• 01-07-2013
    bullit43
    shimano shadow plus without chain guide
    Hi there,first of all sorry not to use the search function but my browser on the phone doesn't allow to type onde the search box.Is it possible to run a Specialized Enduro with a Shadow Plus SLX derailleur without using a chain device? Basically running all kinds of terrain with some jumping and downhill tracks.
  • 01-07-2013
    bullit43
    No one? :P
  • 01-07-2013
    ptd
    I'd suggest no, unless you are using a XX1 chainring.
    AM Forum
    http://forums.mtbr.com/sram/sram-xx1...ed-818475.html
    DH forum
    Sram XX1
  • 01-07-2013
    shredjekyll
    Absolutely not unless using XX1.
  • 01-07-2013
    denjen
    A friend of mine just built up a Specialized Stumpy EVO with a shadow plus derailleur and an XCX-ST E-Type retention device. He says he has had no issues so far
    e*thirteen components
  • 01-07-2013
    brankulo
    yes, it is possible.
  • 01-07-2013
    006_007
    No reason it is not possible - but you may drop your chain in rougher terrain (same as any other dérailleur)
  • 01-07-2013
    b-kul
    with an unramped ring maybe. but id still expect some drops. the least id feel comfortable with is a ss ring and a xcx type guide. id feel even better with a trs+ or similar and at the end of the day i think an extra 50 grams is worth ultimate chain security.
  • 01-07-2013
    nerofinis
    Go for it. I think you will be impressed with the clutch deraileurs. I have yet to drop a chain although my home trails are pretty buff. Another plus is all your going to hears is your wheels on the ground.
  • 01-07-2013
    markymark
    Tried it, doesn't work. Chain came off front ring at the first rough bit of terrain, and then kept coming off any time it was rough or there were drops.
  • 01-07-2013
    KRob
    Are you running a single ring up front? If, so then other's comments make sense about worring about dropped chains. Probably need some kind of retention device unless going XX1.
    If you're running a double front ring set up then I would think the front derailleur and the clutch rear derailleur would be sufficient to avoid chain drops (maybe not 100% but I think it would be rare).
    I'm planning on using this exact set up on my next bike with a bash guard and may add a chain drop prevention device inside the granny ring (Ronnie Ring) if I have issues.
    Disclaimer: I have rarely ever dropped a chain on my 5 Spot with a triple ring set up and no retention device whatsoever (regular rear derailleur), so I may be a bit insensitive to this problem.
  • 01-07-2013
    b-kul
    ^funny how all of us assummed a 1x setup.
  • 01-07-2013
    ride the biscuit
    I was looking into a potential SRAM type 2 , single ring, and xcx setup for my hard tail. I'm sure they're fine but I got a little spooked by some of the reviewers that experienced failures
    I was surprised to see that happen as I have become a SRAM fan over the years...I am actually astonished at what my x9 ders have lived through
  • 01-12-2013
    sweetp
    I tried the SRAM X9 type 2 and ended up sending it back. I experienced all of the negatives that everyone else has mentioned. Forget about riding without a chain retention device, I tried it. Shifting would bind up in the higher gears, etc. etc.
    I now run my original X9 (non type 2) with a single niner ring in front with bash guard and the n-gear jump stop on the inside. Does not look as cool as an exposed ring but it is cheap and I have never ever dropped a chain. And I ride like an *******.
  • 01-12-2013
    speedraceratl
    I also run a 2x10 setup with no chain retention device other than the Shadow Plus and all is fine. And I ride aggressive on down hills hitting every jump I can.
  • 01-12-2013
    sweetp
    Wow, I have never heard of needing a chain retention device when running a front derailleur. But I ride xc. I can imagine DH/AM type stuff might need it. My experience has been strictly from a 1x10 setup, and I can say with first hand authority that the type 2 will not stay on a 1x setup without a bash or a guide or something. Even on flowy Ohio XC trails. happy trails!
  • 01-12-2013
    cathar
    With a double up front, and a derailleur, no problem, unless you often pedal backwards (i.e. before turns). I run this on my Stumpy, no bashguard either.
    With a single ring / 1x10 - No.
  • 01-12-2013
    rcko
    i ran my fuel 2X10 with rear shiumano clutch DR for a while over teach terrain with very little chain issues. my only drops where the very rare granny drops. and these were mostly me shifting at ethe wrong time when I was already tired.
    you will be surprise by how well they works... i put a bionic c-2 (spelling?) chain tangler and this along with the clucth DR have made my chain drops disappear
  • 01-17-2013
    gsxrawd
    Clutch derailleur are good but they are not 100% fool proof.
    Here is a pic of my XTR clutch rear derailleur. Check out how loose the chain is. To this date I have dropped the chain three times so far.
  • 01-18-2013
    b-kul
    is the clutch adjusted properly? i ask because a while back vital had a slideshow on clutch vs regular and pro dhers on a wc course didnt even have that much movement.
    btw, rokform rules!
  • 01-18-2013
    smellurfingers
    For the lat year my set up is a RaceFace SixC 2x10 with a XTR Shadow Plus and it works perfectly. Haven't dropped a chain yet and my riding is mostly freerideish or aggressive trail, drops, jumps, and high speed really chunky trails.
    If you're dropping chains you have a problem with your set up. That said, when racing DH I will always use a guide. While the chance of dropping a chain is remote, better to be safe than sorry.
  • 01-18-2013
    smellurfingers
    Your chain is too loose.
  • 01-18-2013
    Buzz
    Off topic:How close is your front wheel to bottoming out on your frame/headtube in that picture???:eekster:
  • 01-18-2013
    gsxrawd
    btw, rokform rules!
    I installed it straight out of the box with the factory default setting. I never realized that the chain got that loose until I saw the photo. It works 99.9% of the time so I didn't bother to mess with the adjustment. If it falls off again I'll play with the adjustment.
    That section of the trail is right after a high speed drop. That's pretty much bottom out. I only have 90mm of travel. The wheel will not hit the headtube.
  • 01-19-2013
    rogbie
    This is one of the best components I've ever put on my bike: Bionicon C-guide V.02
    I ride a HT and roll some rough terrain with no chain drops.
    I rode a FS 29er in Moab this year with a clutch derailleur with no chain-guide and the chain slap was far more noticeable than on my HT. Note: I had zero dropped chains on this with this set-up.
    Often, dropped chains are a symptom of cross-shifting or shifting at inopportune moments.
  • 01-22-2013
    mcgong
    I have an XTR shadow +, 1x10 setup, non ramp single ring, with an E13 XCX up front...drop my chain all the time. Played with the clutch, chain is the shortest it can go. After a while, it seems that there is more and more play with derailleur. Not that the clutch is slipping, but the other parts of the derailleur are flexing.
  • 01-22-2013
    kayman121
    Depends on your chainring setup, chain length, cassette, etc. I run a 3x setup up front with an XT Shadow+ and my chain never drops, even through the gnarliest of rut, and I do not have a chainguide. At the very least, it certainly is not a functionality hazard.
