Results 1 to 10 of 10
    Nov 2012
    Proper size for Yeti SB66
    I am looking at Yeti SB66 and I am unsure what the right size is.
    I am 6'0" without shoes so with shoes I am 6'1" and 190-195lbs with my gear . Looking at the Yeti website I should be looking at Large however does SB66 runs larger or smaller than other bikes?
    Reputation: KRob's Avatar
    The SB66 runs large. I normally ride a large frame at 5' 11.5" but the medium we tried at Interbike felt just fine. Didn't get a chance to try a large so not sure if it would've felt even better, but I know the tt runs long for a given size on that frame.
    Isaiah 58:14
    www.stuckinthespokes.com
    Nov 2012
    meow meow
    Reputation: b-kul's Avatar
    if you are looking to run a super short stem i would look at a large. big advantage imo to get your stem as short as possible.
    Reputation: jon123's Avatar
    Quote Originally Posted by b-kul View Post
    Agree 100%.
    To me it's one of the things that makes Yetis so great. They are designed with longer top tubes specifically to run short stems. That is 50mm stems (even 35mm -- hey, don't knock it till you try it).
    Getting a little off topic here, but IMO shot stems are right up there with dropper posts in the stability/confidence inspiring factor.
    Go with a large without a doubt. I am 5'11" running a 70mm stem with 740mm bars. The large fits just right.
    Yeti SB-66c large
    Mar 2011
    recommended size and 40mm stem is great. i was worried at first but it turned out well.
    Oni
    Oni is offline
    Master Of Fooliganism
    Reputation: Oni's Avatar
    I'm 5'11 and run a medium with no problems. Switched to a 50mm stem and it's awesome. Makes the bike more playful and nimble.
    Oni
    Reputation: nauc's Avatar
    i like bigger bikes. theyre more comfortable when climbing, more stable at high speeds, and i dont need something super flickable
    Yeti do run long top tubes but their bikes don't feel "big". Meaning that they do feel true to size but just a tad bit stretched out. I normally ride a med, ETT has been between 22.5 to 23.25 inches on all my past frames. The ASR5 I have is a med as well but almost 23.75 ETT. What Yeti does is give you more room to move around without feeling like you're up-sized. I did end up tossing on a 60mm stem where I've normally run a 70mm stem.
  1. 2012 Yeti SB66
    By Dusky21 in forum All Mountain
    Last Post: 04-22-2015, 09:05 PM
  2. Yeti sb66 problems?
    By tom34 in forum Yeti
    Last Post: 03-18-2015, 01:01 PM
  3. Paid Spam: Yeti SB66 Frame, Size Medium
    By smellurfingers in forum All Mountain
    Last Post: 11-27-2012, 02:27 AM
  4. PAID SPAM: Yeti SB66 Frame, Size Medium
    By smellurfingers in forum Yeti
    Last Post: 11-22-2012, 11:38 AM
  5. YETI SB66!!! Anyone know what it's made of?
    By jwcfolife in forum Yeti
    Last Post: 07-19-2012, 12:02 PM
