Results 1 to 6 of 6
    reverb cable replacement?
    I need to replace the cable on my reverb. like a genius i cut it too short. what do I need to order for replacing it??
    Don't be a sheep
    Sep 2004
    Quote Originally Posted by mastakilla
    Should just be standard hydraulic brake line.
    "Do not touch the trim"
    I think you want xloc hose - the reverb uses oil and not brake fluid and I think that requires a different type of hose. Good news is its 6$ for two hoses.
    http://outsideoutfitters.com/p-15805...kit-parts.aspx
    I'm more of a dog person
    Reputation: unclekittykiller's Avatar
    Feb 2006
    no its not a standard brake line its just a single layer hydraulic hose. just get your lbs to order you a replacement hose for the reverb from rockshox. they'll understand what you need.
    Nov 2007
    Quote Originally Posted by Ansible
    these hoses from the Xloc of the Rock Shox forks are too short, only 460mm.
    for the reverb you need 1200mm hoses or even more
    Reputation: Mt. Tam Haze's Avatar
    anybody have experience replacing a broken hose line. BUT with a catch, the hose broke while the seat was not fully extend, which is required as a part of the instructions to replace the cable? i think im just going to call sram but if so let me know
    thanks
