Results 1 to 13 of 13
    Don't skid
    Reputation: KONA_in_SB's Avatar
    Opinions on Revelation Air U-turn
    Anyone riding a RS Revelation? I am thinking of getting one for my hardtail. I have a Pike on my 6" bike and like the lockout and U-turn. So I would get the Revelation Air U-turn. Anyone have any time on one?
    The Revolution will not be motorized...especially at $5 per gallon.
    In my mind, I can do it!
    Reputation: iviguy's Avatar
    Quote Originally Posted by KONA_in_SB
    I'll be able to tell you next week..
    I asked the same question in comparison to a Fox Talas RLC and a Vanilla RLC and overwhelmingly the consensus was that the RS Revelation was a better shock than both. That is why I opted for it. We shall see...
    Reputation: flipnidaho's Avatar
    As good if not better than a Talas..
    I have one on a SS and on my 575 (replaced the Talas with the Rev UTurn Air, no Pop-Loc). It is easily as good as my Talas (and mine was Pushed). It is also about 5mm taller axle to crown so along with a taller lower cup, it raised my front end about half an inch... The only thing I don't like about it is the range of adjustment for the compression is only about 150 degrees or so. I was used to audible clicks for compression adjustment. I ended up running my Rev like the RP3 where I have a lockout, half lockout and full open compression using the Compression lever only...
    Don't skid
    Hmm...sounds like its a good fork. I am sitting here with the money (I just sold my car and need to buy as many bike parts as I can before I do the responsible thing and pay my bills ) about to pull the trigger. We'll see, I'll let you know.
    The Ancient One
    Reputation: Steve from JH's Avatar
    I also replaced a PUSHed TALAS with the Revelation U-Turn (no pop-loc) on my Id. I definitely like it better.
    "Don't criticize what you can't understand."
    Aug 2005
    I have the 426 air u-turn on my Heckler, and it's been a great fork. Light weight, plush, stiff, very adjustable. For me, the sign of a good fork is to be able to set it up easily, and then not notice it when you ride, and this one fits the bill. Can't go wrong with it IMO.
    T , V , & K Rider
    Excellent fork....................
    ......................... get some ! TIG.
    err, 27.5+
    Reputation: AL29er's Avatar
    Another positive experience here. I have a couple of months on mine. It has been on my hardtail and running primarily at 115mm. I recently swapped it onto my BlurLT to see how it would handle and have been pleased thus far. I did add a plus 5mm headset to make it a bit longer to match the bike. The fork is very tuneable, but also easy to set one way and leave it. I haven't had any issue with it in terms of use or setup. The air u-turn works great and has clearly defined detents. I am about 240lb in full gear and typically run the shock at about 170psi pos and 150 negative.
    Bike to the Bone...
    Reputation: rzozaya1969's Avatar
    I went from a Talas R to a Revelation 426 with U-Turn. Both are very good, I prefer the controls on the Fox (very easy to dial, the rebound is on the upper section), the travel control has noticeable feedback without having to look at the stantchion to see how much you have afected travel, on the Rev there's this thingie or flap that you lift to change travel, while it's Al, it seems it might break.
    I've only used my Rev for one ride, so I can't really give a full acount. I think the fork still needs to be broken and dialed it. Anyway, I think that it has a better ride quality, less brake dive, feels a little firmer when peddaling. It has a lot of more adjustability than my Talas (I have the 'R' version, which does not have compresion damping adjustability). This is a blessing and damnation...lol... I guess if I knew what I am doing, I can adjust it pretty good, but right now I'm just in a trial and error stage.
    The Rev is cheaper than the Talas, so I think that also weight in at the buying decision.
    Bike to the Bone...
    Ivy, off topic, but congrats on you're Yeti... the bike, I mean, that avatar you have there doesn't make it justice
    Quote Originally Posted by rzozaya1969
    I thought the G.I. Joe Yeti was cool... It seems to scare everyone though...
    LOL... I've had that avatar for about 2 months just waiting till I ordered the bike so I could post it..
    aka baycat
    Reputation: Ryan G.'s Avatar
    how bout PUSHing your Revelation!!!
    bike in the back right
    Team Blindspot
    Reputation: S-Works's Avatar
    No
    Quote Originally Posted by baycat
    That's a new RS shock that cannot be revealed yet. Darren is playing around with it on his Nomad.
    Astigmatic Visionary
