Results 1 to 11 of 11
    Reputation: KrisRayner's Avatar
    Should I change stem length for lift service runs?
    I'm hitting up a nearby resort for some lift service runs in a couple weeks and am contemplating changing out my front stem to a shorter one I have. Currently riding a Yeti ASR7 (which has a 67deg head angle with 160mm fork) with a 90mm stem and I have a 50mm stem I'm thinking of putting on. I just don't have any riding time on the 50. Will I be changing the handling too much and jeopardizing me crashing more?
    I've only done lift service once before at a different resort and on a completely different bike. (Yeti 575, all air suspension, as opposed to my new ASR 7, all coil)
    Biking Like Crazy!
    Reputation: blcman's Avatar
    It could throw the handling off ...making it more "twitchy" if using the same bars.
    Should think about getting wider bars also to offset the quicker steering.
    I'm not sure why the went to shorter stems in the first place...for more strength?
    If you are not going to big you might try it as is..but take the shorter stem also.
    edit..shorter stems to get your weight back for the knarly descents!
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Also get a wider bar. Up to the same bit wider each side then the stem is shorter (unless it is already stupid wide). If you are used to 90mm I would have went 70 (and 40mm wider bar).
    +3 on the shorter stem/wider bars.
    Reputation: tartosuc's Avatar
    go for it, lift access with 90mm stem is not ideal.
    how wide are your actual bars? if you ride 685mm or more you will be fine. up until a few years back everyone was riding 685mm wide bars for dh.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Throw it on for a driveway test ride or throw it in your bag for a test ride out on the trail. Only takes a couple minutes to change the stem, throw it on at the top of a decent somewhere in your local trail system and see how it feels.
    As it ends up, I did have 685mm bars (MonkeyLite Carbon XC). They're 3 years old and have seen a few hits, so I rationalized buying new. Easton Havoc Carbon 740mm. I can always cut them down if I decide to later. Gonna try to get a couple local rides in on trails I ride frequently for an accurate comparison. Thanks for the help.
    Biking Like Crazy!
    Hey KR..how far down can you get your seatpost?
    From the pictures it looks like it's a curved seattube?
    You might need to bring a shorter one for the lift area rides.
    Just a thought!
    BTW nice looking Yeti!
    Yeah that's about as low as it goes, it's a long post. Wasn't a problem with RockShox Reverb, but it took a dump on me for the second time and is off for warranty. Might have to cut down the seat post...
    Biking Like Crazy!
    I'd probably just get a cheaper post
    and cut it down for park rides and keep the Thompson intact!
    You'd want a really low post so you
    could do tail whips etc... lol!
    Reputation: Allmtnman's Avatar
    Quote Originally Posted by blcman View Post
    X2 on that for sure!!!
    The more people I meet, the more I like my dog!!!
  1. Pro Moto 17d stem length change
    By akxcer in forum 29er Bikes
    Last Post: 11-29-2008, 06:00 AM
  2. Different stem length for change in h-bar?
    By DLd in forum Singlespeed
    Last Post: 08-20-2007, 07:05 PM
  3. tamer lift runs
    By emvath in forum Utah
    Last Post: 06-24-2006, 07:42 PM
  4. Stem length change with lots of sweep?
    By IBIKEAZ in forum 29er Bikes
    Last Post: 05-30-2006, 07:15 PM
  5. Jones bar - Anyone else NOT change stem length?
    By ATXSS in forum Singlespeed
    Last Post: 04-06-2005, 07:36 AM
