Results 1 to 32 of 32
    Dec 2011
    Platform pedals with good bearings
    Hey,
    Just curious if anyone knows a good set of flats with bearings instead of bushings. I've tried riding bushing flats on xc and all mountain type trails but they don't spin fast enough and I've had a few pedals bind on tough climbs.
    Syntace, if price is no object. My experience is that the ultra-thin pedals have to make compromises somewhere, and generally it's in the bearings/bushings. So if price is important, consider some thicker pedals with bearings (I've used Easton Flatboys and Specialized Lo Pro Mag 2's, and got both free spin and decent longevity from both) spin much better and last longer. On the cheaper end, I have a set of Forte Converts that spin pretty well, better than my Spanks anyway.
    Lots of people claim not to care about pedal drag, but few feel the same way about bottom brackets and hub bearings.
    Reputation: dirtrider76's Avatar
    Sep 2012
    I ride Answer Rove pedal's which are sealed bearing.
    I like to fart when I'm in front of you on a climb
    Reputation: innovator8's Avatar
    Re: Platform pedals with good bearings
    I had a used set of Easton cully fat boys, I ran them for 4 years, not sure how long dude before me put them on that bike, but until one failed, they were the most free spinning pedals if ever seen. Just the wind from being on the back of my car would spin them super fast!
    Sent from my SGH-T999 using Tapatalk
    Reputation: eurospek's Avatar
    Definitely not Point1 Podiums. My two sets ate bearings (especially the smaller ones) like no other. Constant maintenance on those sucked.
    konahonzo
    orthonormal
    Reputation: andy f's Avatar
    Quote Originally Posted by 94krawler View Post
    I have a set of Roves too. They're reasonably thin at 17 mm, which was as thin as I was able to find for a dual sealed bearing pedal and the platform is a good size. Durability has been great. Bonus is they're usually pretty easy to find at a good price, especially if you don't mind black.
    The glass is twice as large as it needs to be
    You can add another vote for the Answer Roves. Fantastic pedals.
    Reputation: Fix the Spade's Avatar
    Quote Originally Posted by eurospek View Post
    Or you could just not maintain them, my 2011 Podiums still turn... kinda.
    On topic: Easton Flatboys seem to last forever and use bearings.
    orthonormal
    Quote Originally Posted by Fix the Spade View Post
    I had a set of Eastons for a long time. They're well made but kind of thick and the platform is a bit small compared to more modern designs.
    Dec 2011
    Quote Originally Posted by andy f View Post
    What would be a good price on these?
    Sep 2012
    I see them on occassion for 49.99 on pricepoint. I got mine for that awhile back.
    Dec 2011
    Those Syntace look sweet! I like how there's a size option. But damn expensive.
    orthonormal
    I got the same deal from Pricepoint. I couldn't find colors other than black for less than 79.99.
    used to be RipRoar
    Reputation: TraxFactory's Avatar
    Sep 1999
    Quote Originally Posted by Northender View Post
    Hey,
    I've been running flats for many years now and have been through several. Any decently designed pedal with a bushing should not bind, unless perhaps its totally un-maintained. Im 230lbs and ride lots "tough climbs" and xc, no bind issues, ever. In fact all the pedals I've had with bearings on the outside of the spindle always fail early. Due to the leveraging its just a huge amount of load on that end of the spindle. The best longest lasting pedal I've had used DU bushings on either end of the spindle, but I rebuilt them (new bushings) probably every year until the spindles where too far ovalized, although still worked good, just sloppy.
    If you have to have bearings I would think about a pedal that uses double bearings on the outside. I am currently trying some Spike Spanks that use a large bearing on the inner spindle and outer bushing, so far so good but too early to tell.
    Sep 2013
    I totally recommend the Spank Spikes. Been riding hard and holding up awesome!
    undercover brother
    Reputation: tangaroo's Avatar
    +1 on the spikes. Amazing pedals. Super thin and grippy too.
    Feb 2010
    Big fan of the deity compounds. Completely rebuildable, grippy, cheap. Mine spin for days. deity ::: Compound Pedals - deity components
    squish, squish in da fish
    Reputation: fishwrinkle's Avatar
    bit pricey, but well worth it. the hope f-20's are built like a tank. +12 months of riding through all the seasons and their slop they bring & never once even looked at the bearings. 3 sealed and 1 norglide per pedal and they're still spinning like they just got broke in.
