Results 1 to 24 of 24
    Shorter cranks on more aggressive rig?
    8 Hours Ago
    Could anybody help me make up my mind on going for shorter cranks on an AM/Enduro style bike? Iím in need of a new ring, cassette, and BB so now would be the time to do it. Iíve always ridden 175s on everything, Iím 6í1Ē with about 34Ē inseam. I am currently running the 175 cranks from my old bike which had a higher BB than what I am on now (12.4mm drop, 27.5, hefty sag).
    The advantage for pedal clearance is obvious, I scrape and catch my pedals more now and have to watch my timing more but Iím managing. Iím running platform pedals and tend to mash when Iím trying to keep the pace up so Iím a little afraid of losing torque / power to mash climbs and sprints. Does anyone think shorter helps any for control on jumps, manualing, technical terrain or hinders? It seems like longer might actually give more stability for handling since your legs are spread a touch more but I have heard the opposite can be true? I realize weíre talking a tiny change but Iím looking for opinions... 170, 165, or ride what I got? Thanks for any insight.
    Mar 2018
    I recently went from 175 to 170 - primarily because all the new bikes have such low bottom brackets. Pedal strikes improved, and honestly, I find the 170s far more comfortable. I can't tell a difference on power in the slightest, I even think it's maybe more efficient - I do for sure notice my knees like the 170s better.
    I'm basically the same height as you, tempted to throw a 165 on next and test that on a Fuel EX.
    Walt posted some of his experiences with short cranks in the plus forum where he had positive results. However, a few people will invariably argue you lose power. Honestly it boils down to personal preference. In my experience, it's been a huge improvement.
    Having a nice day!
    Reputation: LoneStar's Avatar
    I run a 170 on my FS rig and a 175 on my SS. I think the biggest thing I notice is that I don't notice really any difference. More importantly, I have not experienced any negatives with the shorter crank arm. I'm 5'8" so that may factor into it a little FWIW.
    I am 6' and just put some 165 on my bike to gain pedal clearance. I cannot tell the difference from the 175 it replaced.
    The taller you are, the less it matters I think.
    You mechanically already "fit" a 175mm crank. Im 5'7, I dont fit a 175mm crank. Even with 170's my knees sometimes end up at a weird angle that I cant apply power at.
    Ill admit that even at 5'7 the stallout feeling I get is pretty rare. Riding the same trail, I'll hit that weird stall out on only one section, and maybe once every 3rd or 4th ride. Id benefit from 165's I think.
    Nov 2017
    Quote Originally Posted by One Pivot View Post
    An oval ring would help you with that stallout feeling you are getting as well
    True, but I wonder if ovals are working around a crank length issue! I'll eventually try an oval, but I know stepping down a crank size would be a good move too.
    There's a ton of road focused articles on this, but mtb is finally coming around too.
    Reputation: huckleberry hound's Avatar
    Feb 2015
    I'm 6'1" and I recently put 165mm cranks on my Stache. I absolutely think that it was one of the best purchases I've made. I wrote my thoughts about them here. Paradigm Drift, or OMG, I built myself a bike!
    Change begins by doing something different.
    Reputation: Dr Evil's Avatar
    Sep 2015
    5'4" here on a 2017 Fuel EX-8 27.5+. Went from the stock 175 cranks to 165 cranks. The best upgrade I did to my bike bar none. Pedal strikes are now the exception. I also went with 32T oval. Also, I noticed a smoother cadence on my climbing.
    Oct 2015
    I'm 5'6" 165mm cranks with an oval, I may go to 160s I feel the oval more on tech climbs but it didn't solve the hitch at the top of too long of a crank when I ran 170s
    Thanks for the discussion. I nearly ordered 165mm cranks but decided to compromise on 170mm for now and see how that goes. I didn't want to give up any seat clearance or change bar height, I feel like everything is fairly dialed as it is. I'm sure 170 won't be much of a change but I'm betting I'll like it.
    I'm at the absolute minimum size with my new bike and 165s cranks. It's a 29er and I smash my taco all the time. Had I went with longer cranks (not recommended by bike company) I would've had to reduce the dropper stroke to fit.
    Reputation: s0ckeyeus's Avatar
    This is true. A 6' 1" person can run just about any crank length. But the standard 175mm cranks are too big for lots of people. Sizing down isn't a big deal. Sizing up has disadvantages.
