Results 1 to 61 of 61
    Evlkneevljr
    Reputation: daverach2478's Avatar
    Single chainring up front?
    Was thinking about running a single chaingring upfront for my do it all bike (Intense Uzzi VPX). Recently, I was forced into running a single 36T up front when my granny ring sheared all bolts (this was a first). It forced me to run the single and I only had to walk a few steep sections. Had to stand on a few sections to mash up the hill (which I never usually do).
    Have any of you gone to a single chainring up front? Do you just get stronger and adjust to it?
    I like bacon.
    Reputation: dhbomber's Avatar
    Nov 2006
    I started riding with a single 32t chainring after a year hiatus...
    It wasn't all that tough! Of course you don't have the granny...but I think that helped with getting fit. Right now I'm in the verge of going up to a 34t ring!
    I guess it all comes down to what terrain you ride on...It's not that steep were I live, so I can get away with riding a 32 to 34 (for my fitness level) ring...
    I think you should go with a 34t.
    Oh, and it also helps if you ride a 10 speed geared bike! The steps are much closer...and takes a lot less effort than a 9 speed!
    My Bike: http://forums.mtbr.com/showpost.php?...3&postcount=49
    On-One Whippet 650b XC machine
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Yeah I ride single ring exclusively and yes you get stronger. I started with a 32t and within a few short months was up to a 38t and no hiking, I pedal everything.
    I highly recommend it, although dont wuss out and get one of the stupid E13 XCX guides, do yourself a favor and man up for a real chainguide like an MRP Mini G2 SL or S4, heck even a Lopes would be good, otherwise your just doing it wrong.
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
    Evlkneevljr
    Well, our stuff can get steep and rocky (AZ). I'm thinking to try it out for a while since I'm outta luck on the granny for now. I was just curious about making it work. It sure would simplify things and if I went to a single ring up front with a Gamut guide, my bike would drop to just a hair under 35# with my fox 180 on the front and a coil shock. It can handle anything....just making sure I could. I don't want to hike a bike anywhere; that's not my style.
    If I just need to get stronger, then so be it!
    Attached Thumbnails Attached Thumbnails Single chainring up front?-chainring.jpg
    I like bacon.
    Crash Test Dummy
    Reputation: CraptacularOne's Avatar
    How the hell did you manage to strip all of the bolts like that?
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by daverach2478
    Serious question, were you using alloy chain ring bolts? If yes, what the hell were you thinking?!? They're for weenies with more dollars than trail miles.
    Anyway. Been running a single 36t on one bike and a 32 on the other (11-34 on back of both). I've found that if I can't climb it with the 36, I still can't climb it with the 32, or on a bike with a granny gear either. The limits of my climbing turned out to be skill and not power related.
    36t ring means lots of standing, but I've yet to spin it out off road.
    i did the 1x9 for awhile but then switched to 2x9 last year. Gotta say, not going back to 1x9. It was nice to be able to get up a lot of sections that I had struggled with and still have energy left for the ride back down. Riding hasn't been about the fitness for me. Its been about having the most fun. If I'm exhausted from not having as many gears, the ride back down wouldn't be as much fun and riding in general wouldn't be as much fun.
    Nov 2006
    Use steel bolts when riding 1 ring (a lot of stress on the bolts).
    I use a Mrp 1.x Chain Guide, and it works great! It's light and quiet. I have experienced chain drops but a simple adjustment cured it.
    Evlkneevljr
    Well, I was thinking a 160lb dude wouldn't be able to shear them all off in one fell swoop of a crank turn. They didn't strip - they sheared off riding up a hill about 10 miles out. Had no chioce but to go single up front the next 10 miles out.
    Gamut makes aluminum chainring bolts (which is what these were). I've always used alloy chainring bolts because that's what Shimano put on the XT cranks I had. Never had a problem, until now. Seeing as the bolt holes are nice and sealed, thought it might be time to explore going to a single chainring. Thought about it before, but, nothing was pushing me.....until now....seeing as I can't put one on....at least until I get a screw remover bit and do some praying.
    I like bacon.
    meow meow
    Reputation: b-kul's Avatar
    you could always get the e13 shift rings. should be coming down the pike soon.
