Results 1 to 11 of 11
    Oct 2012
    Need help please with RaceFace Single Ring narrow/wide
    Hi. I'm planning on buying a Raceface Single Ring (9/10/11 SPEED) NARROW/WIDE. How do I determine if I have Regular tab thickness (BETWEEN 3.3-3.85mm) crank or fat tab crank (4.5mm)? I don't know what to measure exactly. Also, how do I know if I need Carbon or Aluminum tabs? THanks
    Reputation: bigkat273's Avatar
    Re: Need help please with RaceFace Single Ring narrow/wide
    What cranks?
    Oct 2012
    I have Custom SRAM Carbon S-2200, 10-speed XC Trail double, GXP spindle, removeable spider, S: 170mm, others: 175mm
    Reputation: Snfoilhat's Avatar
    May 2010
    Need help please with RaceFace Single Ring narrow/wide-chainring_01.jpg
    Need help please with RaceFace Single Ring narrow/wide-chainring_02.jpg
    Carbon vs. aluminum? Metal will feel cooler to the touch and make a different sound when you tap it. They look different.
    Oct 2012
    Thank you for the photos Snofoilhat! It helped!
    Here are some photos of my ring that I removed. I also removed bash guard. Should I go with the 36t? I have been using 38t in the trails that I ride and it's been fine for me. I ride technical trails in Markham with climbs.
    Oct 2012
    Also looking at my tabs in the photo. It appears to be alluminum. I tried tapping on it and feeling it but had a hard time deciding if it's carbon or aluminum.
    I think you need to re-read what you typed to find your answer to the material that your crank is made of and go with then tabs that match.
    Reputation: Calhoun's Avatar
    Nov 2008
    Quote Originally Posted by rugbyred View Post
    The removable spiders on SRAM cranks are made of Aluminum.
    "Mi amor Nuevo Miércoles!"
    -cabra cadabra
    That makes me an ass!
    Oct 2012
    thank you for the replies and help.
    Reputation: Fuglio's Avatar
    Quote Originally Posted by Calhoun View Post
    What a FKNG know it all
  1. Race Face Narrow-Wide Single Ring...
    By mbell in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-27-2015, 01:14 PM
  2. RaceFace Narrow/Wide chainrings?
    By r1Gel in forum Where are the Best Deals?
    Last Post: 12-11-2013, 06:13 PM
  3. RaceFace Narrow/Wide on Backorder?
    By Skelldify in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-05-2013, 04:58 PM
  4. RaceFace Wide/Narrow Rings Availability
    By ALS650L in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-01-2013, 08:10 PM
  5. RaceFace Wide Narrow with 1x9
    By Dan0930 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-02-2013, 01:29 PM
