Results 1 to 17 of 17
    wadeintahoe
    Need help choosing new hydraulic brakes for my 2002 Giant AC1
    Hi, I recently took a header and broke my rear brake lever housing in half. Since these were the original brakes that came with the bike, I have never bought brakes b4. I ride in Tahoe, and the trails are often very technical, very rocky, tree roots, etc. My bike, being an All Mountain bike weighs in probably 8 to 10 pounds heavier than a tipical cross country bike. In the 40 something pound range is my guess. I am looking for a hydraulic rear and maybe later a front brake.
    Questions:
    1. Is 200mm the same as an 8" rotor.
    2. Any info I need to know or measure for as far as the mounting holes.
    3. Is the hose size standard or do I need to order the right size, or is
    it cut to fit.
    4. What is a Banjo nut or fitting?
    5. Basically, I'm looking for a brake appropriate for an all mountain bike that is ridden on technical trails with great modulation. Probably a two-finger lever, ease of use, proven performance.
    One more thing, this bike has always squeeled like a pig when I am using the rear brake. Soooo annoying! Ive dropped down to a 6" rotor on Giants advice and it still does it. Tried different pads. Any advise on how to fix and avoid this in the future?
    Thank You for you time.
    May 2013
    I don't have much experience yet with disc brakes but I do like the Shimano XT I have on my bike so far. They are quiet, except when wet, great stopping power and nice degree modulation.
    meow meow
    Reputation: b-kul's Avatar
    id go for whatever shimano brakes are in your budget. by far the best ratio of money to power to ease of maintenance out there. hoses are cut to fit, pretty simple. dont worry about a banjo nut, that wont really come into play. if you have rotors and adapters already all you need to worry about is finding the right brakes.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    First and most important question: What's your budget?
    Reputation: nauc's Avatar
    x2 on the Shimano XT's
    Reputation: jmallory's Avatar
    Shimano XTs and Icetech rotors. Such a nice setup.
    Reputation: Hikers Only's Avatar
    Oct 2010
    hands down the Shimano XT's with Ice Tech rotors!
    meow meow
    how big a difference do you find the rotors make? im running my xt's with g2 rotors and they are pretty awesome.
    Jun 2012
    The new slx and any xt is a great brake
    Clueless genius
    Save your money and go for the SLX over the XT. They're essentially the same brake, minus the flashy chrome faceplate and a small adjustment that does next to nothing. The icetech pads in my opinion don't make a whole lot of difference over the non icetech, but the icetech rotors are definitely an improvement over solid steel ones. Worth the extra money? Maybe. That said, "normal" shimano rotors are really damn good too!
    1994 Cannondale M400 2017 Felt Surplus 30
    1997 Marin Point Reyes 2013 Pivot Mach 5.7
    MTBR Member
    Reputation: ncfisherman's Avatar
    Quote Originally Posted by Chikelusmith View Post
    they have the better strength and durability than any other brand
    Can't tell if this is sarcasm or not.
    007 is offline
    b a n n e d
    Jun 2005
    Shimano's are really great..they have the better strength and durability than any other brand so i guess you might wanna stick to them for your requirement..i think that will be great.
    Quote Originally Posted by ncfisherman View Post
    Yeah, I can't tell either . . . Shimano brakes are not category leaders in regard to power or durability.
    Still haven't heard back from OP regarding budget . . . . no point in recommending something until we know what the target pricepoint is.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Shimano XT FTW. Your LIFE depends on brakes, and the XT is the best investment. Shop around....they can be had for under $150/side.
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
    Mar 2013
    Hope Tech V4, are awesome, if your budget allows it.
    Reputation: Wombat's Avatar
    Wade
    To answer your questions:
    Yes, 203mm is the most common "8"" size.
    Your forks and frame probably require IS adapters for the calipers. Most will come with these adapters as calipers are usually now Post Mount.
    3. Is the hose size standard or do I need to order the right size, or is it cut to fit.
    Hose don't come in standard lengths. Measure how long your current hoses or cables are to see what length hoses you'll need. They usually need to be cut and then bled.
    It sits over the hose and is pushed into the caliper/master cylinder by the other hose fittings.
    I used the old 4 piston XTs on my AC and was happy with them. They ended up on my Reign a few years ago. I recently resurrected the AC and put 203mm Avid BB7s on it. I find these as good as my old XTs.
    This bike has always squealed like a pig when I am using the rear brake. Soooo annoying! Ive dropped down to a 6" rotor on Giants advice and it still does it. Tried different pads. Any advise on how to fix and avoid this in the future?
    There are lots of threads on here about this; For some brakes it seems impossible. The Avid hydraulic brakes seem to be the worst offenders.
    meow meow
    some frames actually amplify up the vibration into a squeal, likely your issue, and as wombat said, likely not a ton you can do about it other than avoid avids.
    Nothing can stop me now
    Hopes. What's your budget?
  1. Giant XtC NRS 3 2002 - bad idea?
    By tim808 in forum Beginner's Corner
    Last Post: 09-18-2016, 01:51 AM
  2. Bottom bracket for 2002 giant team dh
    By Gnome_1080 in forum General Discussion
    Last Post: 05-22-2013, 04:30 PM
  3. 2002 GIANT DH Comp - Noob
    By Performula in forum Downhill - Freeride
    Last Post: 03-01-2013, 10:23 AM
  4. Replies: 4
    Last Post: 09-03-2012, 11:59 AM
  5. 2002 Giant AC2 vs 2008 (new) Mongoose Otero Elite
    By sbbamafan in forum Bike and Frame discussion
    Last Post: 01-19-2011, 04:18 PM
