Results 1 to 23 of 23
    Need help looking for stem
    I'm looking for am - free ride stem, sort and light.
    what about thomson
    bikethomson.com/stems/bmx/
    or sunline?
    sixsixone.com/Catalog_SunlineCycling.aspx?id=f244dbb3-cd3f-4d4f-b4b6-7826bafd6930
    sorry for the links- can't post linked yet - newbie
    Huckin' trails
    Reputation: David C's Avatar
    I think that the thompson is over build for what you want, unless its extreme AM and heavy FR...
    But a RaceFace atlas should also get your cover with style... Look also at Truvativ stem.
    Atlas AM : Race Face 2011
    Lot lighter then the Thomson too 255g vs 170g
    Check this one out... 2011 Race Face Atlas AM 50mm Black Mountain Bike Stem | eBay
    $60 free shipping, 158g, bad ass look and performance that can't be beat here...
    But its also because I'm a fan of RaceFace... But people can also suggest other things.
    Just be sure to have the right steerer tube dimension, bar clamp (handlebar diameter) and length of the stem you are comfortable with...
    Happy riding
    David
    Quote Originally Posted by NicoleB28 View Post
    topless. that's what all mtb girls do. we go ride, get topless, have pillow fights in the woods, scissor, then ride home!
    how do I know to fit the right stem to my tube ?
    Huckin' trails
    Normaly your steerer tube should be 1" 1/8 diameter, since it's the standard for MTB bike fork... Now your handlebar diameter at the clamp area might be 31.8mm or 25.4mm... So take a gauge and measure... but if you are going for that kind of stem, you better get a 31.8mm bar, otherwise it's like riding cheap components on DH bike... Taking risk. And the 25.4mm bar won't be able to hold in place in a 31.8mm stem clamp...
    Then you only need to see what length of stem you are comfortable with and you are all set
    The one from RaceFace is for a 1 1/8 steerer, with a 31.8mm bar clamp. 50mm long or also 70mm, and maybe longer.
    If you are looking for weight saving, RaceFace is one of your best bet out here and for the price it's kinda king of the hill with Thomson crawling in that tiny mud hole all the way down
    Thomson say $100 for 50mm stem @ 255g... RaceFace say $60 for 50mm @ 158g...
    No brainer here.
    David
    Freshly Fujified
    Reputation: Call_me_Clyde's Avatar
    David has some valid points
    But to say that the Thomson is "over build" is a bit of a stretch. Thomson is the de-facto standard by which many cyclists compare all other stems and seatposts. They are used for all ride styles to include road, singletrack, all-mountain, freeride and downhill. There is no reason to think that a Thomson would be more than you need. Many of us would say it's the perfect stem.
    Are they more expensive? Yep. Will other stems work? Yep. I've used the Race Face and Truvativ products, and they will work just fine, especially if you are budget conscious.
    Bob
    'If Wal-Mart sold parachutes, who would jump?' Frank Havnoonian (quoting his father) Drexel Hill Cyclery
    Huckin' trails
    Quote Originally Posted by Call_me_Clyde View Post
    Bob
    I'm on a budget almost 100% of the time... now the question is how big your budget is. Mine is RaceFace. If yours is Thomson, well congratulation
    Budget always help us to get the most out of each pieces... So I guess the OP should tell us his budget and exact use of the bike...
    David
    Paste eater
    Reputation: Jwind's Avatar
    Mar 2006
    The truvativ line has some very affordable options and they've come a long way IMO.
    I have some brand new stems lying around that I'm getting ready to throw up on the classifieds. I have a few Truvativ AKA stems that I've been completely happy with. Syncros have always been reliable for me too.
    On another note, you probably have a standard steer tube unless you runninga Lyrik or something with a 1.5 inch non-tapered steer tube.
    Quote Originally Posted by David C View Post
    Normaly your steerer tube should be 1" 1/8 diameter, since it's the standard for MTB bike fork... Now your handlebar diameter at the clamp area might be 31.8mm or 28.6mm... So take a gage and measure... but if you are going for that kind of stem, you better get a 31.8mm bar, otherwise it's like riding cheap components on DH bike... Taking risk. And the 28.6mm bar won't be able to hold in place in a 31.8mm stem clamp...
    No brainer here.
    David
    Bar diameters tend to be either 31.8mm or 25.4 no? Cant say that I've seen a 28.6mm bar
    As for stem brands, for the most part I would say the brand doesnt matter. I happen to be a fan of both Thomson and RaceFace but getting the correct stem for your particular application/need regardless of brand should be okay.
