Results 1 to 11 of 11
    Reputation: zoro's Avatar
    New SLX cranks: pedal inserts?
    Can anybody tell me if they carried over the steel pedal inserts on the new SLX Crankset?
    The older version had some on the double version, is it the same thing for the new one?
    M675 version I think.
    TIA!
    Mar 2011
    Pretty sure it's only on the new Zee
    ptd
    ptd is offline
    Oct 2012
    Hmm I had it in my mind that they did, a quick googleate seems to think they do not.
    They were on my build list.
    Back to Zee?
    Care no inserts?
    Reputation: Fix the Spade's Avatar
    Why not the old 665 cranks?
    The Zee cranks are the M545 Deore set up from a couple of years ago, re-badged and with new chain rings. You can probably get the M545s a lot cheaper and it's identical save for slightly heavier chain rings.
    Unless you're far north of 200lb or jumping the inserts don't make much difference.
    Quote Originally Posted by Fix the Spade View Post
    The biggest culprit in stripped cranks isn't jumping or weight but rock strikes.
    Ha good spotting. The zee and deore cranks are really the same crank!!
    As for not stripping the pedal threads, it really depends on what style of riding you preach and your weight + intangibles. I stripped some XTs not too long ago, and some XTRs back in the days, so I'm kinda paranoid about that now. Probably irrational, but it's still there. Not that much of a big guy, but still 185 + I ride/race pretty aggressively.
    Love the new saints though. I have the previous version and it's insurance policy for worry free riding in terms of cranks.
    Thanks for the tips guys.
    Reputation: dump's Avatar
    Are you talking about pedal washers? If so, you can pick them up at your lbs.
    Non, talking about the actual steel inserts in the pedal threads to reinforce the connection between the pedal and the crank
    Reputation: CHINOTAKER's Avatar
    Oct 2012
    can you put a bashguard on that slx
    crank?
    Not sure depending on the version.
    The double version seems to be sporting a different, thicker spider thus *ucking up the bashguard option (like the saint cranks). It would offset the bashguard and put too wide of a gap between the bash and the chainring.
    You could do it on the triple version though I'm pretty sure.
    Reputation: phoenixnr's Avatar
    I put a bash on my triple SLX
Hot Deals
Contests
Latest Mountain Bike Articles
