Thread: Shifter help
    Sep 2017
    Shifter help
    Planning to pick up a trek precaliber 25 for my little guy with 21 speed, 3 up front 7 in the back. Unfortunately it comes with those twist shifter which I hate. Is there a set of triggers like the sram x-5 s I have my bike I could swap them out for? I'm new to this but an excellent mechanic. Any help appreciated thanks guys
    Less yap more braaap
    Reputation: Tier1's Avatar
    Apr 2015
    From what I understand it is replaceable (just taking a look at my mom's Kirkland special Infinity bike) you pretty much need to take the whole assembly apart then replace the shifter and grip. Not sure about the pull ratios or anything but you should be able to get away with using an older Shimano Acera or Altus that does 7/8 speed and kind of wangjangling it to work (I was able to get a 9 speed Deore LX derailleur working with my 8 speed beater bike even though the pull ratios were supposedly slightly different by playing with the limit screws and such). If you have one in your town look for bicycle co-op's or university volunteer bike shops.
    Reputation: Lone Rager's Avatar
    Dec 2013
    How does your little guy feel about the twist shifters?
    I believe the following will work:
    Altus SL-M310 ESLM310R7AT and ESLM310LBT, right and left shifters.
    Do the math.
    The Precaliber uses a SRAM rear derailleur with 1:1 actuation ratio, so you will need SRAM X3 shifters unless you want to replace the rear mech with Shimano or try to hack it somehow.
    https://www.ebay.com/itm/SRAM-X3-Bic...IAAOSwiYFXISO~
    Source: I have two GF Precalibers
    For what it's worth, my little guys seem to be OK with the twist shifters, although I have been thinking of going trigger.
    The front rings give them the most trouble, and they would be a problem with triggers, too.
  1. Help with Front shifter. Need a shifter which only shift one ring.
    By Hasse S Andersson in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-10-2013, 11:37 AM
  2. N00b shifter question: depressing the right-hand shifter all the way
    By Grease Monk3y in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-19-2013, 05:52 AM
  3. Replies: 1
    Last Post: 02-27-2013, 12:04 PM
  4. XT 770 rear shifter vs. XTR 980 rear shifter
    By Slow Danger in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-05-2012, 10:01 AM
  5. XTR M970 3 ring shifter work as a 2 ring shifter?
    By SCR818 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-09-2011, 10:52 AM
