Results 1 to 12 of 12
    Reputation: bridgestone14's Avatar
    Mar 2005
    need help with my KS Lev
    The rubber gasket that holds the red KS dust cover over the spring on my KS Lev broke and I need to replace it. Can I just get an oring at home depot or do I need a rectangular gasket? Any help will be greatly appreciated. Thanks Ben
    Looking for a Medium Scott Scale frame, preferably a 2012 in 26.
    May 2005
    20MM ID X 1MM C/S
    Bought on ebay. Fit perfectly.
    Metric Nitrile Rubber O Rings Cross Section 1mm Various Sizes Available | eBay
    KS Should include few more w the post...
    Mar 2005
    Awesome, thanks.
    RTM
    RTM is online now
    #1 Latex Salesman
    Reputation: RTM's Avatar
    Quote Originally Posted by snoroqc View Post
    have you guys tried calling them? maybe they'd ship you a couple. from what I've seen they appear to be a very rider/customer friendly outfit.
    May 2005
    Quote Originally Posted by RTM View Post
    Yes.
    ''Your local dealer can source this part through:
    Company: Norco Products Ltd. West
    Address: 1465 Kebet Way
    Port Coquitlam BC, V3C 6L3
    Tel: 1-800-663-8916
    Fax: 1-800-667-2699
    Web: Norco Bicycles
    Respectfully,
    KS USA
    26741 Portola Pkwy 1E658
    Foothill Ranch CA 92610
    Reputation: F.N.G's Avatar
    I lost my actual red cap on the trail and KS actually sent me a replacement. Rick is great to deal with.
    Reputation: JPBakerIII's Avatar
    Mar 2012
    Might want to put a little grease on that thing once in a while. The lube they have on them when new eventually dries up. It will make the seal on the cap stronger and less likely to fall off as well.
    1990 Schwinn Sierra MOS
    2011 Santa Cruz Chameleon
    2012 Cannondale Claymore 2
    May 2005
    Quote Originally Posted by JPBakerIII View Post
    And a tie wrap on the cap.
    Reputation: sohnice's Avatar
    Only to riders from the states.
    I lost my red cap on my local trail too, my local distributor is charging US$20 for that cap!
    Why will this cap lost in the 1st place, i guess you have to ride softly in the trail.
    This is my solution to replace the red cap.
    No advertising for KS now.
    Jun 2013
    Also need help here! Just got mine installed yesterday but I don't like my cable rerouting and want to start again this time with the barrel adjuster in a different location SO I need another cable. What kind of cable can I use? Will a regular brake or gear cable work?
    Also, like the other user above the o-ring that holds the red tab in place broke. I saw the link to ebay but do not know which size to order. If anyone can clarify this that would be great.
    May 2005
    20mm id x 1mm c/s
    Mar 2005
    Shifter cable will work just fine.
