Page 5 of 85 FirstFirst 1 2 3 4 5 6 7 8 9 15 55 ... LastLast
Results 101 to 125 of 2110
  1. #101
    How do I do that?
    Reputation: Tuff Gong's Avatar
    Quote Originally Posted by highaltitude
    Thanks a lot, this was easy and obvious really. This is what the insides look like:
    Crap, what are the chances of being able to source that replacement plunger? There is obviously a strong reason RS has an illustration not to place the bike upside down in case it rests on the plunger but that just further reinforces concerns over the remotes weakness in the event of a crash
    I need to def mount the remote on the bottom somehow....
    Good luck with getting your post back in service High.
  2. #102
    Quote Originally Posted by Tuff Gong
    Agreed. Unclekittykillers pics are giving me hope. For the number of times I use the front derailleur, I think I'm willing to dremel off half of the shift lever if it means tucking the remote underneath.
    Of course, this is all assuming I can guarantee getting a right hand remote when I order the post. Has anyone received a left hand remote or is it coming only with the RH?
  3. #103
    I'm more of a dog person
    Reputation: unclekittykiller's Avatar
    Feb 2006
    i actually ordered a lh remote from my lbs and i got the rh version. seems like most are getting the rh. car nut, I hardly use my fd as well, only on real steep climbs, otherwise i stand up and mash. my lh shifter isn't exactly where i like it anymore, but i'll use the reverb remote more than the fd anyhow, so a little bit of shifter displacement doesn't bother me when i have the remote right where it like it.
    i would imagine that placing the remote under the bars would be even easier if used in conjunction with some avid xx or xo brakes using the remote as the lever clamp (upside down). i would think it would leave more room on the bars to place the shifters wherever you like.
  4. #104
    Feb 2006
    any idea what the purpose of that thing that looks like a staple is? i noticed it on my remote but couldn't figure out it's purpose. i can only imagine it holds something together, but what?
  5. #105
    How do I do that?
    Quote Originally Posted by unclekittykiller
    any idea what the purpose of that thing that looks like a staple is? i noticed it my remote but couldn't figure out it's purpose. i can only imagine it holds something together, but what?
    I'd guess it secures the remote body side of the rubber boot You could see the indent it left on the boot....if I'm even close to being correct.
    edit:Wait a minute? Does it keep the plunger from coming completely out of the body? Does it secure both the plunger and the boot to the body?
    Well, I just tried working the RH remote on the left side with my X7 shifter and Juicy 7 levers. I'm not too crazy about the shifters position but if I grind away the corner of the downshift lever, I could swing the shifter closer down to normal.
    I'll have a couple of rides before I attempt to grind away...
  6. #106
    Quote Originally Posted by mountaindavis
    are you folks running this shock using friction paste? If so, did it come with it?
    The friction paste is not included with the Reverb.
    I'm using carbon installation compound. I suspect the necessity of the paste is directly related to how snug the post to seat tube fit is on your bike.
    I did not originally use the paste and did not encounter any slippage when clamped well under the max torque. The paste just allows me the option of using a bit less torque.
    This is the stuff I sourced:
    http://www.jensonusa.com/store/produ...n+Compoun.aspx
  7. #107
    Feb 2006
    your guess about the staple sounds pretty logical, i wouldn't doubt if thats correct.
    your shifter looks to be almost too uncomfortable tweaked that much..do you think it would work better if you put the shifter to the left of the brake lever and angled the remote more forward?
  8. #108
    Reputation: in the trees's Avatar
    Mar 2005
    Here - http://www.universalcycles.com/shopp...s.php?id=37132
  9. #109
    highaltitude;
    tough luck...
    Let us know what path you took (contact vendor, contact Rockshox) to get the new part...
    Here's a list of the part numbers (sourced from Spare Parts List on Rockshox website) http://www.sram.com/en/service/rocks...D=3&subcatID=1
    Part numbers for the remote start on page 6, I believe the XLoc actuator is detailed on page 28; piece #18 (p/n 11.4315.014.020).
  10. #110
    I found this as a source for replacement parts for the lever, check pic 7. I was debating whether to replace the whole thing for $65 or just the piston kit for $31. After I managed to remove the broken piston head, I just went for the cheaper option.
    http://www.outsideoutfitters.com/p-1...kit-parts.aspx
    I didn't see much point in contacting Sram, and I bought the post from overseas - and there's zero chance the local importer will have spares.
    The little staple locks the hard plastic end of the rubber boot in place, there are little indents, I also seem to have cracked this part. When the lever is extended, the piston head must butt up against the plastic end of the boot.
  11. #111
    XLoc Piston Source
    The silver piece (circled in red) seems a bit different from the parts you took apart, however since the piston is all you need, you should be set. Thanks for the information.
    Here's an addtional source: http://www.universalcycles.com/shopp...s.php?id=37132
  12. #112
    CHOP!