    Shortcutting Hikabiker
    Reputation: Acme54321's Avatar
    Oct 2003
    I've seen that before, usually its because of loose bolts.
    1x10 on a 2011 Trek Remedy 9. With a 34 up front and a 36t cog in the rear, there is almost nothing I can't climb in and around Portland, OR.
    Of course, the 10+ years of riding singlespeed helped prepare me for the 1x10...
    Joe
    Joe Partridge
    Reputation: Luigiugueto's Avatar
    Oct 2007
    Using a larger chainring will be harder, depending on your terrain! I havent made the transition yet, have a 36t single ring waiting to be installed. made the jump from 32t to 36 when i changed to a dual ring crankset, I still used the granny every once in a while.
    I used to pedal up everything on my 32, cant say the same for the 36t. I still have to downshift to the granny after really long rides, but its less and less every day!
    I say go for it! it'll make you stronger, make your bike simpler and make your rides more challenging.
    Evlkneevljr
    this was one of the unusual incidents. I actually used a torque wrench (45 in lbs) and loctited them in. Even though it was only blue loctite, it's certainly going to make it a pain to try and get them out.
    I like bacon.
    Quote Originally Posted by Joe_Jitsu
    Joe
    After riding 1X9 for the last three years, I think this is probably the ideal gearing setup...
    Reputation: mojojojoaf's Avatar
    I started my 1x9 with a 32/12-36 then I got sick- really really sick with a viral infection in my lungs 3 months out of action- moved to Utah which I was excited about but its been winter so now its more like 6 months out of action....had to go to a 28/12-36. Gotta work it back up to a 32...I love the simpleness of a single gear up front. Wish internal geared hubs would come down more in price- that would rock.
    Oct 2003
    Oh yeah, I've never seen one do that exact thing. Most of the time the bolts end up stripping out of the crank. Usually steel bolts though.
    May 2010
    I recently switched over to running a 32 up front only and fairly new to the MTB scene. I picked up a nice bashguard so what would be a a good alternative to the MRP mini G2, I just need a nice guide to keep the chain in place.
    Also, when you when to a single up frotn, did you shorten your chain a few links too?
    100% fuzz, 0% melody
    Mar 2011
    If you want to walk nearly as often as a singlespeed rider, go with 1x9.
    If you want to be hip and trendy and pretend to be Mark Weir, go with 1x9.
    If you want to get stronger because you're lazy and prefer to use that 22t granny ring far more often than you should, go with 1x9.
    If you want to look like a pro DHer and have no front der and no cable or front shifter, go with 1x9.
    If you want to have a bike that looks like you might do an occasional Super D race even though you never ride much, but like posting pictures of your bike on the Web, go with 1x9.
    some or all of the above may apply. use your best judgment to know which works for you.
    Dude... why?
    May 2010
    I come from a BMX background and prefer the simpleness of it, that I and for my area it makes sense . Actually, if I could make a bike purchase again I would go with a single speed 29er.
    I ride rugged terrain so I have no use for the big rings. I run an 11-34 cassette and a 26T front granny ring. Rarely do I spin out. When I used to ride mellow XC terrain I used a 34T front ring and 11-28 cassette. It all depends on your terrain.
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I'm riding a 32T chainring, BBG bash, Blackspire Stinger, med cage derailleur, ghetto jumpstop and 11-32 cassette here. Several thousand miles on this setup and no issues with chain drop or shifting. Even chain/cassette life was on par.
    Ride it everywhere and the gearing has never forced me to hike-a-bike. Other factors have, but not the gearing. :-(
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    #THELEGEND
    Quote Originally Posted by Ash T. Abula
    WOW someone has issues!! Guessing you tried the 1x9 and couldnt make it work out huh. so sad. Whats you issue with Weir, jealous???
    #THELEGEND
    2016 RSD Mayor
    May 2010
    So I'm looking for a good chainguide to run with my raceface bashring.. would this work? http://www.chainreactioncycles.com/M...?ModelID=40435
    I already have the bash ring, so I would like to avoid having to buy the complete guide/ring and spending $150.
    Blue Pig
    Reputation: Blksocks's Avatar
    Dec 2009
    Dude... why?
    Wait, wait, wait... How stupid is your thinking? One can seriously turn the table on what you wrote. Just, get out... now...
