Results 1 to 32 of 32
    Cool-blue Rhythm One-sided SPD clipless pedals?
    Hey all -
    I'm in the market for a one-sided clip-in pedal and shoe. I saw some guy on a technical trail last weekend who would clip in on the uphills, flip the pedal, and use the platform side on the downhills.
    I'd like to try this out. Couldn't find any Shimano-made one-sided SPD pedals but do they exist? Also, any shoes you guys recommend buying with it so that it clips in easily but also tracks well on a platform pedal?
    Thx!
    Kevin
    Quote Originally Posted by tittiot View Post
    Hey all -
    Thx!
    Kevin
    Shimano has the pd-m324 for the 1-sided spd. But the other side isn't really a platform. It also doesn't use the mud shedding design. Another alternative is the Forte MTX pedal that Performance carries. It has more platform than the pd-m324, but can't comment on the spd.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    worst of both worlds
    Honestly... ahh I give up
    Quote Originally Posted by highdelll View Post
    I agree.
    What a pain worrying about getting the right side of the pedal! I don't know anyone who stuck with this option once they got used to their clip-ins.
    Another option is a dual-side clip-in shoe with a platform. This won't give you the stickiness of platform shoes/pedals, but you won't have to hunt for the right side of the pedal. I used one of these when before I was 100% comfortable with my clipless and would unclip for very technical sections. The platform also made it easier to start up on an uphill because the platform allowed me to just start pedalling without worrying about clipping in.
    For both of these options, a clipless pedal (or clipless on one side/platform on the other) with clipless shoes won't give you anywhere near the stickiness of a good platform pedal with good platform shoes. Personally, I'd be nervous about doing downhills unclipped with clipless shoes. I'd choose clipping in or platforms with good shoes designed for platforms.
    As for shoes, I don't have recommendations, but if your shoes cause problems, you can shave back some of the tread on the bottom that is causing the problem to make problematic shoes easier to clip in. It has worked for me.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    +1
    You get to compromise both your ability to clip in and your flat pedal performance. If you would feel more comfortable on the downhills with flat pedals then just ride a good set of flat pedals. I've made the switch and I have yet to say "boy, I sure would like my clipless pedals right now" but when I rode clipless I would frequently wish I had flats for sections of trail.
    T.W.O.
    Reputation: mimi1885's Avatar
    +1 with highdell elegant words, beside 324 is just terrible for trail riding. Try a530 it's lighter and better than 324 and still just as terrible for trail riding.
    Reputation: rickcin's Avatar
    Hey all -
    Thx!
    Kevin
    No expert on clipless, in fact first season I have been using them, however, I will recommend using a fully clipless pedal even on downhill runs. It is safer, gives you better control and balance on the bike with less of a chance of your feet being bounced or jerked off of the pedals. They turn out to be a major control factor.
    I tried the one sided SPD pedals for a ride. They were not so good (sucked). I didn't like guessing which side was up, and it was always the wrong side. I like to ride with double sided SPDs with the tension fairly loose.
    I modified the shimano pedal so it had a usable platform side. The only time I'd use the platform was for log rides. Now I just use regular spds. I really like the float and being stuck to the bike when things get real rough.
    Hey all -
    Thx!
    Kevin
    there is a wellgo pedal, the WAM-D10 i think, that is like that (pins on one side, SPD compatible cleat on the other). i had a pair for a while, but went to full flats shortly thereafter, because clipping into them would give me knee pain.
    http://www.pricepoint.com/detail/142...p=240%20WELD15
    i have two friends that have used them w/ no knee problems whatsoever.
    94 Specialized Rockhopper
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    The problem is that SPD compatible shoes are usually hard and stiff, just the opposite of a good grippy flat friendly shoe (i.e. 5.10s) and with the cleat they just won't grip on the platform side since the pins on the hybrid pedals are seriously lacking as compared to a good flat. I go back and forth a lot and miss the float when I'm riding the flats, but they've exponentially improved my jumping skills.
    My wife switched to Shimano 324s. She has no issues clipping in and out or flipping them over when needed. It helps her confidence in more technical sections on the trail but they're not for weight weenies !!
    Quote Originally Posted by Bungholio View Post
    I went with the Shimano PD-647 since they were the highest rated on the reviews on this site as well as other recommendations I have received from other members. I did agust them to the lowest setting and I love the pedals!
    Rick
    Quote Originally Posted by whodaphuck View Post
    510 Minnaar
    Attached Thumbnails Attached Thumbnails One-sided SPD clipless pedals?-23_408007_1272576822.jpg
    510 Minnaar's ...............NICE !!
    I have been told so in the past and now I really do believe that clipless is safer! You have a better connection to control your bike and pedals, your balance and prevents your feet and crank from flying around.
    Quote Originally Posted by zebrahum View Post
    +1
    Totally agree. Go one or the other. Half and half pedals are for commuters that want to wear riding shoes one day and sandals the next. Not good for mountain biking. Pick one or the other. Clips won't hold you back one bit even on gnar DH once you get comfortable. Having said that, I prefer flats for everything. It's all personal preference. Learn both, then decide which you prefer.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by rickcin View Post
    I understand what you're saying but there is no basis for calling one pedal safer than another. The vast majority of people feel that platform pedals are safer because you aren't attached the them. It's really just what makes the individual feel better. Personally I would agree with the masses, not being attached to your pedals lends its self to being safer because you can bail if needed. I suspect that anyone who thinks platform pedals cause your feet to bounce off of them just needs a bit of time on a really good platform. And there's lot of little things you learn to keep your feet planted better like heels down while you're coasting through technical sections and toes down when you're catching air. Adding angles to your pedals helps give you a surface that you can control while not just standing on the pedals.