    Reputation: MartinsMental's Avatar
    Dec 2005
    Quote Originally Posted by highrustler
    Just received this from SRAM tech support. This will be on their website within a week or so
    Official Reverb Bleed instructions are up.
    It's not where it's made but how it's made.
  13. #113
    Quote Originally Posted by MarkHL
    Good point, I hadn't noticed that part. It looks like a spacer, so hopefully it will be easy to remove by taking off the button and the boot.
  14. #114
    BMJ
    BMJ is offline
    "42 lbs and climbing!"
    Reputation: BMJ's Avatar
    You might need to check that part on Universals website as a viable replacement. The part number doesn't match the Reverb part number. All the pics I've seen of the X-Loc remote for the forks look like a shorter throw than the Reverb. Maybe the silver bushing is just a travel limiter.
    Hmmmm.
  15. #115
    Reputation: mountaindavis's Avatar
    Jun 2010
    Looking at the SRAM's instructions for bleeding, it shows clamping the bike in a stand using the lower part of the seatpost (not the part that extends up) which is good as I was concerned how I was going to clamp my bike once my seatpost arrives (tomorrow! Although we are getting snow right now :-( ). I thought I read in this post that we couldn't clamp it at all, but they clearly show it is alright to do so...
  16. #116
    Threading freely...
    Reputation: polymathic's Avatar
    Oct 2010
    To add to the thread.... My Reverb wasn't working out of the box. Didn't lower or rise. First, I bled it at the remote with one syringe. Finally it went down, but not up. Stuck a second syringe in the seatpost bleed hole and went from syringe to syringe. Now the Reverb works perfectly. Lots of bubbles in there prevented from working at all. Very smooth action now. Thanks all for sharing your experience here. If it wasn't for this thread, I'd have returned the seatpost thinking it was defective.
  17. #117
    Nov 2006
    I am trying to see if I can run a RH remote on the left side of my bars, with a front shifter (xtr), possibly by mounting it well inboard of the shifter. Could someone currently running a Reverb post the distance from the handlebar to the outside of the remote body. Aka. how much free space needed perpendicular to the bar to clear the remote? That would be awesome. Thanks!
  18. #118
    Reputation: Jamie_MTB's Avatar
    Does anybody know how the sram 2011 x0 brake attaches to the reverb lever?
  19. #119
    Feb 2006
    Quote Originally Posted by toons101
    you can use the reverb remote in place of the lever clamp.
  20. #120
    Quote Originally Posted by Huck Pitueee
    Thanks.I'm gonna call them this morning.
    Check out Tree Fort Bikes. They are running a sale until 11-19 for $235 and free shipping I just ordered mine. Plenty in stock. Get in there and get one for cheap
    380mm:
    http://www.treefortbikes.com/product...djustable.html
    420mm:
  21. #121
    got my reverb today. first impression is dissapointing.
    It is binding half way through the travel and not coming all the way up. hopefully it will break in and be more smooth. I also plan to bleed it.
    play in the seat is a hair more than my 6 month old kindshock. not enough to detect while riding and certainly lots less than the joplin.
    by far my biggest gripe is that using the right remote underbars on the left bar really doesnt work very well, even with no shifter on that side. Im using XT brakes mounted inboard for 1 finger braking and the lever is too close to the grips (interferes and bangs your thumb) if mounted outside the brakes and waaay too far away if mounted inside the brakes. maybe it works better if you have the angled MC of the avids...... (but no way im switching to those crappy brakes)
    syringes, hydro fluid and some of the cable snaps are nice bonuses. (cable snaps only work if you have another cable to clip it to though)
  22. #122
    Threading freely...
    Oct 2010
    Evan, once you bleed it the action will smooth and perfect. It wasn't even working in my case until a serious bleed. It does have more play than I'd wish, though. That's the only issue I have so far. But it's very small play....
  23. #123
    Reputation: hani1's Avatar
    Concern about full extention length
    So a fully extended reverb may be about 1/4 to 1/2 in too long for me. Is this a major concern? Has any one else had this problem?
  24. #124
    No, that's not phonetic
    Reputation: tscheezy's Avatar
    Quote Originally Posted by Evan55
    That is a classic symptom of the seatpost collar being too snug. Try to loosen it up by just a hair at at time until you get it to work smoothly. If you need to loosen it so much that the post ends up slipping on rides, well... that's SRAM's bad for making the outer wall so thin on the Reverb.
  25. #125
    Quote Originally Posted by hani1
    Probably a good thing; with the post fully extended, the telescoping section will not have as much support from the tube and is more vulnerable to damage due external forces placed on it.
    My personal opinion is that prolonged riding with it fully extended will hasten wear on the tight tolerances due to the additional leverage and reduced support between the mating surfaces.
    My reason for this line of thinking is, I can feel a slight fore and aft play in the seat tube with it fully extended that I cannot detect in any other inserted range.
    After a bit of practice, adjusting the post to your preferred "top" height will be no harder than any other seat height adjustment.
