Results 1 to 14 of 14
    Reputation: lotusdriver's Avatar
    Sep 2013
    Rock Shox Sektor TK Solo Air, should I upgrade?
    How good is this fork? It certainly seems to work OK but my arms still take a hammering on certain surfaces.
    Cobbles for instance, or rocky surfaces taken at speed, cause me to want to slow down.
    On more undulating terrain without stutter bumps it is a lot better. The travel is 130mm and I am running the air pressure fairly low (70psi, at the bottom of the recommended range for my weight)
    I tried dropping the pressure further but then got excessive bob when pedalling. But at 70psi I am still getting about 120mm max during a ride so am using most of the travel.
    Now I only recently returned to mountain biking and I am unsure as to how much to actually expect from mountain bike suspension. It makes a big difference if you lock the fork out! So it is making things a lot better.
    There is one part of my regular ride which is a steep cobbled track, on this the fork seems unable to keep up, although it is way better than no suspension at all.
    But would there be a big advantage in upgrading to a better fork. For instance, the Rock Shox Pike is half the price I paid for the whole bike, in what way will it be better? Will my arms take less of a pounding on fast rocky descents or are the improvements elsewhere (more adjustments for instance)
    meow meow
    Reputation: b-kul's Avatar
    upgrade to a moco cart. like 100 bucks and should help a lot.
    Nov 2012
    The fork is fine. The main suspension comes from your body so, you have to use your legs and arms as suspension. Try not to be so tightened and move your body in order to absorb the vibretions from the terrain. So move your body and be more relaxed.
    meow meow
    ^what the op describes sounds like the fork is packing up or being overwhelmed. a different approach wont help that much.
    Reputation: paxy's Avatar
    Adjust rebound?
    Not only is my short term memory horrible, but so is my short term memory.
    Sep 2013
    Thanks, l will try it, the rebound is currently set at just below half.
    Position 7 out of about 16.
    Sep 2013
    An update on this thread.
    I reduced the air pressure to 65psi and backed off the rebound damping to position 3.
    I also took advice and fitted the Motion Control cartridge (mainly for the remote lockout)
    The fork is now working much better.
    Reputation: nauc's Avatar
    what bike is it. if FS, which shock are you using and whats your sag set to, front and rear
    Sep 2013
    The bike is a 2013 Tanuki Deluxe FS.
    Shock is a Monarch RL
    Sag is about 30% on the shock and 30-40% on the fork.
    This seems to work well for me, l weigh 160lbs. When l get back from a ride the shock and fork have used pretty much all their travel.
    May 2013
    Did you ever take it apart to check and see if there is a spacer limiting the travel from 140 - 150 mm? I have the same fork that came on my bike and from what i read i think it can have more travel. Mine works pretty good an I beat the hell out of it. If I could have a bit more travel I'd do it. Soon I will take it apart to find out.
    Sent from my SCH-I535 using Tapatalk
    Sep 2013
    Where would the spacer be located? I will have a look.
    Dec 2013
    Did either of you ever check this out? I know I'm bumping a nearly year-old thread, but I recently got a 2014 OEM 650b Sektor Silver TK with my new bike (the 2014 version should be very similar if not identical to the 2013 OEM forks) and haven't been able to get a 100% definite answer to the travel-extension question on this version of the fork.
    There do appear to be travel spacers as part of the general 2014 Sektor design, but I haven't been able to confirm how long the air shaft actually is on the OEM 650b 130mm version. If it's a full-length 150mm shaft, then there should be two spacers that can be removed with no further work....if it's only a 130mm shaft, then I'd have to get a replacement air shaft to change the travel. Knowing the answer would be very nice before I go opening my fork up or having to wait on having my LBS do the work....
    May 2013
    Quote Originally Posted by Ryan Meader View Post
    I'm not much help but I still haven't pulled mine apart... I plan on doing it soon for a rebuild. If there are spacers I'm taking them out
    Sep 2013
    I am still using this fork.
    I am guessing the spacers must be in the air valve side (left fork leg when sat on the bike) as the right leg has the rebound/lockout cartridge in it.
    However l have not had that side out yet.
  1. rock shox sektor rl
    By b-kul in forum Shocks and Suspension
    Last Post: 07-03-2013, 10:22 PM
  2. Pick one!!! ROCK SHOX DART 3 or FOX TALAS RL or ROCK SHOX SEKTOR???
    By Tattootimmy in forum Shocks and Suspension
    Last Post: 06-18-2013, 01:47 PM
  3. Rock Shox Sektor TK solo air
    By jdcatnau in forum 27.5
    Last Post: 02-23-2013, 08:20 AM
  4. Rock Shox Sektor Solo Air travel adjustment
    By trailrider24 in forum Shocks and Suspension
    Last Post: 12-23-2012, 03:15 AM
  5. Rock Shox Sektor R or $200???????????
    By urmb in forum Shocks and Suspension
    Last Post: 06-07-2012, 11:56 PM
