Results 1 to 6 of 6
    Oct 2013
    An old Marin MTB
    Hi everyone - I'm a newcomer to this forum. I want a new, light bike. So instead of going out and adding more hardware to the world, I decided to overhaul an old Marin I came across. Only problem is, it's missing the gear hanger plate and I'm not sure what model it is. The model name is missing - it's got a label on the rear frame tube saying Marin Custom 7000 series Alloy. It's a hard-tail with rigid forks. The forks are pretty light but I think they might be cro-moly steel. The serial number below the bottom bracket is SR6041470 The tubes are pretty thick and round - not shaped. I thought it might be an early Palisades Trail; maybe around 1996, but I'm not sure.
    I wondered it your collective experience and wisdom may have a way of decoding the model from the serial number? - that way I could track down a gear hanger. If this fails, I guess I shall have to get a thick piece of alloy plate and try to make one...
    Any help would be really appreciated. Phil B
    Sep 2012
    Sounds like it might be an Indian Fire Trail. Back in the day I used to have one, polished lacquered alloy tubes steel fork (painted bright lime green) had a fairly long top tube for XC and was stiffer than a girder. Not that helps much for your bits, if its a palisades I recall they used to have grey painted? frames and were steel though things change and memories fade especially considering this was way back in late 80's.
    Reputation: Chad_M's Avatar
    Jul 2013
    Picture would help. Also, depending on year, the vintage section might be better audience.
    Oct 2013
    Old Marin MTB
    Hi - I'm attempting to track down the model of this old Marin I'm trying to refurbish. Main problem is that the gear hanger is missing...
    The Fastest of Bananas
    Reputation: FastBanana's Avatar
    Aug 2013
    Check out bikepedia. You can pretty much match up exactly what your bike is. I think a company named Pile makes pretty much any hanger you could want.
    Jan 2014
    You probably figured out what bike you have, but in case you haven't, I think I found it. I know nothing about bikes, but I claimed a Marin resting on the dumpster at my apt complex and wanted to identify it. It was a really good find next to a bunch of furniture, so I can only assume someone was moving and ditched everything they didn't have room for. Lucky me. I googled "marin 7000 series alloy" and found this post. The picture you posted is exactly like mine except I have front suspension. I stumbled upon bicycle blue book and used some of the info on this thread, and I took a few stabs in the dark by just clicking on random marin models 1996-2000 and voila- I have a 97 Palisades Trail (1) with the rock shox indy c fork, and yours looks like the Palisades Trail (2) from the same year. The info you need might be here:
    1997 Marin Palisades Trail (02) - New and Used Bike Value
    If you didn't already have it figured out, I hope I was some help. Finding this post helped me figure out what I have, so I joined this forum to hopefully help you in return.
  1. What Marin is this?
    By mattmers in forum Marin
    Last Post: 05-07-2013, 10:00 PM
  2. What Marin is this?
    By hramd001 in forum Marin
    Last Post: 05-06-2013, 02:27 AM
  3. Marin is in
    By r1Gel in forum 27.5
    Last Post: 04-18-2013, 09:21 PM
  4. Marin MT or AT
    By TSTEEL in forum Bike and Frame discussion
    Last Post: 05-01-2011, 07:29 PM
  5. Replies: 11
    Last Post: 04-18-2011, 05:46 AM