    Ragley Blue Pig
    Mar 2011
    Quote Originally Posted by Blksocks
    Quote Originally Posted by Guy.Ford
    to both of you:
    Your humor detector is broken in the most obvious way.
    Your projection of your own inadequacies is intact though.
    Carry on.
    Interim thought: here's my "All Mountain hardtail," which runs 1x9:
    Attached Thumbnails Attached Thumbnails Single chainring up front?-green-curtlo.jpg
    Blue Pig
    Dec 2009
    to both of you:
    Carry on.
    It's easy to change face on the internet, isn't it?
    Ragley Blue Pig
    #THELEGEND
    to both of you:
    Carry on.
    Meh humor detector works fine, but I take the 1x movement very seriously, possibly too serious and dont take well to people talking BS @ it just because they're candy a$$e$. Sorry for the misunderstanding, I stand corrected. Still unsure @ your Mark Weir comment though.
    Inadequate, doubtful I run a 1x9 on a 38 lbs rig and can outclimb dudes on hardtails with full 3x9 drivetrains, so no worries there.
    BTW, props for doing the 1x9 right, full chainguide is the only way to roll, unless your on a commuter then by all means mount up the Jump Stop!
    #THELEGEND
    2016 RSD Mayor
    #THELEGEND
    Quote Originally Posted by smwill214
    Sadly that is not going to work for you, that is just a parts kit (sliders, roller and nuts/bolts) for the D2 guide, youd still need the boomrang. Hate to say it, your probably going to have to pony up for a whole guide.
    #THELEGEND
    2016 RSD Mayor
    Ride.
    Jan 2011
    Quote Originally Posted by osmarandsara
    Yup. Same here. I end up starting each season with 2 rings and a front derailleur, because I think I might need it after the winter months, but never seem to use it. It always makes it way off early. Two rides this season and its coming off now. Back to 32f x 11-34 rear w/ an e13 lg1 guide and salsa 32t ring. Best gearing Ive ever used. I also found that I can climb just about everything in the 32/34, sometimes with a little extra grunt but I get there.
    Evlkneevljr
    Thanks for the comments - Right now, I'm thinking more toward my reasons of:
    "If you want to look like a pro DHer and have no front der and no cable or front shifter, go with 1x9"
    Turns out, it's forcing me to be stronger. Went out today and sure enough, I did have to walk some sections, but, I think I could have made them givne more time on a single up front. I have an Uzzi VPX with a 180mm fork on the front. Why? Cause it's the only bike I have. I need it to do everything.....and it does. Got it down to under 36# with a decent build and will drop another 1lb soon. I was trying to simplify and looking for encouragement. Some locals say I'm stupid and just keep the Granny. Others say go for it and it will make you stronger. Only thing I worry about are those Epic 4-5 hour rides in Flagstaff, AZ and the steep climbing on some of the mountains. I'll just have to see what happens; so far, I'm liking it, but, it does take more energy at times....that's where I'm hoping the getting stronger part will come in.
    I like bacon.
    Reputation: asw7576's Avatar
    9 speed
    11 - 34 rear
    22 - 32 front
    Is there such things as 21T crank gear ?
    A custom made 21T ?
    #THELEGEND
    You will get stronger believe me, you just have to have patience and heart, you have to really want it. When I started on the 1x9 I was using a 32t w 11/34 cassette and after a few months (@5) I was running a 38t with 11/34 and not walking anything. Its seriously all about determination. I thought for years about how much I wanted to do this, coming from a DH background it just made sense to me, but always figured it would be too hard. Then one day I decided to really go for it and after a while it got easier, then I started moving up rings and viola piece of cake. Good luck man, hang in there and dont listen to the haters, they're just jealous and lazy.
    #THELEGEND
    2016 RSD Mayor
    Reputation: illini's Avatar
    Dec 2009
    I found 38T to perfect, great balance between high and low.
    Reputation: boomn's Avatar
    Quote Originally Posted by asw7576
    A custom made 21T ?
    Action Tec makes Ti granny rings in 20t and 21t sizes. ~$60 for the basic model, ~$90 for the heat-treated version
    It's a lot cheaper to just work on stronger legs though
    Don't be a sheep
    Sep 2004
    Where do you live and ride?
