Results 1 to 13 of 13
    Jun 2013
    shimano components. best for intermediate xc: weight vs durability
    Hi,
    I was curious about shimano components: as you go up in their hierarchy do they just get lighter or more durable? I go on intermediate trails. I'm not concerned about component weight as it is small compared to the frame.
    So I am looking at various bikes priced form 1.5k-3k which have components consisting of alivio, deore, slx, xt.
    If I get a bike with xt components will it last a lot longer than slx or deore?
    If I get a bike with xt components and i need to replace them in time, can i do so with cheaper deore components? I mean rear slx derailleur can be replaced by rear deore derailleur?
    Also, although i'm looking at getting a new bike my current bike has a tourney rear derailleur that's broken. I called a bike shop and said if i'm just interested in durability should i replace it with a deore, and they said the deore won't be any tougher, so if you're interested in durability you might as well just replace it with another tourney.
    Thanks.
    Dec 2011
    The components get lighter, more durable and faster/more positive engagement all the way to XT. XTR is lighter than XT and is just as durable but you pay quite a bit more to get it.
    As long as your shifter is compatible you can replace it with any of the rear ders
    it is to my understanding and experience that, once you get to about deore you have hit a reliability marker. shimano trickles down there technology. xtr is hands down the lightest. materials and styling changes as price goes up.
    I work partime at a bike shop. But I do think your bike shop is wrong. tourney has stamped steel parts and ends up on a lot of walmart bikes. prone to rusting and weaker pivot points without the rigidity of the cast aluminum. deore and up is kind of their bike shop quality of line. alivio is not bad, the most similar to deore but a step down. tourney and acera are low quality in my opinion. I would atleast start with alivio. deore is the safest bet for decades of reliability. as you get slx which replaced lx, then xt and xtr styling goes up and weight goes down and price goes up. xtr is where the jump in weight loss is at. especially in cassettes.
    Dec 2011
    I run xt shifters, xt shadow rear der, xt cass and saint brakes with ice tech rotors.
    I'd say if you're looking at bikes that cost $1500 and up, run-don't walk- away from anything that isn't fully spec'd with at least Deore/X7.
    I've had Deore components that have held up super well over the years. Yes, you will notice a difference in quality (crispness, accuracy) as you go up to SLX/X9 or XT/X0, but that fancy derailleur will snap off just as quickly from a rock strike no matter what it says on it.
    I currently run a mix of X9 and SLX, and couldn't be happier. Only my front derailleur (Deore) is original to the bike.
    Reputation: s0ckeyeus's Avatar
    Anything Deore and above is good. I'd try to get a bike with the best frame, fork, and wheels, rather than focusing on just the drivetrain. A bike with XT components will often be better overall than one with Deore components, but not always. Sometimes companies will maximize the drivetrain and skimp on the fork, which sucks since forks are more expensive and not as easy to replace.
    Reputation: phoenixnr's Avatar
    RE: shimano components. best for intermediate xc: weight vs durability
    ^ what he said
    Sent from my SGH-i917R using Board Express
    The whole parts spec, not just the drivetrain.
    Assuming the frame fits properly and has the geometry you need, wheels and suspension will have the biggest affect on how it rides on the trail.
    Jun 2013
    Quote Originally Posted by fsrxc View Post
    what do you think of this?
    Ghost AMR Lector 7700 Bicycle - Mountain Equipment Co-op. Free Shipping Available
    or this?
    Ghost AMR Plus 5900 Bicycle - Mountain Equipment Co-op. Free Shipping Available
    I'd rather get the carbon one, the aluminum one seems heavy
    Quote Originally Posted by mrmojorising8 View Post
    Yes the carbon (Lector) is a great deal - Fox suspension plus XT components plus carbon frame for $2800cdn, but keep in mind it's a 5" trail bike. If you want AM travel and geometry this isn't it.
    The AMR Plus has 6" travel, including a dropper post, but with aluminum frame and lower spec for $2400cdn so isn't quite as good a deal, but a 28lbs 6" AM bike for $2400 is still a decent weight and value IMO.
    Dec 2011
    Reputation: Bigb2000's Avatar
    May 2013
    A cheaper, well adjusted drivetrain will perform better than a bashed up expensive one. Deore is just fine. Replace with XT when/if they wear out. I personally prefer SRAM, except for the XT brakes.
    Everything XT and XTR brakes is the way to go.
  1. Shimano HG94 durability issue?
    By KevinGT in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-30-2013, 06:48 PM
  2. Shimano Alfine 8 versus 11 ... durability question.
    By ModifiedArmy in forum Internal Gear Hubs
    Last Post: 03-26-2013, 07:15 PM
  3. Replies: 4
    Last Post: 10-18-2012, 01:06 AM
  4. Swapping components to reduce weight
    By jbsmith in forum Singlespeed
    Last Post: 09-01-2012, 09:05 AM
  5. 2011 GT sensor components Weight?
    By xs2k in forum GT
    Last Post: 06-02-2011, 11:04 AM
