Results 1 to 20 of 20
    Rock Shox Reverb IFP Bleed Procedure?
    Reverbs stop working on a somewhat regular basis. RS will repair or replace them, but sending them back takes time. So... can we fix these ourselves?
    RS now offers the IFP height tool and a bleed tool. They don't seem to have published instructions however. Does anyone have accurate instructions for doing the IFP bleed?
    The "push IFP all the way down and fill the inner tube with oil" approach isn't right. It results in incorrect IFP position.
    I got seemingly good results by:
    1.) Pushing the IFP all the way down.
    2.) Filling the inner tube with oil.
    3.) Putting the small piston back in the inner tube and screwing the cap on.
    4.) Pushing the inner piston down with button depressed to displace oil into IFP chamber.
    5.) Unscrewing the cap and checking IFP depth with IFP tool.
    6.) Screwing the cap back on, moving the inner piston as needed to adjust IFP height (repeat 5 and 6 until IFP height is right). Finish with the inner cap on and tight.
    The IFP height should now be right... next bench bleed and get the inner piston back to the fully extended position....
    7.) Removing the small snap ring on the top of the post, pull out the washer and top cap, pull out the remote circuit piston with needle nose pliers. The IFP chamber should be separated functionally from the inner tube now since the remote piston is out.
    8.) Pull the inner tube piston out until in fully extended position.
    9.) Add oil through hole where remote piston goes until it is filled up to the narrow hole the thin part of the remote piston goes into.
    Now IFP height should be ok, and your inner tube piston should be in fully extended position.
    10.) Replace remote piston, cap, washer, circlip.
    11.) Bleed remote circuit.
    The result is a post that is firm when pressing down on the seat. Feels perfect, no movement. But... when the post is partially compressed, if I lift up on the seat the post extends. When I put the bike down it goes right back where it should, like there is a vacuum somewhere in there. I don't remember it doing this before...
    What could be wrong? I am certain there is no air in the circuit.
    Is there a proper set of instructions?
    When in doubt check Youtube... here ya go
    Quote Originally Posted by fracaxis View Post
    That is the procedure for bleeding the remote line, not for bleeding the internals of the post. Bleeding the remote line is very easy, doesn't really require instructions. The internals are the mystery.
    My bad.
    I'm coming up short on some comprehensive instructions too. I just started running a reverb and will undoubtedly be popping mine open at some point. So far so good, but its just a matter of time. I'm hoping its user serviceable as well.
    I've been pouring over your procedure for a while now. It seems sound. FYI - i did just go check mine (only 3 rides old) and it extends the same way when lifting the bike. I have to "help it a bit by lifting the seat and pushing down on the frame at the same time. Same result that you have, seat lifts then when released suck back down. The "vacuum" is probably just the air chamber behind the IFP pulling back down.
    Reputation: jaknudsen's Avatar
    Do any of you know the actual lengths for the markers on the IFP height tool?
    SRAM has a good video for the procedure now:
    <iframe width="853" height="480" src="http://www.youtube.com/embed/rbHc4V6Ei14" frameborder="0" allowfullscreen></iframe>
    Mar 2006
    Whoa, where did they get that adjustable crow foot adapter?!!
    Mar 2006
    So has anyone worked out the heights of the height markings on the IFP height tool?
    Dec 2012
    same question, So has anyone worked out the heights of the height markings on the IFP height tool? help ..
    I wonder if there's also a way to bleed the unwanted air out of the inner oil chamber without having to pull the whole thing apart.
    Okay so I've successfully done mine now. I didn't use a...."bleed tool" or an "oil height tool". Instead of the bleed tool I just stuck a snug plastic pipe into the post head and clamped it with one of those red clamps.
    Here is the reason for the "oil height tool": You want hydraulic fluid/oil above the bottom of the "poppet" valve (in green below), but you don't want fluid in the black (gap) next to the valve. It needs air in that black space, so that the valve can move downwards. When you press the button on the handlebars you are trying to move that valve downwards - but it won't be able to if you've got incompressible hydraulic fluid in that gap.
    I just sucked a bit of fluid out with the plastic tubing - guessed it. I've probably got a little air in the internal hydraulics but not enough to notice any difference in performance.
    n/a at n/a in Chilliwack, British Columbia, Canada - photo by mikelevy - Pinkbike
    p.s. Using a picture of the oil height tool, figuring out it's approximate real-world diameter, and doing some scaling I worked out that the markings on the height tool are, in fact, 100mm and 125mm from the bottom of the tool. Quite convenient. I have a 125mm travel post so pushed the IFP in 125mm.
    p.p.s. You DO have to bleed the remote hose after this because you have opened the remote hydraulic system as soon as you remove the "poppet" valve.
