Results 1 to 30 of 30
    Need some advice
    I've been biking for a few years now, but not consistently. I don't know a whole lot about bikes either. I have a Trek 4300 Alpha 2002 I think. Lately I've been doing more and I want an upgrade, but I don't have a ton of money. I know I want something with discs and a better fork. I got a max of about $700, what's the best all around bike for the price? Would it be better to upgrade some components on mine? Thanks
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Quote Originally Posted by plumleej View Post
    I can't see it being worth putting money into your 4300. How often did you change the chain? How much did you take care of it? How does the suspension feel? How about saddle, grips, pedals, reach... How does it feel when you ride it? Is there anything you would change about it? You can't throw money at an entry level bike and expect it to start performing like a race bike, unfortunately it doesn't work that way. Certainly if the bike is dialed for you then it will be worth putting some money into, but with a 9 year old bike I don't think you're going to get much value that way.
    $700 in the new market might get you a good deal with the end of season sales going on, it really depends on what the shops in your area have in stock. You could also try to find something used. My suggestion is don't buy anything used or off the internet unless you can ride it first. First and foremost your bike has to fit, personally I'd go to a LBS to buy a bike, but to each their own. $700 is a decent budget, test ride everything you can get your hands on and see how things compare to your old bike.
    Thanks for the response. I see what you're saying about upgrading the 4300, it's old and needs one of everything too. I've been looking at a bike I found on craigslist, it's a Kona Stuff. I'm going to meet with the guy today so I can test ride it. Are these good bikes? He upgraded the fork to a Fox 36 Talas RC2, I don't know a whole lot about bike components but I've heard fox forks are good. He's asking $675 for it.
    Picture Unrelated
    Jun 2005
    All that matters is that you like it. If it fits, and you like it, then it's not a bad bike.
    Ok thanks, there's also a Trek Ex 5. If I save a little more I could get that. How does that compare to the Kona?
    Picture Unrelated
    Jun 2005
    Impossible to say without having the two bikes in my hands. One could be completely clapped out making it worthless but I can't say. I'm going to default to my previous answer.
    Dont waste your time
    i like what zebra said cause he brings up a valid point, dont upgrade something that cant be upgraded. Im a skilled Mountain bike Mechanic myself and am in the process of building my own bike but when i was younger i had to learn the hard way that even if you put $1000 into a bike ods are its still gunna be the bike you had before and it still wont be to your liking. And dont forget that finding a bike that fits you can be tough but as long as you do your research and dont rush it you will be fine, hope the words helped, see ya
    Thanks guys, I ended up selling my Trek and getting a Kona Stuff with lots of upgrades.
    I would like to see pictures
    Took it out today a little and loved it.
    Attached Thumbnails Attached Thumbnails Need some advice-e3187627872c_6613e577-0c69-4445-82a5-1c17834e73fb.jpg
    Good Stuff man! (pun intended....) have fun with your new bike.
    Helmet Tester
    Reputation: MobileMech's Avatar
    That's a burly little bike for the money man! You are going to have a blast on that thing
    Today I noticed that there's some side to side play in the front wheel. Are there bearings or a bushing that goes bad?
    Reputation: smokerings's Avatar
    You might need to adjust the hub.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by smokerings View Post
    +1
    You can try it yourself with the help of Park's website or you could take it into the shop and have them crank out an adjustment in a few minutes. To do it yourself, you may need some cone wrenches depending on the hubs.
    It's a 20mm thru axle and I tightened the cap on the end with an allen wrench and it seem fine now. Is this a normal problem? Could I use a little lock tight?
    Picture Unrelated
    Jun 2005
    There should be pinch bolts that keep the axle from backing out, but yes you should make sure your axle is tight before every ride.
    Took the bike out today and had a blast, first time I really did any jumping. I've almost maxed out the front suspension. On the fork there's the rebound adjustment and the travel adjustment, on the bottom of the fork there's a cap. If you take that off is that a compression adjustment? For the fork do you ever need to redo the fork oil? Also I noticed that I was smelling brakes. They were getting super hot, should I upgrade the disc size? Thanks
    Picture Unrelated
    Jun 2005
    Might be compression damping at the bottom, I'd have to read the manual or tech sheet. Maybe someone with that fork will chime in.
