Results 1 to 5 of 5
Thread: Reverb Broken?
    ಠ_ಠ
    Reputation: dulyebr's Avatar
    Reverb Broken?
    took a couple of months off riding, when I got back on the bike, noticed that my Reverb, which was previously perfect was *really* slow. It worked, but just not that well. I went ahead and suctioned off the the air bubbles in the trigger mechanism, but instead of making it faster (like last time), it made it not work at all. I went ahead and bled the whole system, but now the trigger seems to have no resistance, like the piston is not actually pushing on anything. Any ideas?
    Quote Originally Posted by dulyebr View Post
    Did you forget to put it to the slowest setting before doing the bleed?
    Do it on both ends, at the same time...pull a vac and then pump some fluids back and forth. When I bled my 2nd one (I have one on each of my two bikes) that I picked up from a Craigslist ad, I had to pull a vac from both ends. After that, 100%. But before that when I did it from the remote end alone...no dice.
    meow meow
    Reputation: b-kul's Avatar
    in addition to what pau11y said you have to do a remote bleed after a full system bleed.
    Quote Originally Posted by b-kul View Post
    You are so correct.....and also it does not hurt to make sure it has 250 psi in the air side also, I run nitrogen in them but you do not have to
    ಠ_ಠ
    i'll call sram and report back
  1. Where to send my reverb?
    By hvmathews in forum All Mountain
    Last Post: 07-17-2011, 08:23 PM
  2. Reverb from 31.6 to 30.9
    By Jingleman in forum SRAM
    Last Post: 02-17-2011, 09:09 AM
  3. New Reverb not going down?
    By manamana in forum All Mountain
    Last Post: 12-13-2010, 09:59 AM
  4. GD Turbo Vs. RS Reverb???
    By aaron81fire in forum All Mountain
    Last Post: 12-01-2010, 05:53 AM
  5. DT Reverb
    By tmpaints in forum Knolly
    Last Post: 11-25-2010, 07:21 PM
