Results 1 to 5 of 5
    Mar 2013
    Rear suspension adjustment questions
    I recently got on my first full squish AM/Enduro and have been somewhat baffled with how to tweak the rear suspension. My bike is fitted with a Dyad RT2 that normally comes stock with Cannondales (Jekyll, Trigger, Claymore--mine's a Scarlet). I am 108 lbs. and at the bottom limit for the rider weight recommendations provided on the website. I have it set as recommended and it feels a little too stiff. I've read other forum posts relevant to setting up the Dyad and most recommend running it lower by 2-3 below the recommended weight on the chart. Since I am at the very bottom weight of the recommended limits I am not sure if I should try to go below that and risk being outside the recommended pressure range.
    Do I risk damaging the shock by going below manufacturer's recommendations? How do you suggest I set my rear shock to get more "squish" out of it as it is rather on the stiffer side while following the recommended setting?
    I'm hard yet soft, I am coloured yet clear, I am fruity and sweet. I am jelly. What am I?
    Reputation: nauc's Avatar
    youre jelly!
    gone walk about
    Reputation: nvphatty's Avatar
    Mar 2012
    since we are jelly due to your dilemma my suggestion is to experiment with going low and see what happens with the ride.
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by TikiGoddess View Post
    Email Cannondale and ask them.
    Some shocks can suffer from malfunctions when run at under minimum pressure as the internal pressure is needed hold IFPs in place and/or damper ports/valves shut. Whether that applies to the Dyad I have no idea, but Cannondale will know.
    Mar 2013
    Quote Originally Posted by Fix the Spade View Post
    Right-- I guess it is best to ask them before I risk running low and voiding my warranty. I generally don't mind the somewhat stiff ride running manufacturer recommended pressure but thought I'd ask if anyone's ever gone lower without any adverse consequences to the rear suspension. Thanks for the input!
  1. Replies: 5
    Last Post: 05-01-2014, 07:44 AM
  2. Avid Elixir 5 adjustment questions
    By skinnedshin in forum Brake Time
    Last Post: 08-01-2012, 09:47 AM
  3. Replies: 3
    Last Post: 01-13-2012, 04:30 PM
  4. drivetrain adjustment questions
    By dth656 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-29-2011, 06:49 PM
  5. RP23 adjustment knob questions
    By 99mikegt in forum Shocks and Suspension
    Last Post: 04-21-2011, 06:10 PM