    Hope this helps.
    Jun 2014
    Hi all,
    I recently purchased a used Reverb which had about 1-2" of sag when fully extended. Once below about half length, the sag vanished.
    After a lot of Googling and several trial-and-error attempts, I thought I'd document here how I fixed it as it may help others:
    • First I bled the remote circuit as per the SRAM instructions using the two syringes from the bleed kit (actually, a third party Avid kit, but it worked ok ) - no change to the sag
    • I then repressurised the air cylinder, which was a little low on air - no change
    • I then watched the four "full service" videos on the SRAM page, which while being cool, seemed to need proper parts to sort. "Specialist tools? We don't need no steeenking specialist tools...."
    Here's how I finally fixed it. Assuming that the sag was air, I decided to try to get rid of it:
    1. Depressurise the cylinder and, using the remote, fully depress the seatpost. Depressurise the seatpost again! You really don't want any air left in it or you'll get a face full of oil and metal when you remove the top circlip!
    2. Clamp the post into a vice, taking care not to scratch it. I had no aluminium jaws, so used cardboard - worked ok
    3. Very carefully, remove the small circlip at the top of the post. Even when pressure is removed, it comes out with a pop - be ready to catch the bits!
    4. Remove the circlip, retaining washer and small metal top cap
    5. You should now be able to see the main valve. Using needle-nosed pliers, remove it using the spike on the top.
    6. You can now peer down into the main oil cylinder. I then carefully added enough oil to reach just past the bottom of the piston. (see below)
    7. Replace the piston - it needed a firm wiggle to get it properly seated and pushed down.
    8. Replace the small metal cap, washer and circlip.
    9. Re-bleed the actuator circuit, as you've just emptied half of the oil out of it
    10. Hopefully, you're fixed!
    I had to repeat this three times until I found the correct amount of oil to have in the cylinder. Once done, however, the post feels like new and I'm well chuffed. Obviously, you can change any seals you come across, but I didn't bother. I'm going to see how I get on with it over the coming weeks.
    This process is miles and miles from the one in the SRAM videos and, ultimately, sucks as it's hard to get all of the air out this way, but it's easy (takes me 10 mins) and needs no specialist tools other than the bleed kit (which you *do* need to bleed the actuator circuit and will need if you remove the top cap like I did).
    Quote Originally Posted by daern View Post
    ....[*]You can now peer down into the main oil cylinder. I then carefully added enough oil to reach just past the bottom of the piston. (see below)[*]Replace the piston -
    Sorry but what the heck is the piston?
    Jun 2014
    Quote Originally Posted by peanutaxis View Post
    It's the green bit from here:
    http://ep3.pinkbike.org/p3pb7346907/p3pb7346907.jpg
    I.e. the main actuating valve
    Reputation: somanygoodbikes's Avatar
    After having just followed this set of steps to fix a post with a bit of free movement at the top of the stroke, I thought it might be helpful to add a few extra comments.
    Between step 5 and 6 above -- make sure you extend the post again. Also add some pressure to the air spring. If you don't, you can add too much oil. If you do that, the post will work but not be able to use full travel. In my first attempt, I added fluid when the air piston hadn't gone up, and only had 60mm of travel before it hydro-locked, not the 125mm I should have had.
    If you don't extend the post before topping off the oil, then when you pump it up, the air pressure makes the post compress! Very odd.
    The other tip I have is that the hose on the syringes they supply is the same diameter as the piston. So if you want to set the oil level to the bottom of the piston, you can just remove the brass adapter from one of the syringes, and stick the hose down the hole the piston goes in. The bore narrows where the piston bottoms out, so you can't go too far. Then if you draw on the syringe it will suck up any fluid above the spot where the piston bottoms out, which is right where you want the oil level. Just press the adapter back into the hose to use it for the bleeding process.
    Giant Reign 27.5 2 LTD
    Reputation: ka81ua's Avatar
    Oct 2014
    Going to buy a new https://www.bike-components.de/en/Ro...B-0-mm-o24197/
    and wondering what to buy "for a future" if really needed..
    1) https://www.bike-components.de/en/Ro...versal-o10001/
    2) https://www.bike-components.de/en/Ro...rkzeug-p39217/
    3) https://www.bike-components.de/en/Ro...versal-o10001/
    what are they for and do someone really need them to bleed RS Reverb at home?
    OK
    Oct 2014
    can someone upload hidden video (4 parts) from RockShox ?
    I guess it was there some years ago - https://www.youtube.com/watch?v=XxgUK3gC_Fk
    OK
    Jan 2017
    Hi can you please specify the step 5 and 6. I do not understand from the text
    Quote Originally Posted by somanygoodbikes View Post
    Jan 2017
Members who have read this thread: 7
