Results 1 to 7 of 7
Thread: Newbie at mtb
    Aug 2013
    Hope Newbie at mtb
    Hey all, Im just new to mountain bikes, and I just bought a Jamis Trail x3. I know that for thr price i paid maybe I could have something better, but here in Mexico other optiones were very expensive. But thats not the point.
    I would like to ask what would you recommed changing to my bike for better perfomance.
    Aug 2013
    btw here are the SPECIFICATIONS
    Frame
    6061 aluminum main tubes, over-sized seat tube, replaceable derailleur hanger
    Fork
    RST Blaze TNL, MCU/coil spring with Turn-n-Lock lock-out and external preload adjustor, 100mm travel
    Headset
    VP threadless, 1 1/8"
    Wheels
    Alex TD25 double-wall disc-specific rims with reinforced spoke bed, powder coated, 32H, alloy 6-bolt disc hubs with QR, 14g black stainless steel spokes
    Tires
    Jamis TX, 26 x 1.95"
    Derailleurs
    Shimano Acera M360 rear and Acera M310 34.9mm top pull front
    Shiftlevers
    Shimano Acera M310, 8-speed
    Chain
    KMC HG40
    Cassette
    Shimano CS-HG30, 8-speed, 11-32T
    Crankset
    Shimano M311, alloy crank arms, 42/32/22 rings, 170mm
    BB Set
    Sealed cartridge, 68 x 122.5mm
    Pedals
    ATB platform, hi-impact resin cage & body
    Brakeset
    Tektro HDC-300 hydraulic disc brakes with 6" rotors
    Handlebar
    Jamis XC riser, 6 sweep x 13mm rise x 620mm
    Stem
    Jamis XC alloy threadless, 10 rise x 90mm (13-15"), 100mm (17"), 110mm (19") and 120mm (21")
    Grips
    Kraton for trigger-shift
    Seat Post
    Jamis OS alloy micro-adjust, 31.6 x 350mm with alloy QR clamp
    Saddle
    Jamis ATB Sport with pressure relief channel, SL cover, protective front and rear guards
    thnx
    Reputation: jmallory's Avatar
    Have you ridden it yet? The obvious things are suspension, brakes, wheels/tires, cockpit. I suggest riding it the way it is and it will become obvious what needs to be changed.
    Reputation: charging_rhinos's Avatar
    ^ That is good advice. Do a little bit of riding on it and make a list of things that you think should perform better. Usually the things that will be highest on the list are suspension, wheels, and shifters/derailleurs. Be aware that many of the upgrades will cost nearly as much as your complete bike though. A decent front fork can easily cost over $300 used. But don't let that discourage you. You will be able to get upgrades over time
    tangaroo: What electrolytes do chicken and turkey have again?
    rck18: All of them, because they're meat.
    Reputation: Tystevens's Avatar
    Ride it and see how it does first. If it isn't broke, don't fix it until it does, and then upgrade parts as you go.
    '11 Specialized Enduro Expert for the trails
    '13 Felt Z4 for the road
    Aug 2013
    Work on your skills. If your a beginner YOU are the weak link. Educate yourself on proper form and how to actually ride the bike. It's not as cut and dry as most people think. Oh yeah, a gym membership too. Fitness+strength+skills........than upgrade the bike. My .02
    Reputation: nauc's Avatar
    just looking at specs, id change the pedals and the tires. im loving my Shimano Saint pedals and Nevegal tires
  1. Hello, Newbie Here
    By gbuk in forum Beginner's Corner
    Last Post: 06-19-2013, 12:01 AM
  2. Newbie.
    By Mrredline05 in forum Beginner's Corner
    Last Post: 06-18-2013, 09:01 PM
  3. newbie with q's
    By andy4d in forum Beginner's Corner
    Last Post: 02-27-2013, 06:20 PM
  4. POV Newbie
    By iammemares in forum Videos and POV Cameras
    Last Post: 07-29-2011, 12:35 PM
  5. Old Newbie
    By RobbieGoat in forum California - Socal
    Last Post: 03-08-2011, 06:58 PM