    Reputation: nauc's Avatar
    i have the Saints, suckers are tuff and grip great. ive smack them hard several times on rocks and they spin like new
    theyre $77 right now on Amazon
    heres a disassembly video..
    shimano saint PD-MX80 disassembly - YouTube
    the bearings are right inside this...
    Hey,
    I'd have to ask what pedals did this happen on, it's not an issues with bushing pedals in general, just maybe the ones you had.
    OG Ripley v2
    Carver 420 TI
    Quote Originally Posted by TwoTone View Post
    i can't' agree more. i had a set of ______ pedals with inboard & outboard DU bushings & they literally fell apart in 20 miles. due to bad cs from _______ company and no real answer to when they could get me DU's. the store i bought them from felt to right the wrong of ____ co. they gave me the f20's. if i was buying again, yes i would buy them again. saints are tempting for the simplicity & price
    Dec 2011
    I've used Twenty6 Ralley and Straitline Defacto
    Dec 2011
    Quote Originally Posted by nauc View Post
    I have a new pair of these sitting in the box. lol
    I guess it all boils down to personal preference. When I started shopping flats I couldn't justify big bucks on pedals. I remember the Straighline defactos on the LBS owners bike were really stiff to turn, but he said he liked them that way.
    I ended up buying the Shimano Saints, but took them off after the first ride. They kept rolling under my foot.
    After that experience I wondered if it was the thickness of the pedal but still couldn't pull the trigger on $100 plus thin pedals, until I stumbled on a great deal on new Crampon Ultimate Mags.
    With the hindsight of having ridden them now, I'd gladly pay full price.
    OG Ripley v2
    Carver 420 TI
    so why don't you use them?
    Dec 2011
    Quote Originally Posted by fishwrinkle View Post
    I'll be trying them out today.
    Reputation: charging_rhinos's Avatar
    I have to say that I have had worse luck with bearing pedals than bushings. I don't think all bushing pedals are created equal. Bearing pedals often work very well for a while, but they get roached very quickly and you have to rebuild. I'm running a set of Crampon Ultimates with double DU bushings right now, and they spin well once broken in, and they have lasted FAR longer than any bearing pedal I've owned. They don't start spinning if a fly sneezes near them, but i notice zero resistance while pedaling. I actually appreciate the fact that they don't just start spinning on their own though. It's far nicer when dealing with shin-eating pins to have the pedal sit still when you take a foot off for a second than have it start spinning. Just my .02
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    +1 on the Saints - I've rocked these all summer. Doing some gravity and hitting rocks. Solid pedal and great value. Look good too. For best grip, remove all the little spacer washers.
    Santa Cruz Hightower LT
    EVIL Following
    Dec 2011
    Quote Originally Posted by LCW View Post
    I just got back from a ride with these on. They seem to work very well, but the out of box pin setting is too low for sure. One thing I noticed after my ride that concerns me is some oil leaking out of the seal area. Not sure if that's common to these pedals or not.
    ive had mine for about 9 months. no leaks or any other problems here
    Dec 2011
    Not a major leak, just slight. I only noticed it because there was dirt sticking to that area.
    mine has that, but only because there was a bit of grease on it when i got them. i wiped it clean, and its stayed clean
    i think Shimano put it there for prevented measures, if you know what i mean
    my Shimano cranks are that way too, and ive had no problems with them, and theyre about 4 years old
    just keep an eye on it
  1. Good platform pedals for 300+ lbs?
    By BigBen219 in forum Clydesdales/Tall Riders
    Last Post: 03-25-2014, 02:40 AM
  2. Are these Giant platform pedals good for XC?
    By 80sforlife in forum 29er Bikes
    Last Post: 09-10-2013, 04:36 PM
  3. What are some good clipless/platform pedals? (for around $50)
    By matw in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-05-2013, 02:34 PM
  4. Best platform pedals for AM and XC
    By epg0 in forum Beginner's Corner
    Last Post: 12-12-2012, 09:25 AM
  5. Inexpensive (But Good) Platform Pedals?
    By burnedthetoast in forum General Discussion
    Last Post: 06-22-2012, 10:10 PM