    "Do not touch the trim"
    #THELEGEND
    Quote Originally Posted by Rivet
    I live in Socal and ride all over - SoCal, Norcal, Nevada, Arizona. I ride a 07 Kona Coiler with Totem and Romic coil shock. Been eyeballing the Pivot Firebird or Phoenix as my next ride to replace the Kona,
    #THELEGEND
    2016 RSD Mayor
    1x9 is the only way to go, with a chain guide such as an MRP G2. I run a 36T with a 11-32 short cage der. Super tight, super responsive.
    What you gain? Closest to an instant pedaling response next to a single speed. No dropping chains, no chain slack, makes you stronger, ups the fun factor, less clutter on your bike--one less cable is a lot, or better yet save that for the gravity dropper seat post.
    Stick with a 1x9.....1x10's are a money sucking joke. You get the same gearing from a 1x9 save the 11-36, but do you need that? Compensate with the correct chain ring up front. 10 speed chains are weaker, wear out faster, cost a lot of money...and with the tighter spacing on the cassette, breathe on it hard enough, and your hanger is out of alignment. Tighter spacing, less room for the derailleur to be off, and in AZ, that equals many rides with bad shifting.
    Start with a 34T 11-34 cassette, and you should rock up everything. If not..like a Single Speed, the more you ride it, the stronger you will get and will clear the climbs in due time.
    wuss
    Reputation: dropadrop's Avatar
    I run single 28t in the front with a cassete up to 32 on the rear. Next I'll be trying 32 up front so I can run conventional chainrings, but I'll probably need another cassette too.
    Evlkneevljr
    Well, my bike seems to be heavier than most people doing this that I see (35.7lbs), but, I like to make sure I can litterally handle anything on the trail and not have to worry about my bike. Good to hear some people that ride in AZ/CA type stuff do it; gives me some courage to simplify.
    completely rebuild my Uzzi and the gearing set up I built is a single speed hub (zero dish) with a modified 10 speed XT cassette. Original intent was 2x8. Since the Granny chainring incident, it made me think 1x8 might not be a bad idea. May be tougher to start, but, hoping to grow into it.
    Had to walk 2 sections again but seem to be motoring up sections faster than my friend using a granny...and I don't feel all that bad (the first week I hurt, though)....still gotta replace my Gamut Dual with a single guide....chain keeps falling off on top without the derailer there.
    Attached Thumbnails Attached Thumbnails Single chainring up front?-rear-der-cassette.jpg
    I like bacon.
    meow meow
    quick, tell adam craig! dudes a newb!
    Don't be a sheep
    Sep 2004
    If you "not walking anything" in Laguna with a 38-34 low you are either not riding very demanding trails or should be a pro XC/road racer.
    #THELEGEND
    the only trail I can think of in Laguna, which I would have no reason to climb anyhow, is Canyon Acres. Meadows - check! Mathis - check! Moving along to El Morro, I think I can - check, Slow and Easy - Check. Other Socal trails I have clmbed and continue to, Holy Jim, STT to Old Camp, Harding, Maple Springs, San Juan, Blackstar did I miss anything?
    Now dont get me wrong Im not climbing Holy Jim at XC race speed, but I make it up without stopping and I dont walk.
    #THELEGEND
    2016 RSD Mayor
    #THELEGEND
    Quote Originally Posted by b-kul
    RIGHT!!!! PM me with his email and I'll be sure to let him know.
    #THELEGEND
    2016 RSD Mayor
    meow meow
    i thought all you 1x9 guys knew each other contact info? dont cult members usually know that sort of thing?
    Many singlespeeders ride big, long hills in even harder ratios. The difference is that SS riders stand to climb instead of sitting. Past a certain steepness and length most riders will have to do the same with a 34x38 ratio.
    In other words the real difference in what works or not for your climbs is just your preference for cadence and climbing style. They all work, but maybe not in the way you like or that your muscles are used to. I like single ring setups but I prefer to still be able to sit and spin at a fairly high cadence for extended climbs so I've stayed with a 32fx34r low gear, but when I was riding SS only for two years I was clearing the same hills with 32x20
    #THELEGEND
    Nah my 1x9 crue is a very discerning bunch and IMO Craig does it all wrong. His use of the MRP 1x guide is total weight weenie poser sh1t.
    for reference: Adam Craigs bike = fail
    #THELEGEND
    2016 RSD Mayor
    Mar 2011
    You're not a real man unless you ride up Mont Blanc on a 34 lbs Carbon Nomad with a 200mm travel fork up front, and a 1x10 setup with a 42t ring on the front and an 11-21 cluster out back.