    Anyway, not what this thread is about though.
    Yes, that's fonetic
    Feb 2005
    Quote Originally Posted by homeagain View Post
    Those are nice. does the cleat extend far enough to interfere with the contact on the flats?
    i had a similar shoe (the 661 filter), and it took some shims and trimming to get the cleat to extend enough to clip in, and allow some float (otherwise, when clipped in, it was like stepping into cement, no float at all). when i used the flat side of my pedal, the pins would grab the sole, and there was little interference from the cleat.
    meow meow
    Reputation: b-kul's Avatar
    Quote Originally Posted by dumbaSS View Post
    510 Minnaar
    the cleat will still extend out passed the rubber sole making it pretty much useless unclipped.
    Reputation: bamwa's Avatar
    I use the wellgo wam d10"s for 3 seasons of xc racing and love um. No problems here. not expensive either.
    Heck I even beat Lance Armstrong on those. ( Even on his home course), doh!
    Keep trying to do the awesomest thing you've ever done.
    Quote Originally Posted by b-kul View Post
    Are u speaking from experience? The cleats on my Minnaars do not extend beyond the surface at all.
    Yes, that's fonetic
    Feb 2005
    That actually looks like the cleat is flush with the rubber, meaning when the pins on the non clip side are sinking into the rubber they're going to be hitting the cleat, hindering hook up, but without a side view it's kind of hard to tell for sure.
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    I'm surprised to see an advertisement for pedals say the "pucker factor" is a reason to consider the one side pedals. I understand that everyone who goes to them are knew to them at some point, but I'd say the pucker factor is a very temporary span of time. I never have a problem releasing but I don't do a lot of technical rides.
    I always thought of the one-side as a nice convenience for my back up bike if/when a family member or friend comes by and wants to ride ie; needs the flat pedals. To me, that is the genuine "selling point".
    Yes, that's fonetic
    Feb 2005
    Quote Originally Posted by bachman1961 View Post
    That's why they invented pedal wrenches.
    Really though, I've pretty much quit riding clipped in after 15+ years of doing so (I rode bulky Look cleats before adopting a pair of original Shimano spuds when they came out in 1990ish), so this is no longer an issue for me. Seems like every time I rode clipped in I landed a jump wonky and aggravated my plantar fasciitis. Haven't clipped in in 6 months and am 3 months pain free.
    Co Springs
    Oct 2013
    Your reasoning makes sense.
    I've seen others mention knee or foot pain that is linked to using them.
    Certainly, if my style or type of riding didn't fit with my comfort zone, I'd just go to flat pedals.
    I like the other bike w/o them because I use it around the park and paths with the little guy on the back. Also, the fact that I don't have to 'wrench' anytime someone is over and wants to ride my extra bike. I don't know anyone who'd use it that has shoes. For me, it's a no-brainer in that regard.
    Reputation: lotusdriver's Avatar
    Sep 2013
    I tried one sided pedals but always ended up flapping about with them, trying to get the right side.
    If my foot slipped off the pedal while riding flats on rough terrain it always seemed to be the SPD side that l ended up stamping back down on.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Quote Originally Posted by lotusdriver View Post
    Yup, that's why they are a terrible idea.
    Jayem is exactly correct, ditch those pedals and get some good clipless pedals and get use to them.
    I was very reluctant, like you, and I must admit it was my biggest single improvement to cycling both on and off road. It just provides more control and makes you more a part of the bike.
    I love them and regret I did not go with them from Day1.
    Sep 2014
    I am personally riding clipless for 10 years without any knee pain. But e.g. on rock gardens after a stop there is usually not enough time for me to make sure the second leg is clipped so sometime i and up riding unclipped which is very unsettling.
    Second reason is that when practicing technique, riding clipless does not feel very safe - so i was even riding spd with plastic platform used to hold the reflector.
    So platform pedals with pins with spd on one side is what i was looking for - and i found exactly that in Funn Mamba pedals.
    Yes - finding the right side is annoying, but thats the price i am willing to pay for the benefits of not having to switch whole pedals for technique training or starting pedalling in difficult terrain.
    My only wish would be if they made them a bit lighter (530g).
  1. Need help reassembling double-sided SPD pedals
    By jonschmon in forum Beginner's Corner
    Last Post: 02-08-2010, 11:03 AM
  2. Pedals: clipless, light, double-sided, and platform?
    By terminus in forum XC Racing and Training
    Last Post: 10-06-2009, 07:09 PM
  3. which clipless pedals and shoes for clipless newb?
    By jeepinmike in forum Apparel and Protection
    Last Post: 06-27-2007, 01:47 PM
  4. Pedals: BMX to Clipless
    By madzane in forum General Discussion
    Last Post: 11-09-2005, 11:25 AM
