Results 1 to 7 of 7
    a'buh?
    Reputation: flyingwalrus's Avatar
    Nobby Nic vs. Slant Six vs. Spec. Purgatory
    Trying to match a rear tire to a Nevegal 2.3 up front on a GT Distortion build.
    I want something that rolls fast and is decently light, but still grips well on a variety of terrain. Any input on which of these is the best allrounder? And which is the best in the wet (knowing full well that none of them are going to be mud tires)? I'm looking at dual compound versions in the 2.2-2.3 range, FYI.
    "Don't just huck yourself: be skilled, be trained, be ready, be prepared, then give 'er." -Dylan Tremblay
    meow meow
    Reputation: b-kul's Avatar
    imo non of those are very similar. the purg is pretty aggressive and the six is the least aggressive. i use a purg out back and i like it, pretty fast but still good grip.
    gravity fighter
    Reputation: Mikecito's Avatar
    A Conti XKing might be another contender for you. The 2.2 X almost matches the volume on my Nev 2.3 and it rolls very well. It's decent in the wet but you have to play with your pressure a bit.
    Feb 2007
    Also consider the Specialized Ground Control 2.3" tire. Rolls and grips better than a Purgatory, in my opinion. FYI, I just cut every transition knob off my Nevegals, and they are like completely different tires. If you want a bit more cornering performance from you Nevegal, give that a try if you haven't already!
    Come on, dare me!
    Reputation: Jerome's Avatar
    What about the Hans Dampf from Schwalbe? It is supposedly the best current "lightish" big AM tire (2.35). Otherwise, I have (had) both the Purgatory and the NN and they're pretty different tires. The Spec is more round and has a bit less grip in corners but is more predictable, whereas the NN is more square but has more bit, although it doesn't warn you when "letting it go". I think the Purgatory (in Control version) might be a nice complement to your Nevegal. Last but not least, a 2.2 Purgatory is bigger than a 2.25 NN but the Schwalbe is almost 100 g lighter in standard (EVO) version and 60 g lighter in the Snake Skin version.
    Mar 2011
    Can't go wrong with the Spec. tires. They've got a satisfaction guarantee (30 or 60 days can't remember which). I've run the Nobby Nicks and liked them but I'm on the Purgatory now in the back. The Ground Control by Spec. is basically a NN clone so it would be worth trying out. You could basically try the Ground Control for a few weeks then swap it out for a Purgatory and see which one you like better. I've enjoyed both for riding on the east coast in most conditions. Don't really think I can feel the difference between the 2 although I'm sure more experienced riders can. Hopefully if you try both you can make up your own mind.
    Later
    Bryan
    Dropshot Champ!
    Reputation: redmr2_man's Avatar
    the nobby nic and the purgatory are close to each other. they're both really good tires. the purg will be cheaper...it lasts a little longer too. great tire.
  1. Scott Scale vs Spec Carve vs Spec SJ Comp/Evo
    By Bowfish in forum 29er Bikes
    Last Post: 01-29-2013, 07:44 PM
  2. Good replacement for Spec. Fast Trak / Purgatory combo
    By Mithrandir in forum Wheels and Tires
    Last Post: 01-20-2013, 09:29 PM
  3. Nobby Nic - Purgatory combo
    By trailjunkee in forum Wheels and Tires
    Last Post: 06-27-2012, 01:43 PM
  4. Spec. Purgatory as a front tire
    By Blatant in forum Wheels and Tires
    Last Post: 04-17-2012, 08:35 PM
  5. Replies: 4
    Last Post: 12-19-2011, 12:51 PM