    The manual will have service intervals including fork oil changes. While most people don't follow those guidelines, it's safest to follow the directions for fork longevity.
    Are you using both your brakes? Most of your braking power comes from the front brake and that's a common reason people heat their brakes up too much.
    I'll look into finding a manual for that compression, that's what I thought it was too. I use both brakes, not sure which I favor when I'm riding but I use them both.
    Reputation: Magsrgod's Avatar
    Just go to Fox's service website and you will be able to find all the information on the fork including their recommended settings.
    Fox Racing Shox FOXHelp Service System
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by Magsrgod View Post
    Yes, this.
    I was reading from my phone and the pics didn't load. I forgot it was a 36. So yes, that's a compression damper adjustment. I can't tell if it's a Vanilla or a Talus but you can also change the suspension stiffness by either adding air or changing the spring.
    Looks to be a 2006ish talas
    The guy I got the bike from said the fork is around 2005ish. Are they good forks? What is the basic fork maintenance?
    Yeah it's a good fork, if your ever looking to tune it up some then look into getting completely tuned by Push industries. As it stands it's probably worth getting the oil changed and the seals replaced since you don't know the history on it.
    Cool, thanks. Now that I'm getting more into biking I'm realizing it's probably a good idea for me to get a full face and some pads. Thinking about getting the Bell Drop for a helmet and lizard skins knee/shin. Don't want to spend over $100 for a helmet, and don't want to spend over $50 for leg protection. The cheaper the better, but if they don't hold up and I have to end up getting a new set I guess a more expensive set would be better. What do you guys use? What are the biggest bang for the buck? Thanks
    Picture Unrelated
    Jun 2005
    I'll answer in two parts. First; why do you want a full face helmet? There's some good reasons: facial surgery history, previous injury protection, maybe you're a movie star or something and can't afford to hit your face. *edit: too early and I forgot you got a new bike. I seem to be doing this a lot lately. My bad* If you're riding lifts or shuttling then FF makes sense, less so if you have to pedal your trails. Leg protection makes sense to me though, especially if you're just building your skill set you're bound to bash yourself up in the legs sooner or later.
    I have a Fox Rampage FF and I can't stress enough that you need to try on FF helmets before you buy them. Unless you have enough patience and money to keep sending back helmets for fit you should be trying them on first. I actually should have bought the Troy Lee D2 because it fit better and now I'm paying for that every time I wear the Fox. The Fox isn't a bad helmet, it just hits me in two weird places on the back of my head.
    For legs I used to run Lizard Skins shin pads but I switched to 661 Race knee/shin pads and 661 EVO elbow pads. I've worn cheap pads in the past and they fit poorly, protect fairly well, and they break quickly. There's a few things I don't skimp on and protection equipment is certainly one of those things.
    Quote Originally Posted by zebrahum View Post
    Did you like the lizard skins? Which do you like better 661 or lizard?
    Picture Unrelated
    Jun 2005
    They're different types of pads, but I like the 661 knee/shins better. They're a little less bulky and have the knee pads to them. I tried on a bunch of knee/shins and went with the 661 due to fit. Even the lower and mid level 661 stuff didn't feel good for me, it's a matter of what you want to do with them and how they fit your leg. I'm not pedaling much while wearing pads so the knee/shin is the best choice for protection for me.
    I think I'm going to try and buy local, it's going to cost more but I think trying things on is a good idea. I tried the Deviant II helmet today and it sucked. I really didn't like it. Also tried a Fly helmet which fit perfectly, does it really make a big difference on the size and weight of the helmet? It only weighs a little more and fits very well. It's DOT approved so its bigger too, kind of overkill for what I'm doing but I want a helmet soon.
  1. Replies: 0
    Last Post: 09-27-2010, 03:36 PM
  2. Help need advice
    By temana65 in forum Ellsworth
    Last Post: 08-23-2008, 03:27 PM
  3. Bad Boy advice.
    By Boblister in forum Cannondale
    Last Post: 07-26-2007, 03:52 AM
  4. first DH advice extremely nervous any advice?
    By jekylldude178 in forum Downhill - Freeride
    Last Post: 02-16-2007, 11:25 AM
  5. XtC advice please!
    By peteer01 in forum Giant
    Last Post: 11-10-2005, 11:00 PM