    The one advantage of having a shorter crank is being able to get a better hinge in attack position, or at least not needing quite as much flexibility. The farther your feet are in attack position, the more flexibility you need in your hamstrings to get the ideal position.
    Reputation: vikb's Avatar
    Quote Originally Posted by trailsnales View Post
    I've gone from 175mm cranks to 170mm cranks and back to 175mm cranks on three different bikes. The middle one had a lower BB hence the desire for shorter cranks. Within this ^^ limited range of length I did not notice any significant difference.
    Safe riding,
    Vik
    www.vikapproved.com
    Reputation: ladywrench's Avatar
    Aug 2018
    I'm 5'6'', ride a 27.5 trail bike and low BBs are great but do have their downsides. My knees are also pretty rough so 165mm cranks work great for me and I almost never have pedal strikes unless it's really techy climbing and I'm not in a spot to ratchet. I do not find climbing to be any more of an effort. All pros and no cons in my book.
    Ibis Mojo HD4
    Moots Baxter
    Chromag
    Surface Ti
    All-City Log Lady w/Rohloff
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    It kind of blows me away how often this subject comes up of late. Part and parcel of the low BB's the bulk of bike companies are cramming down our throats these days.
    I like 170's.
    Reputation: movingmountain's Avatar
    Iíve always ran 175mmís on my mountain bikes since the eighties. Iím 5í7Ē and now running 165mm on my Evil Calling. I mistakenly thought I needed the length for levage power. Donít really notice any difference except pedal sticks seemed to be less and my hip flexors arenít as sore on long rides
    Four wheels move my body Two wheels move my soul
    Anytime. Anywhere.
    Reputation: Travis Bickle's Avatar
    I just went 165 from 175 on my 29 HT that has a low BB, especially with the 650b+ I run in the winter. If there is a reduction in power I haven't noticed it yet. Spinning a smaller circle feels good and I'm glad I gave it a shot. I enjoy the low BB, but with big flat pedals and 2.8 650b tires I was having a bit of trouble in some spots.
    I got some bad ideas in my head.
    Dec 2013
    I swapped from 175s to 170s at 5'11" and am never going back.
    Reputation: newking's Avatar
    Nov 2007
    I'm seeing some pedal "scratches" on my Intense Primer when the rear Fox shock is in full travel position. But I am purposely riding that bike through techy situations such as baby heads and rock gardens.
    Not getting hard strikes but some "scratches"
    Bike Has Truvativ Stylo Eagle Boost GXP, 175mm cranks
    Was considering upgrading my wheels then cranks to something like the SRAM Dub XO1 or XX1 in 165mm but noticed they only come in 170 length.
    Difference between 170 and 175mm is a whopping 1/5th of an inch wondering if that would even make a difference and if I would be better off on 165's or 167.5"s?
    I'm 5'8" and ride a medium
    Quote Originally Posted by newking View Post
    Difference for the pedals or for your body ergonomics?
    Doesn't sound like you have pedal strike issues as is, but 5mm can drastically reduce pedal strikes. Having moved from 175mm to 170mm and back to 175mm cranks I don't really notice that +/-5mm.
    Safe riding,
    Vik
    www.vikapproved.com
    I am 6í5Ē and swapped my 175 for 170 mm cranks for pedal clearance. I notice no downside as far as pedaling goes. Good improvement for pedal clearance though. If you are shorter I would not hesitate to try even shorter cranks.
    Reputation: MikeBurnsie's Avatar
    Jan 2011
    You can find the Dub NX and GX level in 165mm at Jenson's. I run 165mm on all my bikes.
    2016 Transition Patrol
    2011 Stump Jumper
    2018 NukeProof Scout
    Bicyclochondriac.
    I don't really find that the "aggressiveness" of the bike or the riding itself really makes a difference in terms of pedal strikes.
    I run the same length on my 80mm HT as on my 140mm AM bike.
  1. Replies: 32
    Last Post: 04-02-2018, 07:24 AM
  2. Replies: 14
    Last Post: 11-01-2016, 07:27 PM
  3. Replies: 34
    Last Post: 06-30-2013, 09:24 AM
  4. shorter travel, yet aggressive enduro frame??
    By mrsa101 in forum Enduro Racing
    Last Post: 05-22-2013, 08:35 AM
  5. Shorter fork=steeper HTA=More aggressive?
    By DefenderOfRock in forum Singlespeed
    Last Post: 04-24-2007, 06:34 AM
Members who have read this thread: 244
