Results 1 to 13 of 13
    Platform pedals on AM HT?
    I have a YelliScreamy that I built up for AM and heavy trail duties. I have been running flats on it, and I have tried to like it. But when I get into fast sections with lots of chatter or rocks, the sharp bucking of the back end kind of kicks my feet around on the pedals, and sometime even off the pedals.
    Admittedly, I have not ridden platform pedals since I switched to clipless 6 years ago. But the other day I rode flats on a friend's Heckler and I wasn't bucked around at all. The suspension absorbed enough of the hits to keep my feet planted.
    I also really like the feel of the platforms for technical rock gardens, because I can get moving again if I have to put a foot down. But the other side of that coin is that I get a LOT more pedal strikes with the flats than I do with the clipless.
    Has anyone successfully and comfortably run flats on their HT? Is this a technique thing I just need to adjust to?
    I don't mind clipless most of the time, but I want to do some bigger jumps and the like with this bike, and I hate getting air with clipless pedals...
    Nov 2012
    I ride flats on a HT and have never been bucked off in fast chunky areas. Dropping your heels in these sections help tremendously.
    Sep 2013
    Drop your heels and follow the contours of the trail with some body English as much as you can.
    Don't understand why your getting a lot more pedal strikes though, are you running slims?
    The problem is that the rocks as roots are all under leaves right now so I can't see the contours f the trail right now. Lol.
    This time of year is bomb downhill with fingers crossed. Not slim pedals. Maybe that's it for the strikes
    Will work on dropping the heels though.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    Quote Originally Posted by blmpkn View Post
    Platforms have much more area (both leading and underfoot) to strike than clipless pedals do.
    OP, there's a learning curve to flat pedals, just as with clipless. It'll take you a few weeks. You'll learn to stick to the pedals better. I had platforms on my Yelli, and was perfectly happy with them.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    I ride a Yelli with 140mm fork & 650B wheels. For regular XC trail rides I use clipless but when Im riding somewhere thats more rocky & technical I put on a set of Spank Spike flats. Nice & thin for ground clearance and a big platform with lots of pins for grip. Cant say Ive had any issues like you describe, though I will admit to needing to ratchet the cranks once in awhile to avoid the odd pedal strike.
    No moss...
    Nov 2012
    Απ: Platform pedals on AM HT?
    buy a pair of five ten‘s shoes and keep your heels down.
    Σταλθηκε απο το dudοκινητο μου με ταπατοκ
    Shinobi-Wan Kenobi Moderator
    Reputation: kristian's Avatar
    Quote Originally Posted by petpol9 View Post
    Agreed, good shoes are the key. I run flats on all of my bikes including the Nimble 9 and the plastic race bike and I never get bucked. You'll get used to it and grow to love them!
    Quote Originally Posted by kristian View Post
    I have some good shoes for them (Teva Pinner 2) and good pedals (E-13). Sounds like I just need to bring some better technique and some patience.
    Jun 2013
    I've come full circle. Started with flats with a lot of grip but pretty thick - lots of pedal strikes. Switched to clipless and like them for pretty much everything. Had a lot less pedal strikes and felt like pedaling was more efficient. But - I did bale more often in up hill techy sections. After taking a class where they advocate the advantages of flats, I've gone to Spank Spikes. Thinner and more grip than previous ones. So far I think this combination works better for me.
    However, for long xc rides that don't have much tech, I'll probably switch back to the clipless....
    Figured I would follow up on this... just needed another week. I now feel 100% comfortable on the flats.
    To the point I am putting them on my singlespeed too... because I now feel "trapped" by the clipless. Even though I haven't ever had trouble bailing really...
    Glad to have you guys convince me to stay with it. I think consciously reminding myself to keep myheels down was the meal ticket.
    Glad to hear it! Another convert!
    People think I'm crazy running flats on my Nimble 9 (SS), but I'm so used to them that I don't even think about it--it's just second nature.
  1. Platform Pedals
    By spartacuslv in forum General Discussion
    Last Post: 07-28-2013, 12:17 PM
  2. Platform pedals
    By dundundata in forum Specialized
    Last Post: 11-09-2012, 04:20 PM
  3. Platform pedals for XC?
    By GorillaTactics in forum Beginner's Corner
    Last Post: 05-25-2012, 09:17 AM
  4. Platform Pedals
    By vertible in forum 29er Bikes
    Last Post: 03-18-2011, 11:50 AM
  5. Platform Pedals?!
    By BoonesDaddy in forum Singlespeed
    Last Post: 01-21-2011, 09:07 PM
