Results 1 to 13 of 13
    Reputation: robncircus's Avatar
    Jan 2011
    Question for Fox DOSS owners
    Searched and didn't see this in any of the threads. I recently bought a new 5"doss. Took it out of the box and it looked short - measured and it's around the 4" mark. Box says 5" post and the post itself says 5 on the shaft. Question is do these come preset in trail mode? Any ideas why it's measuring 4? I couldn't find any info about this online or in the manual. Haven't installed it yet so I may give that a shot to see if it extends to 5". Post comes prepressurized so it's not that. Thoughts?
    Rob
    Sent from my XT1030 using Tapatalk
    Jan 2011
    Well I installed the post today. Popped up an inch once the cable went in. So that answers that.
    All Fun Rider
    Reputation: pixel_nut's Avatar
    Jun 2012
    What kind of shifters/brakes do you have and how well does the dropper lever interact amongst everything else? Curious about this post, really wanting one.
    Jan 2011
    Re: Question for Fox DOSS owners
    Quote Originally Posted by 50mm View Post
    Hi
    I run SRAM XO1 with XT brakes. I am using the lever in an inverted position on the left side where a shifter would normally go. The lever is pretty big, and it sits at about a 40 degree angle inward. However once I got used to it I found it was fine. I used a Kronolog and Lev in the past. Liked the Kronolog, found the Lev to be horribly unreliable. The Lev had the best feel of the 3 though (when it worked).
    Hope that helps
    Jan 2011
    Couple pics for reference...
    Reputation: MSU Alum's Avatar
    I have mine on with the mount reversed, so that the lever is closer to the bars and it "feels" just like a shifter (I also have the 1x11). Mounted as you have it looks very awkward.
    Edit: I didn't mean that to sound quite so judgmental.
    Sent from my SM-G900V using Tapatalk
    Jan 2011
    Quote Originally Posted by MSU Alum View Post
    this looks correct. how'd you get it like that? couldn't figure it out
    Mar 2013
    Quote Originally Posted by robncircus View Post
    His is what mine looks like too.
    There's 3 positions for how far out you want it. When you mount it under the left bar you'll have to flip it around too. The manual shows you how to do this.
    You'll need to flip around part #17 below if you want it like MSU Alum has it (opposite of how the pic in the diagram is oriented).
    I'm running a DOSS with 2x10 XT (I know, SO 2012...) so the lever is mounted on top of the bars. I was really concerned about breaking the lever when I first got it, but haven't had a single problem with it. The lever looks gigantic, but it seems to keep out of the way in the occasional crash. Its also the easiest multi-stop dropper to hit IMO. As far as the post itself is concerned, I mounted mine at the beginning of last season, adjusted the air pressure to my liking, and haven't done a single thing to it since. It just works, consistently, every time. Pretty happy with it.
    Jan 2011
    Quote Originally Posted by Alias530 View Post
    thanks I figured it out. common sense evaded me on this one. so much better now.
    Sep 2013
    I'm running 2x as well, but switched my front shifter to a grip shifter so I could run the lever under the bar. Works great.
    Mar 2013
    I just got my doss, and I got a question. When you pop it up, is yours really loose? You have to put a little pressure on the seat for it to lock in place..
  1. Fox DOSS worth the $$?
    By kayman121 in forum All Mountain
    Last Post: 09-23-2013, 09:20 PM
  2. Replies: 7
    Last Post: 08-02-2013, 07:29 AM
  3. SS to DosS
    By dbhammercycle in forum Singlespeed
    Last Post: 06-11-2013, 09:23 AM
  4. DOSS vs. LEV vs. Reverb
    By kragu in forum All Mountain
    Last Post: 03-19-2013, 01:32 AM
  5. iBis HD owners.. i have a question..(noob question)
    By superunknown222 in forum Ibis
    Last Post: 08-07-2011, 09:59 PM