    Anything less is just like wearing a pink tutu and lemon-yellow ballet slippers to the rodeo.
    Mar 2011
    Gosh, I've confused an Internet Expert on MTBR All Mountain Forum Single Front Chainring threads.
    What will I do to recover from this horrifying existential setback?
    I think I'll sit back and watch The Expert comment further in other threads, expanding his Zone of Expertise. Maybe one day he'll teach at The University of Emptybeer!
    #THELEGEND
    meh
    #THELEGEND
    2016 RSD Mayor
    Sorry to use this thread with my doubts but here it goes
    I have a 06 Enduro Elite and i'm thinking in going single ring.
    Presently, i have a 22-32T but i've been only using the 32T for the past month and i feel great not using the granny ...
    I discovered that my body prefers strength to "rotation" when climbing.
    So i'm thinking about these parts
    32T + 10 Speed ( 12-36 ) cassete + x9 short cage derailleur
    34T + all the other stuff.
    So some questions here...
    A) do you think it will be ok using the short cage derailleur in the back?
    B) 32T or 34T? Much difference?
    C) As for the casette... 12-36 will be better for climbing yes?
    Thank you all
    Oh, So Interesting!
    Reputation: davec113's Avatar
    Quote Originally Posted by Postmodvm View Post
    Thank you all
    a. yes
    b. yes
    c. if you're going 10 speed why not get an 11-36 cassette?
    B) Would you advise going 32 or going 34T?
    C) ok, found that version on my store ... don't know why i didn't see the 11-36 :P
    Oh, So Interesting!
    I need a 32... I live in CO so we have some steep climbs. I can get up pretty steep stuff with a 32 front... extended steep climbs are tough though... if I can't ride up it, guys with grannys can't pedal up it much faster than I can walk anyway. I've rode a bike with a 34 front and it is a significant difference.
    Thank you for your information. 32T it is!
    One last thing ... do you think that with a 32T chainring, 10speed ( 11-36 ) cassette and the short derailleur ... the chain will be too long or will it have a tight fit?
    I'm just thinking that the chain could be a little too long ( in therms of width ) for that setup and i'll have the chain "jumping up and down" like mad ... ( sorry if you can't understand what i'm trying to explain ... i can't find the exact words in english :P )
    Oh, So Interesting!
    You'll need a 10 speed chain, which will work fine, and you'll have to remove a few links to make it shorter... you'll also need a chainguide (like a MRP G2 SL) to keep the chain from falling off your front chainring.
    Yes... that's all covered... only the "removing a few links to make it shorter" was my real doubt ehehhe
    For all you 1x folks out there, I am thnking of dropping my 2x up front and running a 1x. I bought a MRP G2 and now I am wondering if I can just remove one of my chainrings and replace the large ring with a 34T non ramped. Or can I but an older xt or slxcrank and convert it to a 1x. I'm new to this so unsure of the steps to take, like what the heck does the BCD have to do with anything?
    Narrow and rugged is the path that leads to life and few find it.
    > /dev/null 2&>1
    Reputation: Procter's Avatar
    Feb 2012
    Not to persist an old thread, but, to go 1x with an mrp, a 2x won't work, the chainline will be off. You need to use the middle ring on a 3x, or a dedicated 1x crank like a Saint.
    On a 2x, the inner ring will be too far inboard and the top guide on the g2 will drag. You _might_ be able to use washers/spacers to nudge the outer ring inboard, and more washers to nudge the mrp out board, to get it to work, but then you'd be stuck with larger chainrings compatible with this larger BCD. I don't think it will work, but, someone may have tried it. Check the min and max chain ring on your mrp before you go buying parts, i.e. the g2 mini has a max chain ring of 36 i think.
    Bcd governs which chain rings will be compatible with the crank, it has nothing to do with the left-right alignment of the rings.