    Huckin' trails
    Quote Originally Posted by Moozh View Post
    Damn. Sorry for that mistake, I got confused with other measurements and did not realize that. I will edit those to the correct diameter...
    And we are still waiting for the OP spec on the intended use and budget.
    Thanks,
    David
    Big Test Icycles
    Reputation: Hangtime's Avatar
    Chromag Ranger 50mm. Beat the heck out of it. They are built tough and light
    - Sent from my iPhone using Tapatalk
    Nov 2007
    Thomson Elite X4 50mm 0 degree. $60.89 shipped for a black one from amazon.com 178grams.
    Amazon.com: Thomson X4 31.8 Bicycle Stem: Sports & Outdoors
    For now I'm jumping one meter jumps but I would like to do more.
    My budget is 100 usd.
    I think I need the shortest stem. Is there some direct stem for my fox vanilla RLC fork ?
    There might be 40mm stems, can't remember. If you're looking for the shortest one you can find, visit the websites for the brands that cater to FR and AM. Cromag would be one place to start. Rarely might also offer a 40, might be 50 though...
    Reputation: Whip Chop!'s Avatar
    I vote Thomson. Light and bulletproof.
    Huckin' trails
    Quote Originally Posted by marikth View Post
    Well for this level, I'd said Thomson worth the shot... I was more thinking of AM then really aggressive AM... Thomson made good product, among all other manufacturer. I think now the look must be one of the condition for the stem you gonna buy... Don't buy something too flashy for a flat dark grey bike, you know what I mean.
    Truvativ can offer you something with badass look too. I like the Chromag either. Real stuff that get you set on a nice level like Fox components do.
    Check the weight, cost and then look and you will be able to made the best choice. Put those 3 in the order you want went searching and good luck
    David
    thanks a lot for your help. I decided to go on thomson's stem,
    but i can't decide which one exactly to choose:
    1. Thomson X4 31.8mm 50mm 90-D Black Mountain Bike Stem | eBay
    2. Thomson X4 31.8mm 50mm 90-D Silver Mountain Bike Stem | eBay
    3. Thomson Elite Fixed Gear Road BIke Stem 50 22.2mm Blk | eBay
    4. THOMSON ELITE MTB STEM 0 degree 25.4 x 50mm BLACK | eBay
    5. Thomson Blk Threadless Bicycle Stem 0dx50x25.4 #59775 | eBay
    the cost is the same. the wight is different in 80 grams but the strength too.
    don't know which is better: please help!
    this is my bike: dark blue:
    Bikes / Archive*
    the silver one looks great but I don't know if it will look good like you said.
    Huckin' trails
    Bikes / Archive*
    No hard at all... From the bike archive,you have a stock bar diameter of 31.8mm, so only the Thomson X4 31.8mm 50mm 90-D will fit... Unless you can find the others in 31.8mm version or you have a 25.4mm bar...
    Then yes, the black will look better then the silver one on your bike, but both look great alone.
    So it's your call and don't forget to measure your bar diameter before to be sure...
    David
    Out of curiosity, do you know what length of stem you are using now. I might suggest, that you go with something from TruVative, especially in the $40ish price range and buy multiple sizes, especially if you are not used to a 40, 50, or 60mm length stem. Once you have figured out which length is comfortable to you, then sell them off and buy the more expensive stem you do want, Syncros being my choice of stem.
    Bonking ... not feelin' well
    I can't buy any Chromag parts, because it makes the rest of my bike look cheap.
    sorry but this is not my bar! and many of the parts gone thought some improvements.
    Today I'm taking my bike after shock service, and than check the diameter.
    Reputation: Andy Pancroft's Avatar
    EC90SL - I love it!!
    RideDirt
    Reputation: aedubber's Avatar
    I just picked uP this TRUVATIV Hussefelt Stem | SRAM .. I'm gonna try it out and see what happens ...
  1. Thomson Elite Stem/F100RLC Fork loose after removing stem?
    By ALEV8 in forum Shocks and Suspension
    Last Post: 09-24-2010, 11:37 PM
  2. Replies: 6
    Last Post: 09-14-2010, 11:31 AM
  3. Replies: 6
    Last Post: 07-29-2008, 08:39 AM
  4. Replies: 16
    Last Post: 02-08-2008, 07:38 PM
  5. Bar sweep: short stem pushed forward or longer stem pulled back?
    By newyorker in forum Downhill - Freeride
    Last Post: 11-02-2005, 10:18 PM
