! Cheers @LasseB
    @SRvancouver1 I would, but as LasseB points out, I'm in the UK. Love to see you guys being so helpful though! I knew there was a reason I've converted 3 of my mates to Suntour enthusiasts, one has even sold his Lyrics and bought some SF14 Durolux RC2's
  8. #283
    You can also reach to our European colleagues for assistance. If they do not have the items they can direct you to a place for purchase.
    service@srsuntour-cycling.com
    Cheers. Nick
  9. #284
    Hey,
    Just came back from my workshop after changing bushings in my durolux. I can testify that the guys at Suntour European support is friendly but also a bit slow. It took them about 8 months to supply new bushings. I contacted them directly but they told me to contact my local distributor. So the order went through the swedish (yeah, I'm in Sweden) distributor to Suntour Europe and then they kind of slept on it. Distributor had to remind them a couple of times and eventually I had to write them a sour email myself to get it out their doors. But they compensated by sending me new bushings for the Durolux and my Epicon free of charge and i could pick them up at my lbs. A nice gestrure in the end. I'm not saying it was bad service, they were fast to reply once contacted but it was a bit slow to get things done.
    Just some input.
  10. #285
    The Durolux!
    Hey Guys!
    The Durolux fork and shock have both been running great!
    Here is a simple fork overhaul maintenance.
    I have been getting lots of request for a damper overhaul video too but, that will have to be in the future!
    SrSuntour Durolux 20 steps Maintenance Overhaul Video - Pinkbike
    http://www.pinkbike.com/video/358653/
    Then here is my first ride and impression on the rear durolux shock!
    The DX Durolux Shock from SrSuntour Video - Pinkbike
    http://www.pinkbike.com/video/343179/
    RideOn!
    Niko
  11. #286
    Does anyone know if you guys are planning on building a Durolux rear shock with a piggyback?
    I'd love a high end piggyback DX
  12. #287
    Durolux Damper Overhaul
    Here is a look inside the Durolux's Damper!
    A simple overhaul of this beautiful fork!
    RideOn,
    Niko
  13. #288
    Arigatou gozaimasu Niko!
  14. #289
    Your Welcome Buddy!
    I hope this video come out pretty good and easy to understand!
    Just PM me if you have a question!
    RideOn Brother!
    Niko
  15. #290
    Sorry guys I posted this already.
  16. #291
    Hey guys,
    I've just noticed a knocking/clicking sound coming from the durolux, it happens whenever the fork is compressed, no matter how small. It clicks just as it starts to extend after absorbing a hit, could it be the bushings? or do I just need to lube the air piston again?
  17. #292
    May 2013
    Quote Originally Posted by nicholas poetker View Post
    youtube;ySayfHGcX5I]https://www.youtube.com/watch?v=ySayfHGcX5I
    RideOn,
    Niko
    Hi, Niko!
    Thanks for your new Video. I have Durolux RC2'13
    1. Did you damper have a small cone spring between Compression chamber and rebound chamber? I can't see it at your video, but i have it in my damper.
    2. I could not fill to my damper more than 64 cc of oil. If I will fill 72cc I will loose a part of travel.
    3. Do you allow to be a small quantity of air in damper during assemble?
    4. I have a strange hiss sound during rebounding - is it normally? It become louder when rebound speed set to slowest.
    PS. It seems you became a little bigger.
  18. #293
    May 2013
    Quote Originally Posted by Hertz32 View Post
    Hey guys,
    I had a same problem after the first oil change. It sound from damper, low speed compression part. When I changed oil the second time (2,5wt), sound disappear.
    2 days ago I fill the damper with 10W oil and it seems that sound returned. But I need a little more time to check.
  19. #294
    Hi thank you very much!
    Yes, I have become a little bigger!
    Too much post riding beer and big meals!
    However, I still ride lots and lift weights 5 days a week.
    hahahahhah
    Ok, Im sure if you watch the video you can see the little spring.
    Maybe I forgot to film it, but yes mine is there.
    As for the oil level, you must play with it.
    You want to get full travel so, if 64cc is where your damper settles in full travel then thats perfect. I like my fork to ramp up at the end so I think for me 72cc felt good.
    Yes, there is a small cavity of air in the damper, its a straight damper with no internal floating piston or rubber bladder.
    The hissing sound you experience is just the oil and air moving through the shims.
    Its normal in this fork or damper because there is air in the system.
    If there was a rubber bladder or internal floating piston(IFP) then the hiss would go away.
    Its a sound I too dont like but the fork in general is pure butter and feels very reliable.
    It would be cool if Suntour is conjuring a way to keep cost low and battle the cavitation hiss!
    Thank you for the feedback, let me know if you need anything else!
    RideOn,
    Niko
  20. #295
    May 2013
    Niko, thanks for you answer.
    I can confirm that fork is a very plush.
    I removed yellow drum from air chamber to exceed air volume (i saw this suggestions for new SR Auron). As a result a have SAG not more than 25mm and the fork is working good without breakdown. I'm 76 kg dressed, pressure 54-56 psi.
    What is your tuning of compressions? How much clicks from full-open for LSC and HSC?
  21. #296
    May 2010
    Anyone knows of the real world weight of Durolux TA forks? I'm looking for the weight of 120-160 1-1/8 fork but not been able to find it. Thank you in advance!
  22. #297
    Mar 2013
    Any updates on your Durolux fork? So far so good on my 2013 TA model, I'll be servicing mine soon. I'm noticing oil coming out of the seals, I'm not sure if it's the grease I packed under neath the seals or the 10cc of M1 on the lowers. Either way I'll find out if dirt made it's way in....
  23. #298
    Quote Originally Posted by ricerooster View Post
    Mine was loosing some air from the air chamber in to fork leg. After rebuild leak is gone. After one season i can say - this fork one of the best offers on market for the price.
  24. #299
    @ricerooster, the oil is likely from the oil in the lowers. Same thing happens on mine and I have about 15 cc mobil 1 per leg. Dirt hasn't made its way into the fork. The fork has been good after more than 1 year of use (although I haven't been riding as often these past few months).
  25. #300
    Feb 2013
    Just had my 2013 RC2 serviced. Used 5W oil for the first time and cleaned out the internals and regreased the springs.
    It got so plush I had to change settings (more psi and clicks).
    The ride changed dramatically. Definitely the best bang for the buck AM fork out in the market today.
    Posted using Tapatalk
